3.4. Three-dimensional single phase flow over a sphere¶
This tutorial shows how to create a three dimensional single phase flow over a sphere.
60 cm 20 cm x 20 cm |
30 x 10 x 10 |
1 m/s |
3.4.1. Create a new project¶
3.4.2. Select model parameters¶
On the Model pane:
DescriptionfieldSelect “Single Phase” in the
Solverdrop-down menu.
3.4.3. Enter the geometry¶
On the Geometry pane enter the domain extents:
60/100meters for the maximum x value20/100meters for the maximum y value20/100meters for the maximum z value
10/100for the center X position10/100for the center Y position10/100for the center Z position
5/100for the radius.
3.4.4. Enter the mesh¶
30for the x cell valueEnter
10for the y cell valueEnter
10for the z cell value
3.4.5. Create regions for initial and boundary condition specification¶
(all) button to create a region that encompasses the entire domain
namesuch as “sphere”Check the
Select facets (STL)checkbox to turn the region into a STL region. The facets of the sphere should now be selected.
Namefield (“slice”)Enter
zmax/2in both theFrom ZandTo Zfields to move the region to the center of the domain
3.4.6. Create Initial Conditions¶
Initial conditionspaneSelect the already populated “Background IC” from the region list. This will initialize the entire flow field with air.
3.4.7. Create Boundary Conditions¶
the sphere by:
Select regiondialog, select “No Slip Wall” from theBoundary typecombo-boxSelect the “sphere” region and click
Add a mass inflow boundary condition by:
Select regiondialog, select “Mass Inflow” from theBoundary typecombo-boxSelect the “inlet” region and click
OKOn the “Fluid” sub-pane, enter a velocity in the
X-axial velocityfield of1.0m/s
3.4.8. Select output options¶
VTKsub-paneSelect the “slice” region from the list to save cell data at a slice through the domain
Write intervalto “0.01” secondsSelect the
Pressure,Velocity vector,Velocity x-component,Velocity y-component, andVelocity z-componentcheckboxes on theFluidsub-sub-pane
3.4.9. Change run parameters¶
Change
Stop time stepto2.0secondsChange
Time stepto1e-2secondsChange
3.4.10. Run the project¶
Run Solverdialog, select the executableClick the
3.4.11. View results¶
