12.1.12. Parallelization control¶
computational grid. The preconditioners are chosen with the keyword LEQ_PC.
NODESI * NODESJ * NODESK must be the same as the number of processors
specified using mpirun (or equivalent command). Otherwise the code will
return with an error.
12.1.12.1. DBGPRN_LAYOUT¶
Print the index layout for debugging.
12.1.12.2. DEBUG_RESID¶
Group residuals to reduce global collectives.
12.1.12.3. DLB_NODESI(LAYOUT)¶
\(1 \le Layout \le 100\)
12.1.12.4. DLB_NODESJ(LAYOUT)¶
12.1.12.5. DLB_NODESK(LAYOUT)¶
12.1.12.6. ENABLE_DMP_LOG¶
All ranks write error messages.
12.1.12.7. NODESI¶
Number of grid blocks in x-direction.
12.1.12.8. NODESJ¶
Number of grid blocks in y-direction.
12.1.12.9. NODESK¶
Number of grid blocks in z-direction.
12.1.12.10. SOLVER_STATISTICS¶
Print out additional statistics for parallel runs
