3.6. Three-dimensional DEM hopper
Property
Value
geometry
5 cm diameter hopper
mesh
10 x 25 x 10
solid diameter
0.003 m
solid density
2500 kg/m2
gas velocity
NA
temperature
298 K
pressure
NA
3.6.1. Create a new project
  • On the main menu, select New project
  • Create a new project by double-clicking on “Blank” template.
  • Enter a project name and browse to a location for the new project.
  • When prompted to enable SMS workflow, answer No, we will use the standard workflow for this tutorial.
create project
3.6.2. Select model parameters
  • On the Model pane, enter a descriptive text in the Description field
  • Select “Discrete Element Model (MFiX-DEM)” in the Solver drop-down menu
  • Check the Disable Fluid Solver (Pure Granular Flow) checkbox.
select model parameters
3.6.3. Enter the geometry
  • Select the Wand wizard menu and select the hopper wizard
  • Select apply to build the hopper stl file
  • Press the Autosize button to fit the domain extents to the geometry
  • Press the Overscan Reset View icon on the top-left corner of the Model window
hopper wizard
3.6.4. Enter the mesh
  • Enter 10 for the x cell value
  • Enter 25 for the y cell value
  • Enter 10 for the z cell value
enter mesh
  • Enter 0.0 in the Facet Angle Tolerance
3.6.5. Create regions for initial and boundary condition specification
Select the Regions pane. By default, a region that covers the entire domain is already defined.
  • Click the All button to create a region that encompasses the entire domain
  • change the name of the region to a descriptive name such as “walls”
  • Check the Select facets (STL) checkbox to turn the region into a STL region. The facets of the hopper should now be selected.
  1. Change the Y Min domain extent value on the geometry pane by a small amount so that those facets fall outside the simulation domain (for example, change the value to -0.0974).
  2. Change the Y From region extent value on the regions pane for this STL region by a small amount so that those facets fall outside the region (for example, change the value to ymin+0.0001)
  3. Or, use the Filter facets based on normals option on the region pane.
For this example, use option 3 to filter the facets that have normals pointed in the Y direction by:
  • Select box from the Selection method drop-down.
  • Uncheck Slice facets.
  • Check the Filter facets based on normals checkbox
  • Enter a vector pointed in the positive Y direction by entering 0, 1, and 0 in the x, y, z fields, respectively
  • Check the Include equilibrant vector to include facets with normals in the opposite direction of the vector (-x, -y, -z)
  • Enter an angle of 10 in the angle field to include facets with normals within 10 degrees of the filter vector
  • Check the Invert Selection check box to de-select facets that fall along the filter vector and select all the other facets
create region 1
  • Click the Bottom
  • Enter a name for the region in the Name field (“outlet”)
  • Click the All
  • Enter a name for the region in the Name field (“solids”)
  • Enter ymin/3 in the From Y field
  • Enter 0 in the To Y field
3.6.6. Create a solid
On the Solids pane
  • Click the Add button to create a new solid
  • Enter a descriptive name in the Name field (“solids”)
  • Keep the model as “Discrete Element Model (MFiX-DEM)”)
  • Enter the particle diameter of 0.003 m in the Diameter field
  • Enter the particle density of 2500 kg/m2 in the Density field
In the DEM sub-pane, check Enable automatic particle generation checkbox
3.6.7. Create Initial Conditions
  • Click the Add button to create a new initial condition
  • On the Select region dialog, select the “solids” region and click OK
  • On the solids sub-pane, enter 0.4 in the Volume fraction field
3.6.8. Create Boundary Conditions
Select the Boundary conditions pane and create a wall boundary condition for the hopper by:
  • clicking the Add button
  • On the Select region dialog, select “No Slip Wall” from the Boundary type drop-down menu
  • Select the “walls” region and click OK
  • On the Select region dialog, select “Pressure outflow” from the Boundary type combo-box
  • Select the “outlet” region and click OK
3.6.9. Select output options
  • Select the Output pane
  • On the Basic sub-pane, check the Write VTK output files (VTU/VTP) checkbox
new boundary condition
  • Select the VTK sub-pane
  • Create a new output by clicking the Add button
  • On the “select region” dialog, select “particle data” from the output type drop-down menu
  • Select the “Background IC” region from the list to save particle data over the entire domain
  • Click OK to create the output
  • Change the Write interval to 0.01 seconds
  • Select the Diameter and Translational velocity checkboxes
3.6.10. Change run parameters
  • Change Stop time to 2.0 seconds
  • Change Time step to 1e-3 seconds
  • Change Maximum time step to 1e-2 seconds
3.6.11. Run the project
  • Save project by clicking Save button
  • Run the project by clicking the Play button
  • On the Run dialog, select the default solver
  • Click the Run button to actually start the simulation
run
3.6.12. View results
  • Create a new visualization tab by pressing the Add in the upper right hand corner.
  • Select an item to view, such as plotting the time step (dt) or click the VTK button to view the vtk output files.
results
