12.1.12. Point Source¶
Point sources (PS) are used in place of mass inlets where either the geometry and/or grid resolution prohibit proper boundary condition specification. For example, a point source may be used to model an injector with dimensions smaller than the grid. Point sources may be defined within a single computational cell, along a plane, or as a volume of computational cells.
Directional preference is specified with a velocity vector (i.e., PS_U_g,
PS_V_g, etc.), however, directional preference is not required.
12.1.12.1. PS_X_W(PS)¶
\(1 \le PS \le 5000\)
12.1.12.2. PS_X_E(PS)¶
12.1.12.3. PS_Y_S(PS)¶
12.1.12.4. PS_Y_N(PS)¶
12.1.12.5. PS_Z_B(PS)¶
12.1.12.6. PS_Z_T(PS)¶
12.1.12.7. PS_I_W(PS)¶
12.1.12.8. PS_I_E(PS)¶
12.1.12.9. PS_J_S(PS)¶
12.1.12.10. PS_J_N(PS)¶
12.1.12.11. PS_K_B(PS)¶
12.1.12.12. PS_K_T(PS)¶
K index of the top-most cell.
12.1.12.13. PS_U_G(PS)¶
X-component of incoming gas velocity.
12.1.12.14. PS_V_G(PS)¶
Y-component of incoming gas velocity.
12.1.12.15. PS_W_G(PS)¶
Z-component of incoming gas velocity.
12.1.12.16. PS_MASSFLOW_G(PS)¶
12.1.12.17. PS_T_G(PS)¶
Temperature of incoming gas.
12.1.12.18. PS_X_G(PS, SPECIES)¶
\(1 \le Species \le 100\)
12.1.12.19. PS_U_S(PS, PHASE)¶
X-component of incoming solids velocity.
12.1.12.20. PS_V_S(PS, PHASE)¶
Y-component of incoming solids velocity.
12.1.12.21. PS_W_S(PS, PHASE)¶
Z-component of incoming solids velocity.
12.1.12.22. PS_MASSFLOW_S(PS, PHASE)¶
12.1.12.23. PS_T_S(PS, PHASE)¶
12.1.12.24. PS_X_S(PS, PHASE, SPECIES)¶
