12.1.15. Chemical Reactions
12.1.15.1. STIFF_CHEMISTRY
Flag to use stiff chemistry solver (Direct integration).
12.1.15.2. STIFF_CHEM_MAX_STEPS
12.1.15.3. STIFF_CHEM_ABS_TOL
12.1.15.4. STIFF_CHEM_REL_TOL
12.1.15.5. STIFF_CHEM_MIN_RATE
Stiff chemistry minimum fluid reaction rate. If all fluid reaction rates are below this threshold, a cell is said to be non-reactive and no ODE is set for this cell.
12.1.15.6. STIFF_CHEM_MIN_RATE_DPM
Stiff chemistry minimum DPM (Discrete phase model) reaction rate. If all DPM reaction
rates are below this threshold, a particle/parcel is said to be non-reactive and no ODE is set for this particle/parcel.
12.1.15.7. STIFF_CHEM_MIN_SPECIES
Stiff chemistry minimum species mass fraction. Reactions are switched off when reactants fall below this threshold.
12.1.15.8. USE_RRATES
12.1.15.9. SPECIES_NAME(PHASE)
  • \(0 \le Phase \le 10\)
12.1.15.10. NMAX(PHASE)
