12.1.7. Geometry and discretization
12.1.7.1. COORDINATES
Table 12.35 Valid Values
Cartesian
Cartesian coordinates.
cylindrical
Cylindrical coordinates.
12.1.7.2. CPX(CTRL)
  • \(0 \le CTRL \le MAX{\_}CP\)
12.1.7.3. CPY(CTRL)
12.1.7.4. CPZ(CTRL)
12.1.7.5. CYCLIC_X
Table 12.36 Valid Values
No cyclic condition at x-boundary.
Cyclic condition at x-boundary.
12.1.7.6. CYCLIC_X_PD
Table 12.37 Valid Values
Cyclic condition with pressure drop at x-boundary.
12.1.7.7. CYCLIC_Y
Table 12.38 Valid Values
No cyclic condition at y-boundary.
12.1.7.8. CYCLIC_Y_PD
Table 12.39 Valid Values
Cyclic condition with pressure drop at y-boundary.
12.1.7.9. CYCLIC_Z
Table 12.40 Valid Values
No cyclic condition at z-boundary.
Cyclic condition at z-boundary.
12.1.7.10. CYCLIC_Z_PD
Table 12.41 Valid Values
Cyclic condition with pressure drop at z-boundary.
12.1.7.11. CYLINDRICAL_2D
12.1.7.12. DELP_X
12.1.7.13. DELP_Y
12.1.7.14. DELP_Z
12.1.7.15. DX(CELL)
  • \(0 \le Cell \le 5000\)
  • Use uniform mesh size with higher-order discretization methods.
  • DX should be kept uniform in cylindrical coordinates for strict momentum conservation.
12.1.7.16. DY(CELL)
12.1.7.17. DZ(CELL)
12.1.7.18. ERX(CTRL)
  • \(1 \le CTRL \le MAX{\_}CP\)
12.1.7.19. ERY(CTRL)
12.1.7.20. ERZ(CTRL)
12.1.7.21. FIRST_DX(CTRL)
Value of first DX in a segment (x-direction). A negative value will copy DX from previous segment (if available).
12.1.7.22. FIRST_DY(CTRL)
12.1.7.23. FIRST_DZ(CTRL)
12.1.7.24. FLUX_G
12.1.7.25. I_CYL_NUM
12.1.7.26. I_CYL_TRANSITION
Table 12.42 Valid Values
Two cell smoothing transition.
One cell smoothing transition.
No smoothing.
12.1.7.27. IMAX
Number of cells in the x (r) direction.
12.1.7.28. JMAX
Number of cells in the y-direction.
12.1.7.29. KMAX
Number of cells in the z-direction.
12.1.7.30. LAST_DX(CTRL)
Value of last DX in a segment (x-direction). A negative value will copy DX from next segment (if available).
12.1.7.31. LAST_DY(CTRL)
12.1.7.32. LAST_DZ(CTRL)
12.1.7.33. NCX(CTRL)
12.1.7.34. NCY(CTRL)
12.1.7.35. NCZ(CTRL)
12.1.7.36. NO_K
  • Z axis in Cartesian coordinate system
  • Theta in cylindrical coordinate system
Table 12.43 Valid Values
3D simulation.
2D simulation.
12.1.7.37. SHEAR
12.1.7.38. V_SH
12.1.7.39. X_MAX
Simulation domain upper bound in the x-direction.
12.1.7.40. X_MIN
Simulation domain lower bound in the x-direction.
12.1.7.41. XLENGTH
Simulation domain length in the x (r) direction.
12.1.7.42. XMIN
12.1.7.43. Y_MAX
Simulation domain upper bound in the y-direction.
12.1.7.44. Y_MIN
Simulation domain lower bound in the y-direction.
12.1.7.45. YLENGTH
Simulation domain length in the y-direction.
12.1.7.46. Z_MAX
Simulation domain upper bound in the z-direction.
12.1.7.47. Z_MIN
Simulation domain lower bound in the z-direction.
12.1.7.48. ZLENGTH
