3.10. Procedural geometry¶
3.10.1. Create a new project¶
3.10.2. Create the geometry¶
First, create a cylinder:
Go to the Geometry pane and click the button to add geometry:
Radius =
0.05m, Height =0.225m, Resolution =20Start angle=
0deg, end angle =360deg, resolution =32Check the
Bottom capandTop capcheck boxes and set the resolution to5for both caps.
Next, create a bend:
Go to the Geometry pane:
Choose
Procedural > Bendas the geometry input (named “bend”).Enter the bend’s parameters:
Front section: Radius =
0.02m, Length =0.05m, Resolution =10Back section: Radius =
0.05m, Length =0.25m, Resolution =20Bend section: Major radius =
0.075m, Minor radius =0.02m, Start angle=0deg, end angle =90deg, resolution =16Circumference: Start angle=
0deg, end angle =360deg, resolution =16Check the
Bottom capandTop capcheck boxes and set the resolution to3for both caps. Leave Offset =0
Next, create another bend:
Choose
Procedural > Bendas the geometry input (namedbend1).Enter the bend’s parameters:
0.02m, Length =0.1m, Resolution =10Back section: Radius =
0.02m, Length =0.1m, Resolution =10Bend section: Major radius =
0.05m, Minor radius =0.02m, Start angle=0deg, end angle =90deg, resolution =10Circumference: Start angle=
edges, opacity to 1.0, check theShow normalsbox, set theScaleto 0.01, setcountto 10,000 (to show all normals).
union1geometry,Add a filter:
flip normals. Now the vectors point towards the fluid region. The tips of the arrows are not visible, but we can see the origin (shown as a dot at the center of each face).
In
Domain extent, enter the following:X-direction: Min =
-0.055m, Max =0.055m.Y-direction: Min =
0.01m, Max =0.35m.Z-direction: Min =
-0.1m, Max =0.18m.
Go to the Regions pane:
There is already a
Backgroundthat is predefined in the Blank template. We can ignore it for now.Click the
Mass inflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“top inlet”).
Mass inflowin the Boundary type drop down menu.Enter a name for the region in the Name field (“bottom inlet”).
Pressure outflowin theBoundary typedrop down menu.Enter a name for the region in the Name field (“outlet”).
Namefield (“wall”).Change the region color to green.
Select facets (STL)andflip_normals, useallfor the selection method. You should see that there are 4003 facets selected.
Leave the
Boundary typeasNone.Enter a name for the region in the
Namefield (“init bed”).Change the region color to black.
Set the Y-extent form
yminto0.15m.
3.10.5. Setup the mesh¶
15for the x cell value.Enter
35for the y cell value.Enter
30for the z cell value.
0.0deg. (The geometry unions have created elongated triangles we need to keep).Click
Generate.Look at the console output to verify the mesh generation completed successfully.
Color bytobc_id, - setStyletoedgesand opacity to1.0.The Boundary_Mesh should look like a closed surface with colors matching the boundary conditions regions.
After inspection, the mesh is deemed acceptable and we can move to setting up the simulation (Solver mode). Click Accept. This will unlock the Modeler tab.
3.10.6. Model settings¶
3.10.7. Regions settings¶
3.10.8. Fluid settings¶
Change Density to
3.10.9. Solids settings¶
2700kg/m3 in theDensityfield.Select the
Enable automatic particle generationcheckbox.Keep all other settings at their default values.
3.10.10. Initial conditions settings¶
3.10.11. Boundary conditions settings¶
top inletregion. In theSolids 1tab, enter0.2for the volume fraction and-0.2for the Y-axial velocity.Select the
bottom inletregion. Stay on theFluidtab, enter4.0for the Y-axial velocity.The outlet Boundary conditions is already set to atmospheric pressure. No changes are needed.
The Wall Boundary conditions is already set to No-slip wall. No changes are needed.
3.10.12. Numerics settings¶
On the Numerics pane:
0.0and the fluid pressure correction scale factor to1.0On the Preconditioner tab, set the preconditioner to
Nonefor all equations.
3.10.13. Output settings¶
Basicsub-pane, check theWrite VTK output files (VTU/VTP)checkbox.Select the
VTKsub-pane.Select “Particle Data” from the ‘Output type’ drop-down menu.
Select the “Background” region from the list to save all the particle data.
OKto create the output.Enter a base name for the
3.10.14. Run settings¶
Set
Stop timeto1.0.Set
Time stepto0.001.Set
3.10.15. Run the simulation¶
3.10.16. View results¶
next to the Model tab.
