12.1.11. Internal Surface
12.1.11.1. IS_X_W(IS)
  • \(1 \le IS \le 500\)
12.1.11.2. IS_X_E(IS)
12.1.11.3. IS_Y_S(IS)
12.1.11.4. IS_Y_N(IS)
12.1.11.5. IS_Z_B(IS)
12.1.11.6. IS_Z_T(IS)
12.1.11.7. IS_I_W(IS)
12.1.11.8. IS_I_E(IS)
I index of the east-most cell
12.1.11.9. IS_J_S(IS)
J index of the south-most cell
12.1.11.10. IS_J_N(IS)
J index of the north-most cell
12.1.11.11. IS_K_B(IS)
K index of the bottom-most cell
12.1.11.12. IS_K_T(IS)
K index of the top-most cell
12.1.11.13. IS_TYPE(IS)
Type of internal surface
Table 12.63 Valid Values
IMPERMEABLE
No gas or solids flow through the surface.
SEMIPERMEABLE
Gas flows through the surface with an additional resistance. Solids velocity through the surface is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved).
X_IMPERMEABLE
No gas or solids flow in the X direction.
X_SEMIPERMEABLE
Gas flows in the Z direction with additional resistance. Solids velocity in the Z direction is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved).
Y_IMPERMEABLE
No gas or solids flow in the Y direction.
Y_SEMIPERMEABLE
Gas flows in the Y direction with additional resistance. Solids velocity in the Y direction is set to zero or to a user- specified fixed value (i.e., solids momentum equation for this direction is not solved).
Z_IMPERMEABLE
No gas or solids flow in the Z direction.
STL
Arbitrary shaped internal surface defined by an STL file. Only visible to DEM particles or PIC parcels. The fluid phase doesn’t feel this stl internal surface.
12.1.11.14. IS_PC(IS, IDX)
  • \(1 \le IDX \le 2\)
  • IDX=1: Permeability [1.0E32]
  • IDX=2: Inertial resistance coefficient [0.0]
12.1.11.15. IS_VEL_S(IS, PHASE)
