12.1.13. Output Control
12.1.13.1. RES_DT
required
12.1.13.2. RES_BACKUP_DT
12.1.13.3. RES_BACKUPS
12.1.13.4. SPX_DT(SP VALUE)
  • \(1 \le SP Value \le 11\)
  • SP1: void fraction (EP_G)
12.1.13.5. NRR
12.1.13.6. OUT_DT
12.1.13.7. REPORT_SOLID_INVENTORY
required
12.1.13.8. REPORT_SOLID_INVENTORY_DT
required
12.1.13.9. BREAKDOWN_SOLID_INVENTORY_BY_PHASE
required
12.1.13.10. NLOG
12.1.13.11. FULL_LOG
12.1.13.12. TSS_HDR
12.1.13.13. RESID_STRING(RESIDUAL INDEX)
Table 12.65 Valid Values
P0
Gas pressure
PM
Solids phase M pressure
R0
Gas density
RM
Solids phase M density
U0
Gas phase U-velocity
V0
Gas phase V-velocity
W0
Gas phase W-velocity
UM
Solids phase M U-velocity
VM
Solids phase M V-velocity
WM
Solids phase M W-velocity
T0
Gas temperature
TM
Solids phase M temperature
GM
X0NN
XMNN
K0
K-Epsilon model residuals
12.1.13.14. GROUP_RESID
12.1.13.15. REPORT_NEG_DENSITY
Table 12.66 Valid Values
Log negative density errors.
12.1.13.16. REPORT_NEG_SPECIFICHEAT
Table 12.67 Valid Values
12.1.13.17. REPORT_MASS_BALANCE_DT
12.1.13.18. PHIP_OUT_JJ
12.1.13.19. BDIST_IO
12.1.13.20. BSTART_WITH_ONE_RES
12.1.13.21. MONITOR_X_W(MONITOR)
12.1.13.22. MONITOR_X_E(MONITOR)
12.1.13.23. MONITOR_Y_S(MONITOR)
12.1.13.24. MONITOR_Y_N(MONITOR)
12.1.13.25. MONITOR_Z_B(MONITOR)
12.1.13.26. MONITOR_Z_T(MONITOR)
12.1.13.27. MONITOR_NAME(MONITOR)
12.1.13.28. MONITOR_DT(MONITOR)
12.1.13.29. MONITOR_TAVG_DT(MONITOR)
12.1.13.30. MONITOR_TAVG_START(MONITOR)
12.1.13.31. MONITOR_TAVG_RESET_DT(MONITOR)
12.1.13.32. MONITOR_TAVG_SS_TOL(MONITOR)
12.1.13.33. MONITOR_TAVG_SS_SPAN(MONITOR)
12.1.13.34. MONITOR_TYPE(MONITOR)
Data monitor type.
Table 12.68 Valid Values
Point value
Sum over region
Minimum over region
3
Maximum over region
4
5
6
7
Flow rate across surface
8
Mass flow rate across surface
11
Volume integral
12
Volume-weighted average
13
Mass-weighted volume integral
14
Mass-weighted volume average
101
Sum over region
102
Minimum over region
103
Maximum over region
104
105
106
107
108
109
110
12.1.13.35. MONITOR_EP_G(MONITOR)
12.1.13.36. MONITOR_RO_G(MONITOR)
12.1.13.37. MONITOR_P_G(MONITOR)
12.1.13.38. MONITOR_U_G(MONITOR)
12.1.13.39. MONITOR_V_G(MONITOR)
12.1.13.40. MONITOR_W_G(MONITOR)
12.1.13.41. MONITOR_T_G(MONITOR)
12.1.13.42. MONITOR_MW_MIX_G(MONITOR)
12.1.13.43. MONITOR_X_G(MONITOR, SPECIES)
  • \(1 \le Species \le 100\)
12.1.13.44. MONITOR_Y_G(MONITOR, SPECIES)
12.1.13.45. MONITOR_K_TURB_G(MONITOR)
12.1.13.46. MONITOR_E_TURB_G(MONITOR)
12.1.13.47. MONITOR_EP_S(MONITOR, PHASE)
12.1.13.48. MONITOR_U_S(MONITOR, PHASE)
12.1.13.49. MONITOR_V_S(MONITOR, PHASE)
12.1.13.50. MONITOR_W_S(MONITOR, PHASE)
12.1.13.51. MONITOR_ROP_S(MONITOR, PHASE)
12.1.13.52. MONITOR_RO_S(MONITOR, PHASE)
12.1.13.53. MONITOR_P_STAR(MONITOR)
12.1.13.54. MONITOR_P_S(MONITOR, PHASE)
12.1.13.55. MONITOR_T_S(MONITOR, PHASE)
12.1.13.56. MONITOR_X_S(MONITOR, PHASE, SPECIES)
12.1.13.57. MONITOR_THETA_M(MONITOR, PHASE)
12.1.13.58. MONITOR_SCALAR(MONITOR, SCALAR EQ.)
Write scalar in region.
12.1.13.59. MONITOR_RRATE(MONITOR, RATE)
  • \(1 \le RATE \le NRRMAX\)
12.1.13.60. MONITOR_FLUID_RRATE(MONITOR, RATE)
Write fluid reaction rates in region. This keyword replaces
12.1.13.61. MONITOR_DES_RRATE(MONITOR, RATE)
Write particle/parcel reaction rates in region. Particle/parcel data
is converted to cell data.
12.1.13.62. MONITOR_PART_PHASE(MONITOR, PHASE)
12.1.13.63. MONITOR_RADIUS(MONITOR)
12.1.13.64. MONITOR_PMASS(MONITOR)
12.1.13.65. MONITOR_PCOUNT(MONITOR)
12.1.13.66. MONITOR_PVOL(MONITOR)
12.1.13.67. MONITOR_RO_P(MONITOR)
12.1.13.68. MONITOR_VEL_X(MONITOR)
12.1.13.69. MONITOR_VEL_Y(MONITOR)
12.1.13.70. MONITOR_VEL_Z(MONITOR)
12.1.13.71. MONITOR_ROT_X(MONITOR)
12.1.13.72. MONITOR_ROT_Y(MONITOR)
12.1.13.73. MONITOR_ROT_Z(MONITOR)
12.1.13.74. MONITOR_T_P(MONITOR)
12.1.13.75. MONITOR_X_P(MONITOR, SPECIES)
12.1.13.76. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)
  • \(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
12.1.13.77. MONITOR_PART_RRATE(MONITOR, RATE)
  • \(1 \le rate \le 100\)
12.1.13.78. MONITOR_PART_RESIDENCE_TIME(MONITOR)
12.1.13.79. WRITE_VTK_FILES
Table 12.69 Valid Values
12.1.13.80. TIME_DEPENDENT_FILENAME
Table 12.70 Valid Values
12.1.13.81. VTK_DT(VTK)
  • \(1 \le VTK \le 100\)
12.1.13.82. VTK_T_START(VTK)
12.1.13.83. VTK_T_END(VTK)
12.1.13.84. VTK_DBG_FILE(VTK)
When VTK_DBG_FILE is .TRUE., the VTK region file is only written
12.1.13.85. VTK_VAR(IDX)
  • \(1 \le IDX \le 20\)
Table 12.71 Valid Values
Void fraction (EP_g)
3
Gas velocity (U_g, V_g, W_g)
4
5
Solids density (ROP_s)
6
7
8
Scalar
Reaction rates
11
K and Epsilon
12
100
Grid Partition
101
Boundary Condition ID
102
Distance to wall
103
DEM facet count
104
DEM Neighboring facets
999
Cell IJK index
1000
Cut face normal vector
12.1.13.86. VTK_X_W(VTK)
12.1.13.87. VTK_X_E(VTK)
12.1.13.88. VTK_Y_S(VTK)
12.1.13.89. VTK_Y_N(VTK)
12.1.13.90. VTK_Z_B(VTK)
12.1.13.91. VTK_Z_T(VTK)
12.1.13.92. VTK_FILEBASE(VTK)
12.1.13.93. VTK_DATA(VTK)
Table 12.72 Valid Values
C
Cell data (VTU file).
P
Particle data (VTP file).
G
Geometry data (STL file).
F
Force chain data (VTP file).
N
Glued (non-spherical) particle data (VTP file).
12.1.13.94. VTK_GEO(VTK, GEO)
12.1.13.95. VTK_SELECT_MODE(VTK)
Table 12.73 Valid Values
C
P
I
12.1.13.96. VTK_NXS(VTK)
12.1.13.97. VTK_NYS(VTK)
12.1.13.98. VTK_NZS(VTK)
12.1.13.99. VTK_SLICE_TOL(VTK)
12.1.13.100. VTK_EP_G(VTK)
12.1.13.101. VTK_RO_G(VTK)
12.1.13.102. VTK_P_G(VTK)
12.1.13.103. VTK_VEL_G(VTK)
12.1.13.104. VTK_U_G(VTK)
12.1.13.105. VTK_V_G(VTK)
12.1.13.106. VTK_W_G(VTK)
12.1.13.107. VTK_P_STAR(VTK)
12.1.13.108. VTK_P_S(VTK, PHASE)
12.1.13.109. VTK_VEL_S(VTK, PHASE)
12.1.13.110. VTK_U_S(VTK, PHASE)
12.1.13.111. VTK_V_S(VTK, PHASE)
12.1.13.112. VTK_W_S(VTK, PHASE)
12.1.13.113. VTK_ROP_S(VTK, PHASE)
12.1.13.114. VTK_RO_S(VTK, PHASE)
12.1.13.115. VTK_EP_S(VTK, PHASE)
12.1.13.116. VTK_T_G(VTK)
12.1.13.117. VTK_T_S(VTK, PHASE)
12.1.13.118. VTK_C_PG(VTK)
12.1.13.119. VTK_C_PS(VTK, PHASE)
12.1.13.120. VTK_MU_G(VTK)
12.1.13.121. VTK_MW_MIX_G(VTK)
12.1.13.122. VTK_X_G(VTK, GAS SPECIES)
12.1.13.123. VTK_Y_G(VTK, GAS SPECIES)
12.1.13.124. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)
12.1.13.125. VTK_THETA_M(VTK, PHASE)
12.1.13.126. VTK_SCALAR(VTK, SCALAR)
12.1.13.127. VTK_RRATE(VTK, RATE)
  • \(1 \le rate \le nRRmax\)
12.1.13.128. VTK_RRATE_LABEL(VTK, RATE)
12.1.13.129. VTK_FLUID_RRATE(VTK, RATE)
12.1.13.130. VTK_DES_RRATE(VTK, RATE)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is
accumulated in fluid cells.
12.1.13.131. VTK_K_TURB_G(VTK)
12.1.13.132. VTK_E_TURB_G(VTK)
12.1.13.133. VTK_VORTICITY(VTK)
12.1.13.134. VTK_LAMBDA_2(VTK)
Write lambda_2 in region.
12.1.13.135. VTK_PARTITION(VTK)
12.1.13.136. VTK_BC_ID(VTK)
12.1.13.137. VTK_DWALL(VTK)
12.1.13.138. VTK_FACET_COUNT_DES(VTK)
12.1.13.139. VTK_NB_FACET_DES(VTK)
12.1.13.140. VTK_IJK(VTK)
12.1.13.141. VTK_SCALAR_CC(VTK)
12.1.13.142. VTK_NORMAL(VTK)
12.1.13.143. VTK_DEBUG(VTK, IDX)
  • \(1 \le IDX \le 15\)
12.1.13.144. VTK_PART_DIAMETER(VTK)
12.1.13.145. VTK_PART_PHYSICAL_DIAMETER(VTK)
12.1.13.146. VTK_PART_CGP_STAT_WT(VTK)
12.1.13.147. VTK_PART_VEL(VTK)
12.1.13.148. VTK_PART_ANGULAR_VEL(VTK)
12.1.13.149. VTK_PART_ORIENTATION(VTK)
12.1.13.150. VTK_PART_USR_VAR(VTK, USR_VAR)
12.1.13.151. VTK_PART_TEMP(VTK)
12.1.13.152. VTK_PART_C_PS(VTK)
12.1.13.153. VTK_PART_X_S(VTK, DES_SPECIES)
12.1.13.154. VTK_PART_RRATE(VTK, RATE)
12.1.13.155. VTK_PART_DENSITY(VTK)
12.1.13.156. VTK_PART_MASS(VTK)
12.1.13.157. VTK_PART_VOLUME(VTK)
12.1.13.158. VTK_PART_DRAG_COEFF(VTK)
12.1.13.159. VTK_PART_COHESION(VTK)
12.1.13.160. VTK_PART_RANK(VTK)
12.1.13.161. VTK_PART_ID(VTK)
Write particle ID in region.
12.1.13.162. VTK_PART_RESIDENCE_TIME(VTK)
12.1.13.163. VTK_PART_PHASE_ID(VTK)
12.1.13.164. VTK_PART_PHASE(VTK, PHASE)
12.1.13.165. VTK_FCMAX_ONLY(VTK)
12.1.13.166. VTK_PART_COL_FORCE(VTK)
12.1.13.167. VTK_CUTCELL_ONLY(VTK)
12.1.13.168. VTK_PART_GLUEID(VTK)
12.1.13.169. VTK_PART_GLUEDIAMETER(VTK)
12.1.13.170. VTK_PART_GLUEBOUNDING(VTK)
12.1.13.171. VTK_PART_GLUEMASS(VTK)
12.1.13.172. VTK_PART_GLUEVOLUME(VTK)
12.1.13.173. VTK_PART_GLUEQUAT(VTK)
12.1.13.174. FRAME(VTK)
12.1.13.175. VTU_DIR
Directory where VTK files are stored. By default,
12.1.13.176. DES_REPORT_MASS_INTERP
12.1.13.178. VTP_DIR
12.1.13.179. DES_OUTPUT_TYPE
Table 12.74 Valid Values
PARAVIEW
TECPLOT
12.1.13.180. DEBUG_DES
12.1.13.181. FOCUS_PARTICLE
12.1.13.182. WRITE_PART_OUT
12.1.13.183. PART_OUT_ZERO_VEL
12.1.13.184. PART_OUT_X_MIN
12.1.13.185. PART_OUT_X_MAX
12.1.13.186. PART_OUT_X_EXCLUDE
12.1.13.187. PART_OUT_Y_MIN
12.1.13.188. PART_OUT_Y_MAX
12.1.13.189. PART_OUT_Y_EXCLUDE
12.1.13.190. PART_OUT_Z_MIN
12.1.13.191. PART_OUT_Z_MAX
12.1.13.192. PART_OUT_Z_EXCLUDE
12.1.13.193. PART_OUT_PHASE(PHASE)
12.1.13.194. PART_OUT_DIAMETER_MIN
12.1.13.195. PART_OUT_DIAMETER_MAX
12.1.13.196. PART_OUT_DIAMETER_EXCLUDE
12.1.13.197. PART_OUT_DENSITY_MIN
12.1.13.198. PART_OUT_DENSITY_MAX
12.1.13.199. PART_OUT_DENSITY_EXCLUDE
12.1.13.200. PART_OUT_U_MIN
12.1.13.201. PART_OUT_U_MAX
12.1.13.202. PART_OUT_U_EXCLUDE
12.1.13.203. PART_OUT_V_MIN
12.1.13.204. PART_OUT_V_MAX
12.1.13.205. PART_OUT_V_EXCLUDE
12.1.13.206. PART_OUT_W_MIN
12.1.13.207. PART_OUT_W_MAX
12.1.13.208. PART_OUT_W_EXCLUDE
12.1.13.209. PART_OUT_TEMP_MIN
12.1.13.210. PART_OUT_TEMP_MAX
12.1.13.211. PART_OUT_TEMP_EXCLUDE
12.1.13.212. PART_OUT_X_S_MIN(INDEX)
  • \(1 \le Index \le 100\)
12.1.13.213. PART_OUT_X_S_MAX(INDEX)
12.1.13.214. PART_OUT_X_S_EXCLUDE(INDEX)
12.1.13.215. PART_OUT_USR_VAR_MIN(INDEX)
12.1.13.216. PART_OUT_USR_VAR_MAX(INDEX)
12.1.13.217. PART_OUT_USR_VAR_EXCLUDE(INDEX)
12.1.13.218. PART_IN_X_MIN
12.1.13.219. PART_IN_X_MAX
12.1.13.220. PART_IN_X_EXCLUDE
12.1.13.221. PART_IN_Y_MIN
12.1.13.222. PART_IN_Y_MAX
12.1.13.223. PART_IN_Y_EXCLUDE
12.1.13.224. PART_IN_Z_MIN
12.1.13.225. PART_IN_Z_MAX
12.1.13.226. PART_IN_Z_EXCLUDE
12.1.13.227. PART_IN_PHASE(PHASE)
12.1.13.228. PART_IN_DIAMETER_MIN
12.1.13.229. PART_IN_DIAMETER_MAX
12.1.13.230. PART_IN_DIAMETER_EXCLUDE
12.1.13.231. PART_IN_DENSITY_MIN
12.1.13.232. PART_IN_DENSITY_MAX
12.1.13.233. PART_IN_DENSITY_EXCLUDE
12.1.13.234. PART_IN_U_MIN
12.1.13.235. PART_IN_U_MAX
12.1.13.236. PART_IN_U_EXCLUDE
12.1.13.237. PART_IN_V_MIN
12.1.13.238. PART_IN_V_MAX
12.1.13.239. PART_IN_V_EXCLUDE
12.1.13.240. PART_IN_W_MIN
12.1.13.241. PART_IN_W_MAX
12.1.13.242. PART_IN_W_EXCLUDE
12.1.13.243. PART_IN_TEMP_MIN
12.1.13.244. PART_IN_TEMP_MAX
12.1.13.245. PART_IN_TEMP_EXCLUDE
12.1.13.246. PART_IN_X_S_MIN(INDEX)
12.1.13.247. PART_IN_X_S_MAX(INDEX)
12.1.13.248. PART_IN_X_S_EXCLUDE(INDEX)
12.1.13.249. PART_IN_USR_VAR_MIN(INDEX)
12.1.13.250. PART_IN_USR_VAR_MAX(INDEX)
12.1.13.251. PART_IN_USR_VAR_EXCLUDE(INDEX)
