3.7. DEM granular flow chutes¶
1.75 m x 0.94 m x 0.2 m |
20 x 20 x 10 |
12.5 mm (0.0125 m) |
3.7.1. Create a new project¶
On the Model
drop-down menu.Check the
Disable Fluid Solver
checkbox.
3.7.3. Enter the geometry¶
primitives
->cylinder
0.1
for the cylinder resolution
primitives
->cylinder
1.2
0.08
Slice the tube in half:
Center X
value to0.5
mChange the
Y Length
to1.2
m
Rotate the chute:
transform
)Enter a value of
0.8
in theTranslate X
fieldEnter a value of
0.6
in theTranslate Y
120
in theRotation Z
transform1
)Enter a value of
0.0
in theTranslate X
0.3
in theTranslate Y
70
in theRotation Z
Press the
Autosize
button to fit the domain extents to the geometry
3.7.4. Enter the mesh¶
Background
sub-pane
20
20
for the y cell valueEnter
for the z cell value
Select the Regions
pane.
3.7.6. Create a solid¶
field (“glass beads”)Enter the particle diameter of
1/80
2500
kg/m2 in theDensity
On the DEM
sub pane:
check the
checkbox and keep defaults values for all other settings.
pane leave the default initial condition.
Select region
glass beads
sub-pane:Enter a value of
0.1
in thevolume fraction
field.Enter a velocity in the
Y-axial velocity
field of-0.1
m/s
Select region
combo-boxSelect the “walls” region and click
3.7.9. Select output options¶
check boxSelect the
sub-paneSelect
Particle Data
in theOutput type
combo box.Select the “Background IC” region from the list to save all the cell data
*.vtp
files in theFilename base
fieldChange the
to0.1
secondsSelect the
Diameter
andTranslational Velocity
check boxes.
3.7.10. Run the project¶
3.7.11. View results¶
