3.2. Two-dimensional fluidized bed, Two-fluid Model (TFM)¶
Geometry |
10 cm x 30 cm |
Mesh |
20 x 60 |
Solid diameter |
200 microns ( |
Solid density |
Gas velocity |
0.25 m/s |
Temperature |
Pressure |
3.2.1. Create a new project¶
On the main menu select
On the Model
drop-down menu.
3.2.3. Enter the geometry¶
2 Dimensional
checkboxEnter
10/100
30/100
meters for the maximum y value
3.2.4. Enter the mesh¶
pane, Background
20
60
for the y cell value
Select the Regions
visualize the results.
Color
buttonEnter
xmin
ormin
in theFrom X
fieldEnter
xmax
ormax
in theTo X
fieldEnter
ymin
ormin
in theFrom Y
fieldEnter
ymax/2
ormax/2
in theTo Y
fieldEnter
zmin
ormin
in theFrom Z
fieldEnter
zmax
ormax
in theTo Z
3.2.6. Create a solid¶
field (“glass beads”)Keep the model as “Two-Fluid Model (MFiX-TFM)”)
200e-6
2500
kg/m2 in theDensity
101325
Pa in thePressure (optional)
button.
0.4
in theVolume Fraction
Select region
Y-axial velocity
field of “0.25” m/s
Select region
On the Numerics
pane, Residuals
in theFluid Normalization
field.
checkbox
sub-paneSelect the “Background IC” region from the list to save all the cell data
to create the output
*.vtu
files in theFilename base
fieldChange the
to0.1
secondsSelect the
Volume fraction
,Pressure
, andVelocity vector
checkboxes on theFluid
sub-sub-pane
to1e-3
secondsChange the
to1e-2
seconds
3.2.12. Run the project¶
3.2.13. View results¶
3D view
