stiff_chem_dbg_mod.f
2 ! !
3 ! Module name: STIFF_CHEM_DEBUG !
4 ! !
5 ! Purpose: !
6 ! !
7 ! Author: J.Musser Date: !
8 ! !
9 ! Comments: !
10 ! !
11 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
13
14  PRIVATE
15
16 ! Variable Access:
17 !---------------------------------------------------------------------//
18  PUBLIC :: ode_debug_level
19
20 ! Subroutine Access:
21 !---------------------------------------------------------------------//
22  PUBLIC :: allocate_stiff_chem_dbg
23
24  PUBLIC :: update_ode_old
25  PUBLIC :: reset_ode
26
27  PUBLIC :: check_ode_data
28  PUBLIC :: write_ode_log
29
30 ! Routine used to compare to values.
31  LOGICAL, external :: compare
32
33 ! Static variables/parameters.
34 !---------------------------------------------------------------------//
35 ! Debug Level: (Messages)
36 ! 0 - None
37 ! 1 - Limited
38 ! 2 - Aggressive
39  INTEGER :: ode_debug_level = 1
40
41 ! File unit for ODE Error Log.
42  INTEGER, parameter :: oel_unit = 6589
43
44 ! Original field variables. Used to reset after failed integration.
45  DOUBLE PRECISION, allocatable :: ode_vars_o(:)
46
47  LOGICAL :: print_err_header
48
49  contains
50
51 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
52 ! !
53 ! Module name: ALLOCATE_STIFF_CHEM_STATS !
54 ! !
55 ! Purpose: !
56 ! !
57 ! Author: J.Musser Date: !
58 ! !
59 ! Comments: !
60 ! !
61 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
62  SUBROUTINE allocate_stiff_chem_dbg(lODE_DIMN)
63
64  implicit none
65
66 ! The number ODEs (maximum).
67  INTEGER, intent(in) :: lODE_DIMN
68
69  allocate( ode_vars_o(lode_dimn) )
70
71  RETURN
72  END SUBROUTINE allocate_stiff_chem_dbg
73
74
75 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
76 ! Module name: ODE_UPDATE_OLD !
77 ! !
78 ! Purpose: !
79 ! !
80 ! Author: J.Musser Date: !
81 ! !
82 ! Comments: !
83 ! !
84 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
85  SUBROUTINE update_ode_old(lODE_DIMN, lODE_VARS)
86
87  implicit none
88
89 ! The number ODEs (maximum).
90  INTEGER, intent(in) :: lODE_DIMN
91
92 ! MFIX field variables mapped into the ODE format.
93  DOUBLE PRECISION, intent(in) :: lODE_VARS(lode_dimn)
94
95  ode_vars_o = lode_vars
96
97  RETURN
98  END SUBROUTINE update_ode_old
99
100
101 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
102 ! Module name: ODE_RESET !
103 ! !
104 ! Purpose: !
105 ! !
106 ! Author: J.Musser Date: !
107 ! !
108 ! Comments: !
109 ! !
110 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
111  SUBROUTINE reset_ode(lDIMN, lVARS, lAtps)
113  use compar, only: mype
114
115  use stiff_chem_stats, only: failedcount
116
117  implicit none
118
119 ! The number ODEs (maximum).
120  INTEGER, intent(in) :: lDIMN
121
122 ! MFIX field variables mapped into the ODE format.
123  DOUBLE PRECISION, intent(inout) :: lVARS(ldimn)
124
125  INTEGER, intent(in) :: lAtps
126
127  lvars = ode_vars_o
128
129  IF(latps == 3) failedcount(mype) = failedcount(mype) + 1
130
131  RETURN
132  END SUBROUTINE reset_ode
133
134
135 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
136 ! !
137 ! Module name: CHECK_ODE_DATA !
138 ! !
139 ! Purpose: !
140 ! !
141 ! Author: J.Musser Date: !
142 ! !
143 ! Comments: !
144 ! !
145 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
146  SUBROUTINE check_ode_data(lnD, lNEQ, loD, VARS, lUNLIMITED, &
147  lstate, lerr)
149  use param1, only : zero
150  use physprop, only : nmax, mmax
151  use toleranc, only : tmax, tmin
152
153  implicit none
154
155  INTEGER, intent(in) :: lnD
156
157  INTEGER, intent(in) :: lNEQ(lnd)
158
159 ! The number ODEs (maximum).
160  INTEGER, intent(in) :: loD
161
162 ! MFIX field variables mapped into the ODE format.
163  DOUBLE PRECISION, intent(in) :: VARS(lod)
164 ! Flag for unlimited steps.
165  LOGICAL, intent(in) :: lUNLIMITED
166 ! Sate value returned from ODEPACK
167  INTEGER, intent(in) :: lState
168 ! Error Flag
169  INTEGER, intent(out) :: lErr
170
171
172 ! Loop indicies:
173  INTEGER :: M ! phase
174  INTEGER :: N ! species
175  INTEGER :: Node ! other
176
177
178  lerr = 0
179
180 ! Check ODE_VAR for NaNs.
181 !---------------------------------------------------------------------//
182  DO node=1,lod
183  IF(vars(node).NE.vars(node)) THEN
184  lerr = -8
185  return
186  ENDIF
187  ENDDO
188
189
190 ! Check ODEPACK State
191 !---------------------------------------------------------------------//
192  IF(lstate == -1) THEN
193  lerr = lstate
194  if(lunlimited) return
195  ELSEIF(lstate == 2) THEN
196  lerr = 0
197  ELSE
198  lerr = lstate
199  ENDIF
200
201
202 ! Initialize.
203  node = 1
204
205 ! Check variables for physical values.
206 !---------------------------------------------------------------------//
207
208 ! Gas phase density.
209  IF(vars(node) <= zero) THEN
210  lerr = -(100 + node)
211  return
212  ENDIF
213  node = node + 1
214
215
216 ! Gas phase temperature.
217  IF(vars(node) > tmax .OR. vars(node) < tmin) THEN
218  lerr = -(100 + node)
219  return
220  ENDIF
221  node = node + 1
222
223 ! Gas phase species mass fractions.
224  DO n=1,nmax(0)
225  IF(vars(node) > 1.009d0) THEN
226  lerr = -(100 + node)
227  return
228  ENDIF
229  IF(vars(node) < 0.0d0) THEN
230  IF(abs(vars(node)) > 1.0d-5) THEN
231  lerr = -(100 + node)
232  return
233  ENDIF
234  ENDIF
235  node = node + 1
236  ENDDO
237
238 ! Solids temperature.
239  DO m = 1, mmax
240  IF(vars(node) > tmax .OR. vars(node) < tmin) THEN
241  lerr = -(100 + node)
242  return
243  ENDIF
244  node = node + 1
245  ENDDO
246
247
248  DO m = 1, mmax
249  IF(lneq(2+m) == 1) THEN
250
251 ! Solids volume fraction.
252  IF(vars(node) <= zero) THEN
253  lerr = -(100 + node)
254  return
255  ENDIF
256  node = node + 1
257
258 ! Solids phase species mass fractions.
259  DO n=1,nmax(m)
260
261  IF(vars(node) > 1.009d0) THEN
262  lerr = -(100 + node)
263  return
264  ENDIF
265  IF(vars(node) < 0.0d0) THEN
266  IF(abs(vars(node)) > 1.0d-5) THEN
267  lerr = -(100 + node)
268  return
269  ENDIF
270  ENDIF
271  node = node + 1
272
273  ENDDO
274  ENDIF
275  ENDDO
276
277  RETURN
278  END SUBROUTINE check_ode_data
279
280
281 !vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv!
282 ! !
283 ! Module name: ODE_ErrorLog !
284 ! !
285 ! Purpose: !
286 ! !
287 ! Author: J.Musser Date: !
288 ! !
289 ! Comments: !
290 ! !
291 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
292  SUBROUTINE write_ode_log(lErr, lnD, lNEQ, loD, lVARS)
294  use compar, only : mype
295  use run, only : time
296  use physprop, only : mmax
297
298  use indices
299
300  implicit none
301
302  INTEGER, intent(in) :: lErr
303
304  INTEGER, intent(in) :: lnD
305  INTEGER, intent(in) :: lNEQ(lnd)
306
307 ! The number ODEs (maximum).
308  INTEGER, intent(in) :: loD
309  DOUBLE PRECISION, intent(in) :: lVARS(lod)
310
311  INTEGER :: lc1
312  INTEGER :: IJK
313
314  DOUBLE PRECISION :: ddt_lVARS(lod)
315
316  CHARACTER(LEN=255) :: lFile
317
318  LOGICAL :: lExist
319
320  ijk = lneq(2)
321
322  lfile = ''; write(lfile,"('StiffChem_',I2.2,'.log')") mype
323
324  inquire(file=lfile,exist=lexist)
325  if(lexist) then
326  open(oel_unit,file=trim(adjustl(lfile)), position='append',convert='big_endian')
327  else
328  open(oel_unit,file=trim(adjustl(lfile)), status='new',convert='big_endian')
329  endif
330
331
332  if(print_err_header) then
333  WRITE(oel_unit,9000) time
334  print_err_header = .false.
335  endif
336
337
338  WRITE(oel_unit,9001) ijk, i_of(ijk), j_of(ijk), mype
339  WRITE(oel_unit,9002) lerr
340  WRITE(oel_unit,9003) lneq(1)
341
342  DO lc1=1,mmax
343  IF(lneq(lc1+2) == 1) THEN
344  WRITE(oel_unit,9004) lc1
345  ELSEIF(lneq(lc1+2) == 0) THEN
346  WRITE(oel_unit,9005) lc1
347  ELSE
348  WRITE(oel_unit,9006) lc1, lneq(lc1+2)
349  ENDIF
350  ENDDO
351
352  WRITE(oel_unit,"(/5x,'Field Variables:')")
353  WRITE(oel_unit,9007)
354  DO lc1=1, lod
355  WRITE(oel_unit,9008) lc1, ode_vars_o(lc1), lvars(lc1), &
356  (lvars(lc1) - ode_vars_o(lc1))
357  ENDDO
358
359  CALL stiff_chem_rrates(lneq, time, lvars, ddt_lvars)
360
361  WRITE(oel_unit,"(/5x,'Derivatives:')")
362  WRITE(oel_unit,9009)
363  DO lc1=1, lod
364  WRITE(oel_unit,9010) lc1, ddt_lvars(lc1)
365  ENDDO
366
367
368  RETURN
369
370  9000 FORMAT(//3x,'Time: ',g15.8)
371  9001 FORMAT(//5x,'Fluid Cell: ',i4,4x,'(',i3,',',i3,')',10x,&
372  'Process: ',i4)
373  9002 FORMAT( 5x,'Error Flag/ODEPACK Status: ',i4,/)
374
375  9003 FORMAT( 5x,'Number of ODEs Solved: ', i4,/)
376  9004 FORMAT( 5x,'Solving solids phase ',i2,&
377  ' bulk density and species equations.')
378
379  9005 FORMAT( 5x,'NOT solving solids phase ',i2,&
380  ' bulk density and species equations.')
381
382  9006 FORMAT( 5x,'Unknown flag for solids phase ',i2,' Flag = ',i4)
383
384
385  9007 FORMAT( 5x,'Var',6x,'Incoming',13x,'Returned',13x,'Difference')
386  9008 FORMAT( 5x,i3,3(3x,g18.8))
387
388
389  9009 FORMAT( 5x,'Var',6x,' YDOT ')
390  9010 FORMAT( 5x,i3,3x,g18.8)
391
392  END SUBROUTINE write_ode_log
393
394
395  END MODULE stiff_chem_dbg
subroutine, public write_ode_log(lErr, lnD, lNEQ, loD, lVARS)
Definition: indices_mod.f:45
double precision, parameter tmax
Definition: toleranc_mod.f:31
subroutine, public check_ode_data(lnD, lNEQ, loD, VARS, lUNLIMITED, lState, lErr)
double precision, parameter tmin
Definition: toleranc_mod.f:34
subroutine, public update_ode_old(lODE_DIMN, lODE_VARS)
integer, dimension(:), allocatable, public failedcount
integer, public ode_debug_level
integer mmax
Definition: physprop_mod.f:19
Definition: indices_mod.f:46
Definition: physprop_mod.f:119
integer mype
Definition: compar_mod.f:24
subroutine stiff_chem_rrates(lNEQ, lTime, Y, YDOT)
subroutine, public reset_ode(lDIMN, lVARS, lAtps)
double precision time
Definition: run_mod.f:45
subroutine, public allocate_stiff_chem_dbg(lODE_DIMN)
