12.1.7. Gas Phase
12.1.7.1. RO_G0
12.1.7.2. MU_G_MODEL
Gas viscosity model (default is Sutherland’s law).
Table 12.56 Valid Values
CONSTANT
Constant viscosity
SUTHERLAND
Sutherland’s law
HERSCHEL-BULKLEY
Herschel-Bulkley (non-Newtonian) model
UDF
User-defined function
12.1.7.3. MU_G0
Specified constant gas viscosity [Pa.s in SI].
12.1.7.4. SL_MUREF
Reference gas viscosity [Pa.s in SI] in the Sutherland’s law.
12.1.7.5. SL_TREF
Reference temperature [K] in the Sutherland’s law.
12.1.7.6. SL_S
Sutherland constant [K] in the Sutherland’s law.
12.1.7.7. HB_TAU0
Bingham yield stress [Pa] in Herschel-Bulkley viscosity law.
12.1.7.8. HB_K0
Consistency factor [Pa.s^n] in Herschel-Bulkley viscosity law.
12.1.7.9. HB_N
  • Power law index (dimensionless) in Herschel-Bulkley viscosity law.
  • 0 < HB_n < 1 : Shear thinning fluid
  • HB_n = 1 : Bingham fluid
  • HB_n > 1 : Shear thickening fluid
12.1.7.10. HB_GAMA_C
Strain rate cutoff [1/s] in Herschel-Bulkley viscosity law.
12.1.7.11. K_G0
12.1.7.12. C_PG0
12.1.7.13. DIF_G0
12.1.7.14. MW_AVG
12.1.7.15. MW_G(SPECIES)
  • \(1 \le Species \le 100\)
12.1.7.16. NMAX_G
12.1.7.17. SPECIES_G(SPECIES)
12.1.7.18. SPECIES_ALIAS_G(SPECIES)
