3.5. Three Dimensional Fluidized Bed¶
This tutorial shows how to create a three dimensional fluidized bed simulation using the two fluid model and the discrete element model (DEM). The model setup is:
10 cm diameter x 40 cm |
20 x 60 x 20 |
0.25 m/s |
3.5.1. Create a new project¶
fig_new_project
): On the main menu, selectNew project
(fig_model_param
): On the Model
drop-down menu.
3.5.3. Enter the geometry¶
Add Geometry
button ->Primitives
->cylinder
40/100
10/2/100
for the cylinder resolutionPress the autosize button to fit the domain extents to the geometry
0.1
meters. This will hang the stl file outside of the domain, allowing for a sharp and clean cut.Flip the normals by clicking the
button and selecting the
flip normals
filter
3.5.4. Enter the mesh¶
Background
sub-pane
20
60
for the y cell valueEnter
20
for the z cell value
Select the Regions
visualize the results.
click the
button to create a new region to be used for the bed initial condition.
Color
buttonEnter
in theTo Y
button to create a new region to be used by the gas inlet boundary condition.
field (“inlet”)
button to create a new region to be used by the pressure outlet boundary condition.
field (“outlet”)
button to create a new region to be used to select the walls.
field (“walls”)Click the
Select facets
box. The region type should change from “box” to “STL”.
button to create a new region to be used to save a slice of cells at the center of the domain.
field (“slice”)Enter
in theFrom X
andTo X
fields
3.5.6. Create a solid¶
button to create a new solid
field (“glass beads”)Accept the radial distribution setting (Carnahan-Starling)
200e-6
2500
kg/m2 in theDensity
101325
Pa in thePressure (optional)
fieldCreate a new Initial Condition by pressing the
Select the region created previously for the bed Initial Condition (“bed” region) and click the
button.Select the solid (named previously as “glass beads”) sub-pane and enter a volume fraction of
0.4
in theVolume Fraction
Select Region
Fluid
sub-pane, enter a velocity in theY-axial velocity
field of0.25
m/sCreate another Boundary condition by clicking the
Select Region
dialog, select “Pressure Outflow” from theBoundary type
Select Region
combo-boxSelect the “wall” region and click
On the Numerics
pane, Residuals
in theFluid Normalization
field.
checkboxSelect the
*.vtu
files in theFilename base
fieldChange the
to0.01
secondsSelect the
Volume fraction
,Pressure
, andVelocity vector
check-boxes on theFluid
tabCreate another output by clicking the
Select the “Slice” region from the list to save all the cell data
*.vtu
fieldChange the
to0.01
secondsSelect the
Volume fraction
,Pressure
tab
Stop Time
to1.0
secondsChange the
to1e-3
secondsChange the
to1e-2
seconds
3.5.12. Run the project¶
Save project by clicking
Run
dialog, select the default executable from the listClick the
Run
3.5.13. View results¶
3D view
Close the VTK window
Model
pane, change the solver toMFiX-DEM
Mesh
pane, coarsen the grid to 15, 45, and 15 cells in the in the x, y, and z direction, respectfully.
Solids
pane, change that particle diameter to5.0000e-03
to get a more reasonable particle count for tutorial purposes.On the
Solids
pane,DEM
sub-pane: - check theEnable automatic particle generation
- enter a value of15
in theSearch grid partitions
,KMAX
field.On the
Boundary Conditions
pane, change theinlet
Y-axial velocity
to0.6
m/sOn the
Boundary Conditions
pane, delete thewalls
boundary condition and re-add it to write the correct wall parameters for the DEM simulation.On the
Output
pane,VTK
sub-pane:Delete the
all
orBackground_IC
outputCreate a new output, change the
Output type
toParticle data
and select theBackground_IC
region.Change the write frequency to
0.01
Diameter
andTranslational Velocity
data
Run the simulation
