3.3. Two-dimensional fluidized bed, Discrete Element Model (DEM)¶
15 cm x 90 cm x 0.4 cm |
15 x 45 x 1 |
2700 kg/m2 |
42.0 m/s |
3.3.1. Create a new project¶
![create project](../_images/gui_new_project.png)
Model
drop-down menu.
![model parameters](../_images/gui_dem_2d_model.png)
3.3.3. Enter the geometry¶
0.15
0.90
meters for the maximum y valueEnter
0.004
![enter geometry](../_images/gui_dem_2d_geometry.png)
3.3.4. Enter the mesh¶
pane, Background
15
45
for the y cell valueEnter
for the z cell value
![enter mesh](../_images/gui_dem_2d_mesh.png)
On the Regions
field (“bed”)Change the
To Y
field to be “ymax/2”Click the
field (“inlet”)Enter
0.07
in theFrom X
field and0.08
in theTo X
field.Click the
field (“outlet”)
![create regions](../_images/gui_tfm_2d_region3.png)
3.3.6. Create a solid¶
pane, Materials
field (“solids”)Enter the particle diameter of
0.004
2700
kg/m2 in theDensity
![new boundary condition](../_images/gui_dem_2d_solids.png)
Solids
pane,DEM
sub-paneCheck the
checkbox, so that the bed Initial Condition, defined later, will be filled with solids
![new boundary condition](../_images/gui_dem_2d_solids2.png)
101325
Pa in thePressure (optional)
![new boundary condition](../_images/gui_tfm_2d_ics1.png)
button.
![new boundary condition](../_images/gui_tfm_2d_newic.png)
0.4
in theVolume Fraction
field. This will fill the bottom half of the domain with solids.Note the estimated number of particles and inventory (around 3,200 particles or 0.3 kg). When running DEM simulations on a single core machine, it is recommended to stay below 100,000 particles to get reasonable run times.
![new boundary condition](../_images/gui_dem_2d_ics2.png)
Select region
![new boundary condition](../_images/gui_tfm_2d_newbc1.png)
Y-axial velocity
field of “42” m/s
![new boundary condition](../_images/gui_dem_2d_bcs1.png)
Select region
![new boundary condition](../_images/gui_tfm_2d_newbc2.png)
3.3.9. Select output options¶
checkbox
![new boundary condition](../_images/gui_tfm_2d_output.png)
sub-paneSelect “Particle Data” from the ‘Output type’ drop-down menu.
to create the output
![new boundary condition](../_images/gui_dem_2d_newoutput.png)
*.vtu
files in theFilename base
field (“particles”)Change the
to0.01
secondsSelect the
Diameter
andTranslational Velocity
checkboxes
![new boundary condition](../_images/gui_dem_2d_output_vtk.png)
Change
Stop time
to1.0
secondsChange
to1e-2
secondsChange
to1e-2
seconds
3.3.11. Run the project¶
Run
Run
![new boundary condition](../_images/gui_run_dialog.png)
3.3.12. View results¶
3D view
![new boundary condition](../_images/gui_vtk_visible_dialog.png)
![vtk view](../_images/gui_dem_2d_vtk_view.png)
