3.7. DEM granular flow chutes
Property
Value
geometry
1.75 m x 0.94 m x 0.2 m
mesh
20 x 20 x 10
solid diameter
12.5 mm (0.0125 m)
solid density
2500 kg/m2
temperature
298 K
pressure
101325 Pa
3.7.1. Create a new project
  • On the main menu, select New project
  • Create a new project by double-clicking on “Blank” template.
  • Enter a project name and browse to a location for the new project.
  • When prompted to enable SMS workflow, answer No, we will use the standard workflow for this tutorial.
Create project
3.7.2. Select model parameters
On the Model pane:
  • Enter a descriptive text in the Description field
  • Select “Discrete Element Model (MFiX-DEM)” in the Solver drop-down menu.
  • Check the Disable Fluid Solver checkbox.
3.7.3. Enter the geometry
  • Create the cylindrical geometry by pressing Geometry -> primitives -> cylinder
    • Enter 0.1 meters for the cylinder radius
    • Enter 30 for the cylinder resolution
add cylinder
  • Create another cylindrical geometry by pressing Geometry -> primitives -> cylinder
    • Enter 1.2 meters for the cylinder height
    • Enter 0.08 meters for the cylinder radius
  • Subtract the smaller radius cylinder from the larger radius cylinder
    • Select the larger radius cylinder (named cylinder)
    • While holding the ctrl key, select the smaller radius cylinder (named cylinder1)
    • Press the Difference (difference) button
apply difference
  • Slice the tube in half:
    • Add a box: Geometry -> primitives -> box
    • Change the Center X value to 0.5 m
    • Change the Y Length to 1.2 m
    • Select the tube (named difference)
    • While holding the ctrl key, select the box (named box)
    • Press the Difference button
  • Rotate the chute:
    • Select the chute (named difference1)
    • Add a filter: Filter -> transform
    • Enter a value of 0.8 m in the Translate Y field.
    • Enter a value of 70 in the Rotation Z field.
Add filter
  • Copy the chute by pressing the Copy button with the chute selected (named transform)
    • Enter a value of 0.8 in the Translate X field
    • Enter a value of 0.6 in the Translate Y field
    • Enter a value of 120 in the Rotation Z field
  • Copy the chute again by pressing the Copy button with the chute selected (named transform1)
    • Enter a value of 0.0 in the Translate X field
    • Enter a value of 0.3 in the Translate Y field
  • Press the Autosize button to fit the domain extents to the geometry
enter cylinder input
3.7.4. Enter the mesh
On the Mesh pane:
  • On the Background sub-pane
  • Enter 20 for the x cell value
  • Enter 20 for the y cell value
  • Enter 10 for the z cell value
3.7.5. Create regions for initial and boundary condition specification
Select the Regions pane.
  • Create a region to be used for the wall boundary condition
    • Click the All (all) button to create a new region
    • Enter a name for the region in the Name field (“walls”)
    • Change the color by pressing the Color button
    • Check the Select facets (STL) checkbox
  • Create a region to be used as the mass inflow boundary condition
    • Click the Top (top) button to create a new region
    • Enter a name for the region in the Name field (“inlet”)
    • Enter a value of -0.4 m in the From X field
    • Enter a value of -0.2 m in the To X field
3.7.6. Create a solid
On the Solids pane:
  • Click the Add button to create a new solid
  • Enter a descriptive name in the Name field (“glass beads”)
  • Enter the particle diameter of 1/80 m in the Diameter field
  • Enter the particle density of 2500 kg/m2 in the Density field
On the DEM sub pane:
  • check the Enable automatic particle generation checkbox and keep defaults values for all other settings.
3.7.7. Create Initial Conditions
3.7.8. Create Boundary Conditions
  • Create a new Boundary condition by clicking the Add button
  • On the Select region dialog, select “Mass Inflow” from the Boundary type drop-down menu
  • Select the “inlet” region and click OK
  • On the glass beads sub-pane:
    • Enter a value of 0.1 in the volume fraction field.
    • Enter a velocity in the Y-axial velocity field of -0.1 m/s
  • Create another Boundary condition by clicking the Add button
  • On the Select region dialog, select “No Slip Wall” from the Boundary type combo-box
  • Select the “walls” region and click OK
3.7.9. Select output options
  • On the Basic sub-pane, check the Write VTK output files (VTU/VTP) check box
  • Select the VTK sub-pane
  • Create a new output by clicking the Add button
  • Select Particle Data in the Output type combo box.
  • Select the “Background IC” region from the list to save all the cell data
  • Click OK to create the output
  • Enter a base name for the *.vtp files in the Filename base field
  • Change the Write interval to 0.1 seconds
  • Select the Diameter and Translational Velocity check boxes.
3.7.10. Run the project
  • Save project by clicking Save button
  • Run the project by clicking the Play button
  • On the Run dialog, select the default executable from the list
  • Click the Run button to actually start the simulation
3.7.11. View results
  • Create a new visualization tab by pressing the Add in the upper right hand corner.
  • Select an item to view, such as plotting the time step (dt) or click the VTK button to view the vtk output files.
new boundary condition
