56 integer,
allocatable :: arr1(:)
57 integer,
allocatable :: arr2(:)
58 integer :: work_around(100)
60 INTEGER :: LC, L, NN, IDX
66 LOGICAL,
PARAMETER :: lCALL_ISAT = .false.
68 CHARACTER(LEN=512) :: VERSION
81 version =
'RES = 01.8' 104 next_reca = 1 + next_reca
105 next_reca = next_reca - 1
108 next_reca = next_reca + 1
110 write (*,*)
'next_reca = ' , next_reca
112 write (*,*) l,
nmax(l)
113 work_around(l+1) =
nmax(l)
128 next_reca = next_reca + 1
129 write (*,*)
' next_reca = ' , next_reca
143 next_reca = next_reca + 1
219 next_reca = next_reca + 1
254 next_reca = next_reca + 1
267 next_reca = next_reca + 1
270 next_reca = next_reca + 1
274 next_reca = next_reca + 1
292 next_reca = next_reca + 1
305 next_reca = next_reca + 1
310 next_reca = next_reca + 1
318 next_reca = next_reca + 1
331 next_reca = next_reca + 1
336 next_reca = next_reca + 1
342 next_reca = next_reca + 1
353 next_reca = next_reca + 1
358 next_reca = next_reca + 1
367 next_reca = next_reca + 1
372 next_reca = next_reca + 1
377 next_reca = next_reca + 1
382 next_reca = next_reca + 1
387 next_reca = next_reca + 1
double precision, dimension(dimension_bc, dim_m) bc_ww_s
double precision l_scale0
double precision, dimension(dimension_ic) ic_p_star
character(len=16) coordinates
integer, parameter dimension_c
double precision, dimension(dimension_bc) bc_y_n
logical, dimension(0:dim_m) momentum_y_eq
double precision, dimension(dim_m) c_ps0
integer, parameter dimension_ic
double precision, dimension(dimension_ic) ic_l_scale
double precision, dimension(dim_eqs) ur_fac
character(len=60) description
double precision, dimension(dimension_bc) bc_dt_0
double precision, dimension(dimension_bc) bc_volflow_g
double precision, dimension(dimension_bc) bc_uw_g
double precision, dimension(dimension_ic, dim_m) ic_rop_s
double precision, dimension(dimension_bc, dim_m) bc_uw_s
double precision, dimension(dim_m) d_p0
character(len=16), dimension(dimension_is) is_type
integer, parameter dimension_is
double precision, dimension(dimension_bc) bc_t_g
double precision, dimension(dimension_ic) ic_t_g
integer, dimension(dimension_ic) ic_j_s
double precision, dimension(dimension_bc) bc_dt_l
double precision, dimension(dimension_is) is_x_e
integer, dimension(dimension_is) is_i_w
logical, dimension(0:dim_m) momentum_x_eq
character(len=60) run_name
logical, dimension(0:dim_m) species_eq
double precision, dimension(dimension_bc, dim_m) bc_w_s
integer, dimension(dimension_ic) ic_j_n
character(len=60), dimension(dimension_usr) usr_format
double precision, dimension(dimension_bc, dim_m, dim_n_s) bc_x_s
double precision, dimension(dimension_usr) usr_x_e
integer, parameter dim_scalar
double precision tol_resid_t
double precision tol_resid_scalar
logical, dimension(0:dim_m) momentum_z_eq
logical, dimension(dim_m) solve_ros
double precision, dimension(0:dim_j) dy
double precision, dimension(dimension_bc) bc_jet_g0
double precision, dimension(dimension_bc) bc_jet_gh
double precision, dimension(dimension_ic) ic_z_b
double precision, dimension(dim_m, dim_n_s) x_s0
double precision, dimension(dimension_bc) bc_x_e
double precision, dimension(dimension_usr) usr_y_s
double precision, dimension(dimension_ic) ic_x_w
double precision, dimension(dimension_usr) usr_z_b
subroutine convert_to_io_i(arr_internal, arr_io, nn)
character(len=16), dimension(dimension_ic) ic_type
double precision, dimension(dimension_ic, dim_m) ic_gama_rs
double precision, dimension(0:dim_k) dz
logical, dimension(dim_m) close_packed
double precision, dimension(dimension_bc) bc_ro_g
double precision, dimension(dim_n_g) mw_g
double precision, dimension(dimension_bc) bc_v_g
double precision, dimension(n_spx) spx_dt
integer, parameter dimension_usr
double precision, dimension(dimension_usr) usr_x_w
double precision, dimension(dimension_bc) bc_y_s
double precision, dimension(dimension_ic) ic_u_g
double precision, dimension(dimension_is) is_x_w
double precision, dimension(dimension_bc, dim_m) bc_volflow_s
double precision, dimension(dimension_ic) ic_z_t
double precision, dimension(dimension_ic, dim_m) ic_w_s
integer, dimension(dimension_ic) ic_i_w
double precision, dimension(dimension_usr) usr_y_n
integer, dimension(dim_eqs) leq_it
double precision, dimension(dimension_bc, dim_m) bc_t_s
integer, dimension(dimension_ic) ic_i_e
double precision, dimension(dimension_ic) ic_v_g
integer, dimension(dimension_ic) ic_k_b
character(len=16), dimension(dimension_usr) usr_ext
integer, dimension(dim_m) inert_species
integer, dimension(dimension_is) is_k_b
character(len=20), dimension(dimension_c) c_name
character(len=6), dimension(dimension_usr) usr_type
double precision, dimension(dimension_is, dim_m) is_vel_s
character(len=16) run_type
double precision, dimension(dim_m) v_s0
double precision, dimension(dimension_usr) usr_z_t
double precision, dimension(dim_m) k_s0
double precision, dimension(dimension_is) is_z_b
subroutine out_bin_512(IUNIT, ARRAY, N, NEXT_REC)
double precision, dimension(dimension_ic) ic_y_n
double precision, dimension(dimension_bc, dim_m) bc_hw_s
double precision, dimension(dimension_bc) bc_hw_g
double precision, dimension(dimension_is, 2) is_pc
double precision, dimension(dimension_ic, dim_m, dim_n_s) ic_x_s
double precision, dimension(dimension_bc) bc_p_g
double precision, dimension(dimension_ic) ic_w_g
double precision, dimension(0:dim_i) dx
double precision, dimension(dimension_ic) ic_gama_rg
double precision tol_diverge
double precision, dimension(dimension_bc) bc_dt_h
integer, dimension(dimension_ic) ic_k_t
character(len=16), dimension(dimension_bc) bc_type
double precision, dimension(dimension_usr) usr_dt
double precision, dimension(dimension_ic, dim_m) ic_v_s
double precision, dimension(dimension_bc, dim_m) bc_v_s
double precision, dimension(dimension_bc) bc_massflow_g
double precision, dimension(dimension_bc) bc_z_b
integer, dimension(dimension_is) is_j_s
double precision, dimension(dimension_bc, dim_m) bc_massflow_s
double precision, dimension(dimension_ic) ic_p_g
double precision, dimension(dimension_bc) bc_rop_g
double precision, dimension(dimension_bc) bc_u_g
double precision, dimension(dimension_bc) bc_vw_g
double precision, dimension(dimension_ic) ic_x_e
double precision, dimension(dimension_is) is_z_t
double precision, dimension(dim_m, dim_n_s) mw_s
double precision tol_resid_x
double precision, dimension(dimension_bc, dim_m) bc_u_s
double precision, dimension(dimension_ic, dim_m) ic_u_s
double precision, dimension(dim_m) u_s0
double precision, dimension(dim_m) w_s0
integer, parameter unit_res
double precision, dimension(dimension_bc, dim_n_g) bc_x_g
double precision, dimension(dimension_bc) bc_ep_g
integer, dimension(dim_eqs) discretize
double precision, dimension(dimension_is) is_y_s
double precision, dimension(dimension_ic, dim_n_g) ic_x_g
double precision, dimension(dimension_bc) bc_z_t
double precision, dimension(dimension_c) c
double precision, dimension(dimension_ic) ic_ep_g
double precision, dimension(dimension_is) is_y_n
integer, dimension(dim_eqs) leq_method
double precision, dimension(dim_m) ro_s0
double precision, dimension(dim_m) mu_s0
double precision, dimension(dimension_bc) bc_jet_gl
integer, dimension(:), allocatable flag
integer, dimension(dimension_is) is_j_n
integer, dimension(1:dim_scalar) phase4scalar
integer, dimension(dimension_is) is_i_e
double precision, dimension(dimension_bc) bc_w_g
character(len=60), dimension(dimension_usr) usr_var
double precision, dimension(dimension_ic) ic_y_s
double precision, dimension(dimension_bc, dim_m) bc_vw_s
double precision, dimension(dimension_bc) bc_ww_g
double precision, dimension(dimension_ic) ic_t_rg
double precision, dimension(dimension_ic, dim_m) ic_t_s
subroutine out_bin_512i(IUNIT, ARRAY, N, NEXT_REC)
double precision, dimension(dimension_bc, dim_m) bc_rop_s
double precision, dimension(dimension_bc) bc_x_w
integer, dimension(dimension_is) is_k_t
double precision, dimension(dimension_ic, dim_m) ic_t_rs
