12.1.9. Initial Condition
Each initial condition (IC) is specified over a rectangular region (or pie-shaped for cylindrical coordinates) that corresponds to the scalar numerical grid. These are 3D regions: X_w X_e, Y_s Y_n, and Z_t Z_b. The region is defined by the constant coordinates of each of the six faces, which may be specified as the physical coordinates or the cell indices. The physical coordinates are easier to specify than the cell indices. If cell sizes are not small enough to resolve a region specified using physical coordinates, MFIX will indicate this problem with an error message.
12.1.9.1. IC_X_W(IC)
  • \(1 \le IC \le 500\)
12.1.9.2. IC_X_E(IC)
12.1.9.3. IC_Y_S(IC)
12.1.9.4. IC_Y_N(IC)
12.1.9.5. IC_Z_B(IC)
12.1.9.6. IC_Z_T(IC)
Z coordinate of the top face.
12.1.9.7. IC_I_W(IC)
12.1.9.8. IC_I_E(IC)
12.1.9.9. IC_J_S(IC)
12.1.9.10. IC_J_N(IC)
12.1.9.11. IC_K_B(IC)
12.1.9.12. IC_K_T(IC)
K index of the top-most wall.
12.1.9.13. IC_TYPE(IC)
12.1.9.14. IC_EP_G(IC)
12.1.9.15. IC_P_G(IC)
12.1.9.16. IC_P_STAR(IC)
12.1.9.17. IC_L_SCALE(IC)
12.1.9.18. IC_ROP_S(IC, PHASE)
12.1.9.19. IC_EP_S(IC, PHASE)
12.1.9.20. IC_PSD_TYPE(IC, PHASE)
Table 12.59 Valid Values
MONO
Uniform particle size.
NORMAL
LOG_NORMAL
CUSTOM
12.1.9.21. IC_PSD_MEAN_DP(IC, PHASE)
Initial mean value of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.9.22. IC_PSD_STDEV(IC, PHASE)
Initial standard deviation of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.9.23. IC_PSD_MAX_DP(IC, PHASE)
12.1.9.24. IC_PSD_MIN_DP(IC, PHASE)
12.1.9.25. IC_T_G(IC)
12.1.9.26. IC_T_S(IC, PHASE)
12.1.9.27. IC_THETA_M(IC, PHASE)
12.1.9.28. IC_GAMA_RG(IC)
12.1.9.29. IC_T_RG(IC)
12.1.9.30. IC_GAMA_RS(IC, PHASE)
12.1.9.31. IC_T_RS(IC, PHASE)
12.1.9.32. IC_U_G(IC)
Initial x-axial component of gas velocity in the IC region.
12.1.9.33. IC_U_S(IC, PHASE)
Initial x-axial component of solids-phase velocity in the IC region.
12.1.9.34. IC_V_G(IC)
Initial y-axial component of gas velocity in the IC region.
12.1.9.35. IC_V_S(IC, PHASE)
Initial y-axial component of solids-phase velocity in the IC region.
12.1.9.36. IC_W_G(IC)
Initial z-axial component of gas velocity in the IC region.
12.1.9.37. IC_W_S(IC, PHASE)
Initial z-axial component of solids-phase velocity in the IC region.
12.1.9.38. IC_X_G(IC, SPECIES)
  • \(1 \le Species \le 100\)
12.1.9.39. IC_X_S(IC, PHASE, SPECIES)
12.1.9.40. IC_SCALAR(IC, SCALAR EQ.)
12.1.9.41. IC_K_TURB_G(IC)
12.1.9.42. IC_E_TURB_G(IC)
12.1.9.43. IC_DES_LATTICE(IC, PHASE)
Type of initial lattice distribution (simple cubic or hexagonal)
to the entire IC region.
Table 12.60 Valid Values
HEXA
Particles are distributed on a hexagonal close-packed lattice.
CUBIC
Particles are distributed on a cubical lattice.
12.1.9.44. IC_DES_SPACING(IC, PHASE)
Spacing between particle within initial lattice distribution
(expressed as a fraction of particle diameter) to the entire IC region.
12.1.9.45. IC_DES_SPACE_FACTOR_X(IC, PHASE)
12.1.9.46. IC_DES_SPACE_FACTOR_Y(IC, PHASE)
12.1.9.47. IC_DES_SPACE_FACTOR_Z(IC, PHASE)
12.1.9.48. IC_DES_RAND(IC, PHASE)
12.1.9.49. IC_DES_RAND_FACTOR_X(IC, PHASE)
12.1.9.50. IC_DES_RAND_FACTOR_Y(IC, PHASE)
12.1.9.51. IC_DES_RAND_FACTOR_Z(IC, PHASE)
12.1.9.52. IC_DES_SM(IC, PHASE)
12.1.9.53. IC_DES_NP(IC, PHASE)
12.1.9.54. IC_DES_ABORT_ON_FAILED_SEEDING(IC, PHASE)
Flag to abort if unsuccessful seeding occurs.
12.1.9.55. IC_DES_CHECK_STL_OVERLAP(IC, PHASE)
Check for particle overlap with SL geometry
12.1.9.56. IC_PIC_CONST_STATWT(IC, PHASE)
Flag to specify the initial constant statistical
weight for computational particles/parcels. Actual number of parcels will be automatically computed.
12.1.9.57. IC_SQP_RANDOM_Q(IC, PHASE)
12.1.9.58. IC_GSP_RANDOM_Q(IC, PHASE)
Initialize GSP with random orientation (quaternion) in the IC region.
