12.1.5. Two-Fluid Model
This section contains keywords relating to the Two-Fluid Model.
12.1.5.1. KT_TYPE
Solids phase stress model [Algebraic].
Table 12.33 Valid Values
ALGEBRAIC
Granular energy algebraic formulation.
AHMADI
Cao and Ahmadi (1995). Int. J. Multiphase Flow 21(6), 1203.
GD_99
Garzo and Dufty (1999). Phys. Rev. E 59(5), 5895.
GHD
Garzo, Hrenya and Dufty (2007). Phys. Rev. E 76(3), 31304
GTSH
Garzo, Tenneti, Subramaniam, Hrenya (2012). J.Fluid Mech. 712, 129.
IA_NONEP
Iddir & Arastoopour (2005). AIChE J. 51(6), 1620
LUN_1984
Lun et al (1984). J. Fluid Mech., 140, 223.
SIMONIN
Simonin (1996). VKI Lecture Series, 1996-2
12.1.5.2. FRICTION_MODEL
Table 12.34 Valid Values
Only solids pressure
SCHAEFFER
Schaeffer friction model. 1987, Journal of Differential Equations 66, 19–50.
SRIVASTAVA
Srivastava and Sundaresan friction model. 2003, Powder Technology 129(1-3):72-85
GUO_BOYCE
Guo-Boyce friction model, 2021. Proceedings of the National Academy of Sciences, 118 (35).
12.1.5.3. BLENDING_FUNCTION
Table 12.35 Valid Values
No blending
TANH_BLEND
Hyperbolic tangent function
SIGM_BLEND
Scaled sigmodial function
12.1.5.4. YU_STANDISH
Table 12.36 Valid Values
Use the Yu-Standish correlation.
Do not use the Yu-Standish correlation.
12.1.5.5. FEDORS_LANDEL
Table 12.37 Valid Values
Use the Fedors-Landel correlation.
Do not use the Fedors-Landel correlation.
12.1.5.6. RDF_TYPE
Table 12.38 Valid Values
CARNAHAN_STARLING
Carnahan, N.F. and Starling K.E., (1969). The Journal of Chemical Physics, Vol. 51(2):635-636. Only applies to monodisperse cases.
MA_AHMADI
Ma, D. and Ahmadi, G., (1986). The Journal of Chemical Physics, 84(6):3449. Only applies to monodisperse cases.
LEBOWITZ
Lebowitz, J.L. (1964) The Physical Review, A133, 895-899. Only applies to polydisperse cases.
MODIFIED_LEBOWITZ
Iddir, H. Y., Modeling of the multiphase mixture of particles using the kinetic theory approach. Doctoral Dissertation, Illinois Institute of Technology, Chicago, Illinois, 2004, (chapter 2, equations 2-49 through 2-52.) Only applies to polydisperse cases.
MANSOORI
Mansoori, GA, Carnahan N.F., Starling, K.E. Leland, T.W. (1971). The Journal of Chemical Physics, Vol. 54:1523-1525. Only applies to polydisperse cases.
MODIFIED_MANSOORI
van Wachem, B.G.M., Schouten, J.C., van den Bleek, C.M., Krishna, R. and Sinclair, J. L. (2001) AIChE Journal 47:1035–1051. Only applies to polydisperse cases.
12.1.5.7. ADDED_MASS
12.1.5.8. M_AM
12.1.5.9. C_E
12.1.5.10. R_P(PHASE, PHASE)
  • \(1 \le Phase \le 2\)
12.1.5.11. E_W
12.1.5.12. PHIP
12.1.5.13. PHIP0
12.1.5.14. C_F
12.1.5.15. PHI
12.1.5.16. PHI_W
12.1.5.17. EPS_F_MIN
12.1.5.18. EP_S_MAX(PHASE)
12.1.5.19. SEGREGATION_SLOPE_COEFFICIENT
12.1.5.20. V_EX
Table 12.39 Valid Values
0.0
Boyle-Massoudi stress is turned off.
12.1.5.21. MU_S0(PHASE)
  • kinetic theory calculations (granular_energy) are off, which
  • frictional/plastic calculations are off, which means zero
  • LAMBDA_S = -2/3 MU_S0
12.1.5.22. DIF_S0(PHASE)
12.1.5.23. EP_STAR
12.1.5.24. CLOSE_PACKED(PHASE)
Table 12.40 Valid Values
The phase forms a packed bed with void fraction EP_STAR.
The phase can exceed close pack conditions so that it maybe behave like a liquid.
12.1.5.25. JENKINS
Table 12.41 Valid Values
Use standard boundary conditions.
Use Jenkins small frictional boundary condition.
