12.1.11. Output control
12.1.11.1. BDIST_IO
12.1.11.2. BREAKDOWN_SOLID_INVENTORY_BY_PHASE
Required
12.1.11.3. BSTART_WITH_ONE_RES
12.1.11.4. DEBUG_DES
12.1.11.5. DES_OUTPUT_TYPE
Table 12.55 Valid Values
PARAVIEW
TECPLOT
12.1.11.6. DES_REPORT_MASS_INTERP
12.1.11.7. FOCUS_PARTICLE
12.1.11.8. FRAME(VTK)
  • \(1 \le VTK \le 100\)
12.1.11.9. FULL_LOG
12.1.11.10. GROUP_RESID
12.1.11.11. GSP_OUTPUT_TYPE
Type of GSP output shape in VTK files.
Table 12.56 Valid Values
Use actual glued particle shape (show all component spheres).
Use bounding sphere to represent entire GSP.
12.1.11.12. MONITOR_DES_RRATE(MONITOR, RATE)
  • \(1 \le RATE \le NRRMAX\)
Write particle/parcel reaction rates in region. Particle/parcel data is converted to cell data.
12.1.11.13. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)
  • \(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
12.1.11.14. MONITOR_DT(MONITOR)
12.1.11.15. MONITOR_E_TURB_G(MONITOR)
12.1.11.16. MONITOR_EP_G(MONITOR)
12.1.11.17. MONITOR_EP_S(MONITOR, PHASE)
12.1.11.18. MONITOR_FLUID_RRATE(MONITOR, RATE)
Write fluid reaction rates in region. This keyword replaces MONITOR_RRate and does not require users to write code to save data in ReactionRates(:,:) array.
12.1.11.19. MONITOR_K_TURB_G(MONITOR)
12.1.11.20. MONITOR_MW_MIX_G(MONITOR)
12.1.11.21. MONITOR_NAME(MONITOR)
12.1.11.22. MONITOR_P_G(MONITOR)
12.1.11.23. MONITOR_P_S(MONITOR, PHASE)
12.1.11.24. MONITOR_P_STAR(MONITOR)
12.1.11.25. MONITOR_PART_PHASE(MONITOR, PHASE)
12.1.11.26. MONITOR_PART_RESIDENCE_TIME(MONITOR)
12.1.11.27. MONITOR_PART_RRATE(MONITOR, RATE)
  • \(1 \le rate \le 100\)
12.1.11.28. MONITOR_PCOUNT(MONITOR)
12.1.11.29. MONITOR_PMASS(MONITOR)
12.1.11.30. MONITOR_PVOL(MONITOR)
12.1.11.31. MONITOR_RADIUS(MONITOR)
12.1.11.32. MONITOR_RO_G(MONITOR)
12.1.11.33. MONITOR_RO_P(MONITOR)
12.1.11.34. MONITOR_RO_S(MONITOR, PHASE)
12.1.11.35. MONITOR_ROP_S(MONITOR, PHASE)
12.1.11.36. MONITOR_ROT_X(MONITOR)
12.1.11.37. MONITOR_ROT_Y(MONITOR)
12.1.11.38. MONITOR_ROT_Z(MONITOR)
12.1.11.39. MONITOR_RRATE(MONITOR, RATE)
12.1.11.40. MONITOR_SCALAR(MONITOR, SCALAR EQ.)
Write scalar in region.
12.1.11.41. MONITOR_T_G(MONITOR)
12.1.11.42. MONITOR_T_P(MONITOR)
12.1.11.43. MONITOR_T_S(MONITOR, PHASE)
12.1.11.44. MONITOR_TAVG_DT(MONITOR)
12.1.11.45. MONITOR_TAVG_RESET_DT(MONITOR)
12.1.11.46. MONITOR_TAVG_SS_SPAN(MONITOR)
12.1.11.47. MONITOR_TAVG_SS_TOL(MONITOR)
12.1.11.48. MONITOR_TAVG_START(MONITOR)
12.1.11.49. MONITOR_THETA_M(MONITOR, PHASE)
12.1.11.50. MONITOR_TYPE(MONITOR)
Data monitor type.
Table 12.57 Valid Values
Point value
Sum over region
Minimum over region
3
Maximum over region
4
5
6
7
Flow rate across surface
8
Mass flow rate across surface
11
Volume integral
12
Volume-weighted average
13
Mass-weighted volume integral
14
Mass-weighted volume average
101
Sum over region
102
Minimum over region
103
Maximum over region
104
105
106
107
108
109
110
12.1.11.51. MONITOR_U_G(MONITOR)
12.1.11.52. MONITOR_U_S(MONITOR, PHASE)
12.1.11.53. MONITOR_V_G(MONITOR)
12.1.11.54. MONITOR_V_S(MONITOR, PHASE)
12.1.11.55. MONITOR_VEL_X(MONITOR)
12.1.11.56. MONITOR_VEL_Y(MONITOR)
12.1.11.57. MONITOR_VEL_Z(MONITOR)
12.1.11.58. MONITOR_W_G(MONITOR)
12.1.11.59. MONITOR_W_S(MONITOR, PHASE)
12.1.11.60. MONITOR_X_E(MONITOR)
12.1.11.61. MONITOR_X_G(MONITOR, SPECIES)
  • \(1 \le Species \le 100\)
12.1.11.62. MONITOR_X_P(MONITOR, SPECIES)
12.1.11.63. MONITOR_X_S(MONITOR, PHASE, SPECIES)
12.1.11.64. MONITOR_X_W(MONITOR)
12.1.11.65. MONITOR_Y_G(MONITOR, SPECIES)
12.1.11.66. MONITOR_Y_N(MONITOR)
12.1.11.67. MONITOR_Y_S(MONITOR)
12.1.11.68. MONITOR_Z_B(MONITOR)
12.1.11.69. MONITOR_Z_T(MONITOR)
12.1.11.70. NLOG
12.1.11.71. NRR
12.1.11.72. OUT_DT
12.1.11.73. PART_IN_DENSITY_EXCLUDE
12.1.11.74. PART_IN_DENSITY_MAX
12.1.11.75. PART_IN_DENSITY_MIN
12.1.11.76. PART_IN_DIAMETER_EXCLUDE
12.1.11.77. PART_IN_DIAMETER_MAX
12.1.11.78. PART_IN_DIAMETER_MIN
12.1.11.79. PART_IN_PHASE(PHASE)
12.1.11.80. PART_IN_TEMP_EXCLUDE
12.1.11.81. PART_IN_TEMP_MAX
12.1.11.82. PART_IN_TEMP_MIN
12.1.11.83. PART_IN_U_EXCLUDE
12.1.11.84. PART_IN_U_MAX
12.1.11.85. PART_IN_U_MIN
12.1.11.86. PART_IN_USR_VAR_EXCLUDE(INDEX)
  • \(1 \le Index \le 100\)
12.1.11.87. PART_IN_USR_VAR_MAX(INDEX)
12.1.11.88. PART_IN_USR_VAR_MIN(INDEX)
12.1.11.89. PART_IN_V_EXCLUDE
12.1.11.90. PART_IN_V_MAX
12.1.11.91. PART_IN_V_MIN
12.1.11.92. PART_IN_W_EXCLUDE
12.1.11.93. PART_IN_W_MAX
12.1.11.94. PART_IN_W_MIN
12.1.11.95. PART_IN_X_EXCLUDE
12.1.11.96. PART_IN_X_MAX
12.1.11.97. PART_IN_X_MIN
12.1.11.98. PART_IN_X_S_EXCLUDE(INDEX)
12.1.11.99. PART_IN_X_S_MAX(INDEX)
12.1.11.100. PART_IN_X_S_MIN(INDEX)
12.1.11.101. PART_IN_Y_EXCLUDE
12.1.11.102. PART_IN_Y_MAX
12.1.11.103. PART_IN_Y_MIN
12.1.11.104. PART_IN_Z_EXCLUDE
12.1.11.105. PART_IN_Z_MAX
12.1.11.106. PART_IN_Z_MIN
12.1.11.107. PART_OUT_DENSITY_EXCLUDE
Density filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.108. PART_OUT_DENSITY_MAX
Density maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.109. PART_OUT_DENSITY_MIN
Density minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.110. PART_OUT_DIAMETER_EXCLUDE
Diameter filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.111. PART_OUT_DIAMETER_MAX
Diameter maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.112. PART_OUT_DIAMETER_MIN
Diameter minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.113. PART_OUT_PHASE(PHASE)
Solids phase filter selection mode applied to particles written in particle output file. Change to .FALSE. to exclude particles belonging to this phase.
12.1.11.114. PART_OUT_TEMP_EXCLUDE
Temperature filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.115. PART_OUT_TEMP_MAX
Temperature maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.116. PART_OUT_TEMP_MIN
Temperature minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.117. PART_OUT_U_EXCLUDE
X-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.118. PART_OUT_U_MAX
X-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.119. PART_OUT_U_MIN
X-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.120. PART_OUT_USR_VAR_EXCLUDE(INDEX)
User-defined variable filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.121. PART_OUT_USR_VAR_MAX(INDEX)
User-defined variable maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.122. PART_OUT_USR_VAR_MIN(INDEX)
User-defined variable minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.123. PART_OUT_V_EXCLUDE
Y-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.124. PART_OUT_V_MAX
Y-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.125. PART_OUT_V_MIN
Y-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.126. PART_OUT_W_EXCLUDE
Z-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.127. PART_OUT_W_MAX
Z-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.128. PART_OUT_W_MIN
Z-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.129. PART_OUT_X_EXCLUDE
X-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data is outside the [min;max] range.
12.1.11.130. PART_OUT_X_MAX
X-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.131. PART_OUT_X_MIN
X-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.132. PART_OUT_X_S_EXCLUDE(INDEX)
Species filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.133. PART_OUT_X_S_MAX(INDEX)
Species maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.134. PART_OUT_X_S_MIN(INDEX)
Species minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.135. PART_OUT_Y_EXCLUDE
Y-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.136. PART_OUT_Y_MAX
Y-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.137. PART_OUT_Y_MIN
Y-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.138. PART_OUT_Z_EXCLUDE
Z-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.139. PART_OUT_Z_MAX
Z-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.140. PART_OUT_Z_MIN
Z-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_[DATA]_EXCLUDE is set to .TRUE.
12.1.11.141. PART_OUT_ZERO_VEL
Option to reset the velocity to zero in the particle output file. Default value is .False. (do not reset the velocity to zero).
12.1.11.142. PHIP_OUT_JJ
12.1.11.144. REPORT_MASS_BALANCE_DT
12.1.11.145. REPORT_NEG_DENSITY
Table 12.58 Valid Values
Log negative density errors.
12.1.11.146. REPORT_NEG_SPECIFICHEAT
Table 12.59 Valid Values
12.1.11.147. REPORT_SOLID_INVENTORY
Required
12.1.11.148. REPORT_SOLID_INVENTORY_DT
Required
12.1.11.149. RES_BACKUP_DT
12.1.11.150. RES_BACKUPS
12.1.11.151. RES_DT
Required
12.1.11.152. RESID_STRING(RESIDUAL INDEX)
Table 12.60 Valid Values
P0
Gas pressure
PM
Solids phase M pressure
R0
Gas density
RM
Solids phase M density
U0
Gas phase U-velocity
V0
Gas phase V-velocity
W0
Gas phase W-velocity
UM
Solids phase M U-velocity
VM
Solids phase M V-velocity
WM
Solids phase M W-velocity
T0
Gas temperature
TM
Solids phase M temperature
GM
X0NN
XMNN
K0
K-Epsilon model residuals
12.1.11.153. SPX_DT(SP VALUE)
  • \(1 \le SP Value \le 11\)
  • SP1: void fraction (EP_G)
12.1.11.154. TIME_DEPENDENT_FILENAME
Table 12.61 Valid Values
12.1.11.155. TSS_HDR
12.1.11.156. VTK_BC_ID(VTK)
12.1.11.157. VTK_C_PG(VTK)
12.1.11.158. VTK_C_PS(VTK, PHASE)
12.1.11.159. VTK_CUTCELL_ONLY(VTK)
12.1.11.160. VTK_DATA(VTK)
Table 12.62 Valid Values
C
Cell data (VTU file).
P
Particle data (VTP file).
G
Geometry data (STL file).
F
Force chain data (VTP file).
N
Glued (non-spherical) particle data (VTP file).
12.1.11.161. VTK_DBG_FILE(VTK)
When VTK_DBG_FILE is .TRUE., the VTK region file is only written when the subroutine WRITE_DBG_VTU_AND_VTP_FILES is called, typically in a UDF.
12.1.11.162. VTK_DEBUG(VTK, IDX)
  • \(1 \le IDX \le 15\)
12.1.11.163. VTK_DES_RRATE(VTK, RATE)
  • \(1 \le rate \le nRRmax\)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is accumulated in fluid cells.
12.1.11.164. VTK_DT(VTK)
12.1.11.165. VTK_DWALL(VTK)
12.1.11.166. VTK_E_TURB_G(VTK)
12.1.11.167. VTK_EP_G(VTK)
12.1.11.168. VTK_EP_S(VTK, PHASE)
12.1.11.169. VTK_FACET_COUNT_DES(VTK)
12.1.11.170. VTK_FCMAX_ONLY(VTK)
12.1.11.171. VTK_FILEBASE(VTK)
12.1.11.172. VTK_FLUID_RRATE(VTK, RATE)
12.1.11.173. VTK_GEO(VTK, GEO)
12.1.11.174. VTK_IJK(VTK)
12.1.11.175. VTK_K_TURB_G(VTK)
12.1.11.176. VTK_LAMBDA_2(VTK)
Write lambda_2 in region.
12.1.11.177. VTK_MU_G(VTK)
12.1.11.178. VTK_MW_MIX_G(VTK)
12.1.11.179. VTK_NB_FACET_DES(VTK)
12.1.11.180. VTK_NORMAL(VTK)
12.1.11.181. VTK_NXS(VTK)
12.1.11.182. VTK_NYS(VTK)
12.1.11.183. VTK_NZS(VTK)
12.1.11.184. VTK_P_G(VTK)
12.1.11.185. VTK_P_S(VTK, PHASE)
12.1.11.186. VTK_P_STAR(VTK)
12.1.11.187. VTK_PART_ANGULAR_VEL(VTK)
12.1.11.188. VTK_PART_C_PS(VTK)
12.1.11.189. VTK_PART_CGP_STAT_WT(VTK)
12.1.11.190. VTK_PART_COHESION(VTK)
12.1.11.191. VTK_PART_COL_FORCE(VTK)
12.1.11.192. VTK_PART_COORDINATION(VTK)
Write particle coordination number in region.
12.1.11.193. VTK_PART_DENSITY(VTK)
12.1.11.194. VTK_PART_DIAMETER(VTK)
12.1.11.195. VTK_PART_DRAG_COEFF(VTK)
12.1.11.196. VTK_PART_GLUEBOUNDING(VTK)
12.1.11.197. VTK_PART_GLUEDIAMETER(VTK)
12.1.11.198. VTK_PART_GLUEID(VTK)
12.1.11.199. VTK_PART_GLUEMASS(VTK)
12.1.11.200. VTK_PART_GLUEQUAT(VTK)
12.1.11.201. VTK_PART_GLUEVOLUME(VTK)
12.1.11.202. VTK_PART_ID(VTK)
Write particle ID in region.
12.1.11.203. VTK_PART_MASS(VTK)
12.1.11.204. VTK_PART_ORIENTATION(VTK)
12.1.11.205. VTK_PART_OVERLAP_STATS(VTK)
Write particle overlap statistics (min, max, mean) in region.
12.1.11.206. VTK_PART_PHASE(VTK, PHASE)
12.1.11.207. VTK_PART_PHASE_ID(VTK)
12.1.11.208. VTK_PART_PHYSICAL_DIAMETER(VTK)
12.1.11.209. VTK_PART_RANK(VTK)
12.1.11.210. VTK_PART_RESIDENCE_TIME(VTK)
12.1.11.211. VTK_PART_RRATE(VTK, RATE)
12.1.11.212. VTK_PART_TEMP(VTK)
12.1.11.213. VTK_PART_USR_VAR(VTK, USR_VAR)
12.1.11.214. VTK_PART_VEL(VTK)
12.1.11.215. VTK_PART_VOLUME(VTK)
12.1.11.216. VTK_PART_X_S(VTK, DES_SPECIES)
12.1.11.217. VTK_PARTITION(VTK)
12.1.11.218. VTK_RO_G(VTK)
12.1.11.219. VTK_RO_S(VTK, PHASE)
12.1.11.220. VTK_ROP_S(VTK, PHASE)
12.1.11.221. VTK_RRATE(VTK, RATE)
12.1.11.222. VTK_RRATE_LABEL(VTK, RATE)
12.1.11.223. VTK_SCALAR(VTK, SCALAR)
12.1.11.224. VTK_SCALAR_CC(VTK)
12.1.11.225. VTK_SELECT_MODE(VTK)
Table 12.63 Valid Values
C
P
I
12.1.11.226. VTK_SLICE_TOL(VTK)
12.1.11.227. VTK_T_END(VTK)
12.1.11.228. VTK_T_G(VTK)
12.1.11.229. VTK_T_S(VTK, PHASE)
12.1.11.230. VTK_T_START(VTK)
12.1.11.231. VTK_THETA_M(VTK, PHASE)
12.1.11.232. VTK_U_G(VTK)
12.1.11.233. VTK_U_S(VTK, PHASE)
12.1.11.234. VTK_V_G(VTK)
12.1.11.235. VTK_V_S(VTK, PHASE)
12.1.11.236. VTK_VAR(IDX)
  • \(1 \le IDX \le 20\)
Table 12.64 Valid Values
Void fraction (EP_g)
3
Gas velocity (U_g, V_g, W_g)
4
5
Solids density (ROP_s)
6
7
8
Scalar
Reaction rates
11
K and Epsilon
12
100
Grid Partition
101
Boundary Condition ID
102
Distance to wall
103
DEM facet count
104
DEM Neighboring facets
999
Cell IJK index
1000
Cut face normal vector
12.1.11.237. VTK_VEL_G(VTK)
12.1.11.238. VTK_VEL_S(VTK, PHASE)
12.1.11.239. VTK_VORTICITY(VTK)
12.1.11.240. VTK_W_G(VTK)
12.1.11.241. VTK_W_S(VTK, PHASE)
12.1.11.242. VTK_X_E(VTK)
12.1.11.243. VTK_X_G(VTK, GAS SPECIES)
12.1.11.244. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)
12.1.11.245. VTK_X_W(VTK)
12.1.11.246. VTK_Y_G(VTK, GAS SPECIES)
12.1.11.247. VTK_Y_N(VTK)
12.1.11.248. VTK_Y_S(VTK)
12.1.11.249. VTK_Z_B(VTK)
12.1.11.250. VTK_Z_T(VTK)
12.1.11.251. VTP_DIR
12.1.11.252. VTU_DIR
Directory where VTK files are stored. By default, VTK files are written in the run directory.
12.1.11.253. WRITE_PART_OUT
Option to write a particle output file at the end of a simulation. This file has the same format as the particle_input.dat file (version 2.0 and up). After the simulation, the file can be renamed as particle_input.dat and used as initial condition for another simulation. For example, a first granular DEM simulation can be run fairly quickly to settle a bed of particles and the data saved in this file can be used to start a new coupled simulation. Default value is .False. (do not write the file).
12.1.11.254. WRITE_VTK_FILES
Table 12.65 Valid Values
