This tutorial shows how to create a three dimensional fluidized bed simulation using the two-fluid model (TFM) and the discrete element model (DEM). The model setup is:
10 cm diameter x 40 cm |
20 x 60 x 20 |
0.25 m/s |
3.5.1. Create a new project¶
On the Model
drop-down menu.
3.5.3. Enter the geometry¶
Add Geometry
button ->Primitives
->cylinder
40/100
10/2/100
for the cylinder resolutionPress the autosize button to fit the domain extents to the geometry
0.1
meters. This will hang the stl file outside of the domain, allowing for a sharp and clean cut.Flip the normals by clicking the
button and selecting the
flip normals
filter
3.5.4. Enter the mesh¶
Background
sub-pane
20
60
for the y cell valueEnter
20
for the z cell value
Select the Regions
visualize the results.
Color
buttonEnter
in theTo Y
field (“inlet”)
field (“outlet”)
field (“walls”)Click the
Select facets
box. The region type should change from “box” to “STL”.
field (“slice”)Enter
in theFrom X
andTo X
fields
3.5.6. Create a solid¶
field (“glass beads”)Accept the radial distribution setting (Carnahan-Starling)
200e-6
2500
kg/m2 in theDensity
101325
Pa in thePressure (optional)
fieldSelect the region created previously for the bed Initial Condition (“bed” region) and click the
button.Select the solid (named previously as “glass beads”) sub-pane and enter a volume fraction of
0.4
in theVolume Fraction
Select region
Fluid
sub-pane, enter a velocity in theY-axial velocity
field of0.25
m/sOn the
Select region
On the Numerics
pane, Residuals
in theFluid Normalization
field.
checkboxSelect the
sub-paneSelect the “Background IC” region from the list to save all the cell data
*.vtu
files in theFilename base
fieldChange the
to0.01
secondsSelect the
Volume fraction
,Pressure
, andVelocity vector
checkboxes on theFluid
tabSelect the “Slice” region from the list to save all the cell data
*.vtu
fieldChange the
to0.01
secondsSelect the
Volume fraction
,Pressure
tab
Stop time
to1.0
secondsChange the
to1e-3
secondsChange the
to1e-2
seconds
3.5.12. Run the project¶
3.5.13. View results¶
3D view
Close the VTK window
Model
pane, change the solver toMFiX-DEM
Mesh
pane, coarsen the grid to 15, 45, and 15 cells in the in the x, y, and z direction, respectfully.
Solids
pane, change that particle diameter to5.0000e-03
to get a more reasonable particle count for tutorial purposes.On the
Solids
pane,DEM
sub-pane: - check theEnable automatic particle generation
- enter a value of15
in theSearch grid partitions
,KMAX
field.On the
Boundary Conditions
pane, change theinlet
Y-axial velocity
to0.6
m/sOn the
Boundary Conditions
pane, delete thewalls
boundary condition and re-add it to write the correct wall parameters for the DEM simulation.On the
Output
pane,VTK
sub-pane:Delete the
all
orBackground_IC
outputCreate a new output, change the
Output type
toParticle data
and select theBackground_IC
region.Change the write frequency to
0.01
Diameter
andTranslational Velocity
data
Run the simulation
