usr_rates.f
2 ! !
3 ! Module name: USR_RATES !
4 ! !
5 ! Purpose: Hook for user defined reaction rates. !
6 ! !
7 ! Author: J.Musser Date: 10-Oct-12 !
8 ! !
9 ! Comments: Write reaction rates in units of moles/sec.cm^3 (cgs) or !
10 ! kmoles/sec.m^3 (SI). Units should match those specified in the data !
11 ! file.
12 ! !
13 ! Example reaction: Methane combustion !
14 ! !
15 ! mfix.dat input: !
16 !``````````````````````````````````````````````````````````````````````!
17 ! @(RXNS) !
18 ! CH4_Comb { chem_eq = "CH4 + 2.0*O2 --> CO2 + 2.0*H2O" } !
19 ! @(END) !
20 !``````````````````````````````````````````````````````````````````````!
21 ! !
22 ! usr_rates.f input: !
23 !``````````````````````````````````````````````````````````````````````!
24 ! c_O2 = (RO_g(IJK)*X_g(IJK,O2)/MW_g(O2)) !
25 ! c_CH4 = (RO_g(IJK)*X_g(IJK,CH4)/MW_g(CH4)) !
26 ! RATES(CH4_Comb) = 2.0d5 * EP_g(IJK) * c_O2 * c_CH4 !
27 !``````````````````````````````````````````````````````````````````````!
28 ! * Species alias and reaction names given in the data file can be !
29 ! used in reference to the reaction index in RATES and a species !
30 ! index in gas/solids phase variables. !
31 ! !
32 ! * Additional information is provided in section 5.11 of the code !
33 ! Readme. !
34 ! !
35 !^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^!
36  SUBROUTINE usr_rates(IJK, RATES)
37
38  USE param
39  USE param1
40  USE parallel
41  USE fldvar
42  USE rxns
43  USE energy
44  USE geometry
45  USE run
46  USE indices
47  USE physprop
48  USE constant
49  USE funits
50  USE compar
51  USE sendrecv
52  USE toleranc
53  USE usr
54  USE fun_avg
55
56  IMPLICIT NONE
57
58  INTEGER, INTENT(IN) :: IJK
59
60  DOUBLE PRECISION, DIMENSION(NO_OF_RXNS), INTENT(OUT) :: RATES
61
62  include 'species.inc'
63
64 ! Reaction specific variables:
65 !`````````````````````````````````````````````````````````````````````//
66
67 ! Reaction rates:
68 !`````````````````````````````````````````````````````````````````````//
69 ! Include reaction rates here. Reaction rates should be stored in the
70 ! variable RATES. The reaction name given in the data file can be used
71 ! to store the rate in the appropriate array location. Additional
72 ! input format parameters are given in Section 4.11 of the code Readme.
73
74  rates(:) = zero
75
76  RETURN
77
78  END SUBROUTINE usr_rates
Definition: rxns_mod.f:1
subroutine usr_rates(IJK, RATES)
Definition: usr_rates.f:37
Definition: param_mod.f:2
Definition: usr_mod.f:1
