12.1.8. Solids Phase
12.1.8.1. SOLIDS_MODEL(PHASE)
Table 12.57 Valid Values
TFM
Two-fluid model (continuum)
DEM
Discrete element model
CGP
Coarse-grained particle DEM
SQP
Superquadric particle DEM
GSP
Glued sphere particle DEM
PIC
Multiphase particle-in-cell
12.1.8.2. MMAX
Applies to Solids Model(s): TFM, DEM
Number of solids phases.
12.1.8.3. D_P0(PHASE)
12.1.8.4. RO_S0(PHASE)
12.1.8.5. X_S0(PHASE, SPECIES)
12.1.8.6. RO_XS0(PHASE, SPECIES)
12.1.8.7. INERT_SPECIES(PHASE)
12.1.8.8. DIL_INERT_X_VSD(PHASE)
12.1.8.9. DIL_FACTOR_VSD
12.1.8.10. K_S0(PHASE)
12.1.8.11. KS_MODEL(PHASE)
Table 12.58 Valid Values
CONST_EFF
USR
Bauer
Musser
12.1.8.12. C_PS0(PHASE)
12.1.8.13. MW_S(PHASE, SPECIES)
12.1.8.14. NMAX_S(PHASE)
12.1.8.15. SPECIES_S(PHASE, SPECIES)
12.1.8.16. SPECIES_ALIAS_S(PHASE, SPECIES)
12.1.8.17. CGP_STAT_WT(PHASE)
12.1.8.18. CGP_D_P0(PHASE)
12.1.8.19. SQP_A(PHASE)
12.1.8.20. SQP_B(PHASE)
12.1.8.21. SQP_C(PHASE)
12.1.8.22. SQP_M(PHASE)
12.1.8.23. SQP_N(PHASE)
12.1.8.24. SQP_Q1(PHASE)
12.1.8.25. SQP_Q2(PHASE)
12.1.8.26. SQP_Q3(PHASE)
12.1.8.27. SQP_Q4(PHASE)
12.1.8.28. SQP_CONTACT_EVOLUTION
12.1.8.29. SQP_INIT_CONTACT_EVOLUTION
12.1.8.30. GSP_Q1(PHASE)
Glued sphere particle quaternion q1.
12.1.8.31. GSP_Q2(PHASE)
Glued sphere particle quaternion q2.
12.1.8.32. GSP_Q3(PHASE)
Glued sphere particle quaternion q3.
12.1.8.33. GSP_Q4(PHASE)
Glued sphere particle quaternion q4.
12.1.8.34. INIT_THETA
Description for INIT_THETA XXX
12.1.8.35. NGLUEDPARTICLES
Number of glued sphere particles
