12.1.17. Solids phase
12.1.17.1. C_PS0(PHASE)
Applies to solids model(s): TFM, DEM
12.1.17.2. CGP_D_P0(PHASE)
12.1.17.3. CGP_STAT_WT(PHASE)
12.1.17.4. D_P0(PHASE)
12.1.17.5. DIL_FACTOR_VSD
12.1.17.6. DIL_INERT_X_VSD(PHASE)
12.1.17.7. GSP_MODEL
Method used for modeling glued-sphere particles
Table 12.84 Valid Values
EXPLICIT
Model each component sphere separately, so properties such as temperature can vary.
IMPLICIT
Model the whole GSP, and component spheres share all properties.
12.1.17.8. GSP_Q1(PHASE)
Glued sphere particle quaternion q1.
12.1.17.9. GSP_Q2(PHASE)
Glued sphere particle quaternion q2.
12.1.17.10. GSP_Q3(PHASE)
Glued sphere particle quaternion q3.
12.1.17.11. GSP_Q4(PHASE)
Glued sphere particle quaternion q4.
12.1.17.12. INERT_SPECIES(PHASE)
12.1.17.13. K_S0(PHASE)
12.1.17.14. KS_MODEL(PHASE)
Table 12.85 Valid Values
CONST_EFF
USR
Bauer
Musser
12.1.17.15. MMAX
Number of solids phases.
12.1.17.16. MW_S(PHASE, SPECIES)
12.1.17.17. NGLUEDPARTICLES
Number of glued sphere particles
12.1.17.18. NMAX_S(PHASE)
12.1.17.19. RO_S0(PHASE)
12.1.17.20. RO_XS0(PHASE, SPECIES)
12.1.17.21. SOLIDS_MODEL(PHASE)
Table 12.86 Valid Values
TFM
Two-fluid model (continuum)
DEM
Discrete element model
CGP
Coarse-grained particle DEM
SQP
Superquadric particle DEM
GSP
Glued sphere particle DEM
PIC
Multiphase particle-in-cell
12.1.17.22. SPECIES_ALIAS_S(PHASE, SPECIES)
12.1.17.23. SPECIES_S(PHASE, SPECIES)
12.1.17.24. SQP_A(PHASE)
12.1.17.25. SQP_B(PHASE)
12.1.17.26. SQP_C(PHASE)
12.1.17.27. SQP_CONTACT_EVOLUTION
12.1.17.28. SQP_INIT_CONTACT_EVOLUTION
12.1.17.29. SQP_M(PHASE)
12.1.17.30. SQP_N(PHASE)
12.1.17.31. SQP_Q1(PHASE)
12.1.17.32. SQP_Q2(PHASE)
12.1.17.33. SQP_Q3(PHASE)
12.1.17.34. SQP_Q4(PHASE)
12.1.17.35. X_S0(PHASE, SPECIES)
