12.1.17. Parallelization Control¶
computational grid. The preconditioners are chosen with the keyword LEQ_PC.
NODESI * NODESJ * NODESK must be the same as the number of processors
specified using mpirun (or equivalent command). Otherwise the code will
return with an error.
12.1.17.1. NODESI¶
Number of grid blocks in x-direction.
12.1.17.2. NODESJ¶
Number of grid blocks in y-direction.
12.1.17.3. NODESK¶
Number of grid blocks in z-direction.
12.1.17.4. DLB_NODESI(LAYOUT)¶
\(1 \le Layout \le 100\)
12.1.17.5. DLB_NODESJ(LAYOUT)¶
12.1.17.6. DLB_NODESK(LAYOUT)¶
12.1.17.7. SOLVER_STATISTICS¶
Print out additional statistics for parallel runs
12.1.17.8. DEBUG_RESID¶
Group residuals to reduce global collectives.
12.1.17.9. ENABLE_DMP_LOG¶
All ranks write error messages.
12.1.17.10. DBGPRN_LAYOUT¶
Print the index layout for debugging.
