12.1.4. Geometry and Discretization
12.1.4.1. COORDINATES
Table 12.24 Valid Values
Cartesian
Cartesian coordinates.
cylindrical
Cylindrical coordinates.
12.1.4.2. IMAX
Number of cells in the x (r) direction.
12.1.4.3. DX(CELL)
  • \(0 \le Cell \le 5000\)
  • Use uniform mesh size with higher-order discretization methods.
  • DX should be kept uniform in cylindrical coordinates for strict momentum conservation.
12.1.4.4. XMIN
12.1.4.5. XLENGTH
Simulation domain length in the x (r) direction.
12.1.4.6. X_MIN
Simulation domain lower bound in the x-direction.
12.1.4.7. X_MAX
Simulation domain upper bound in the x-direction.
12.1.4.8. JMAX
Number of cells in the y-direction.
12.1.4.9. DY(CELL)
12.1.4.10. YLENGTH
Simulation domain length in the y-direction.
12.1.4.11. Y_MIN
Simulation domain lower bound in the y-direction.
12.1.4.12. Y_MAX
Simulation domain upper bound in the y-direction.
12.1.4.13. NO_K
  • Z axis in Cartesian coordinate system
  • Theta in cylindrical coordinate system
Table 12.25 Valid Values
3D simulation.
2D simulation.
12.1.4.14. KMAX
Number of cells in the z-direction.
12.1.4.15. DZ(CELL)
12.1.4.16. Z_MIN
Simulation domain lower bound in the z-direction.
12.1.4.17. Z_MAX
Simulation domain upper bound in the z-direction.
12.1.4.18. ZLENGTH
12.1.4.19. CYCLIC_X
Table 12.26 Valid Values
No cyclic condition at x-boundary.
Cyclic condition at x-boundary.
12.1.4.20. CYCLIC_X_PD
Table 12.27 Valid Values
Cyclic condition with pressure drop at x-boundary.
12.1.4.21. DELP_X
12.1.4.22. CYCLIC_Y
Table 12.28 Valid Values
No cyclic condition at y-boundary.
12.1.4.23. CYCLIC_Y_PD
Table 12.29 Valid Values
Cyclic condition with pressure drop at y-boundary.
12.1.4.24. DELP_Y
12.1.4.25. CYCLIC_Z
Table 12.30 Valid Values
No cyclic condition at z-boundary.
Cyclic condition at z-boundary.
12.1.4.26. CYCLIC_Z_PD
Table 12.31 Valid Values
Cyclic condition with pressure drop at z-boundary.
12.1.4.27. DELP_Z
12.1.4.28. SHEAR
12.1.4.29. V_SH
12.1.4.30. FLUX_G
12.1.4.31. CYLINDRICAL_2D
12.1.4.32. I_CYL_NUM
12.1.4.33. I_CYL_TRANSITION
Table 12.32 Valid Values
Two cell smoothing transition.
One cell smoothing transition.
No smoothing.
12.1.4.34. CPX(CTRL)
  • \(0 \le CTRL \le MAX{\_}CP\)
12.1.4.35. NCX(CTRL)
  • \(1 \le CTRL \le MAX{\_}CP\)
12.1.4.36. ERX(CTRL)
12.1.4.37. FIRST_DX(CTRL)
Value of first DX in a segment (x-direction). A negative
12.1.4.38. LAST_DX(CTRL)
Value of last DX in a segment (x-direction). A
12.1.4.39. CPY(CTRL)
12.1.4.40. NCY(CTRL)
12.1.4.41. ERY(CTRL)
12.1.4.42. FIRST_DY(CTRL)
12.1.4.43. LAST_DY(CTRL)
12.1.4.44. CPZ(CTRL)
12.1.4.45. NCZ(CTRL)
12.1.4.46. ERZ(CTRL)
12.1.4.47. FIRST_DZ(CTRL)
12.1.4.48. LAST_DZ(CTRL)
