3.11. Hydrogen oxidation in a batch reactor using CHEMKIN mechanism¶
This tutorial shows how to import thermodynamic information of species and kinetic mechanism from CHEMKIN into MFiX. A batch reactor in a single cell is simulated in this tutorial. The mechanism for the oxidiation of hydrogen from Conaire et al. [1] is applied.
3.11.1. Read the project into MFiX¶
The basic model has been set up in the input file, “hydrogen_oxidation.mfx”.
On the main menu select
Open project.Open the project by browsing to the tutorial directory
tutorial/chemkin/hydrogen_oxidation.
The main purpose of this tutorial is to show how to use CHEMKIN mechanism in MFiX. For more details about the model setup, please refer to other tutorials.
3.11.2. Generate mesh¶
On the Mesher pane:
Generateto generate the meshClikc
Acceptto accept the mesh
3.11.3. Import species for fluid phase¶
On the Fluid pane:
+underSpecies. This will open the Fluid species popup window.
Load from file (CHEMKIN format)inSourceof the popup window
Choose file, choose “thermodynamicInfo.txt” in the popup window, and clickOpen.
After importing the file, the species defined in the file will show in the window.
Select all the species (click on first species “AR” and drag down) and click
import from databaseto import all species. ClickDone.
Users have the flexibility to select the required species for their case from the provided list. If a species is not defined in the CHEMKIN file, users can import it from the built-in Burcat database or an external Burcat file as well.
For reacting cases, constant specific heat capacity is not allowed. Change it to “Mixture” in “Properties”.
3.11.4. Create Initial and Boundary conditions¶
On the Initial conditions pane, set the following conditions as the initial conditions.
Initial Value |
Volume Fraction |
1.0 |
Temperature |
800 K |
Pressure |
101325 Ps |
U-Velocity |
0.0 m/s |
V-Velocity |
0.0 m/s |
W-Velocity |
0.0 m/s |
Composition |
H2: 0.1, O2: 0.8, N2: 0.1, OH:0.0 |
On the Boundary conditions pane, No-Slip and adiabatic walls have been setup.
3.11.5. Import kinetic mechanism¶
On the Chemistry pane, Options sub-pane:
Check the
Enable Arrhenius model for fluid phase reactionscheckboxChange the
Minimum mass fraction for reactionsforFluid reactionsto 0 to consider all species with mass fraction larger than 0 in the reactionsCheck the
Enable stiff chemistry solvercheckboxChange the
Absolute tolerance,Relative toleranceandMinimum reaction ratein stiff solver to be 1e-09, 1e-08 and 1e-20.
Users can change the minimum mass fraction for reactions and the parameters for stiff solver based on the accuracy requirement of their cases.
On the Chemistry pane, Reactions sub-pane:
Load reaction definitions from text fileand selectChemkin formatSelect the mechanism file “chemkin_mechanism.CKI” in the popup window. Click
Open.
Then all the reactions with all the information will be imported
3.11.6. Setup output, monitor and run parameters¶
The output, monitor and run parameters have been setup. Users can modify them based on their own requirement.
3.11.7. Run the project¶
Runbutton to start the simulation
This tutorial simulates the oxidation of H2 in a batch reactor. Users should expect to see consumption of H2 and O2 and a temperature increase from the exothermic reaction.
