3.7. DEM Granular Flow Chutes¶
1.75 m x 0.94 m x 0.2 m |
20 x 20 x 10 |
12.5 mm (0.0125 m) |
3.7.1. Create a new project¶
fig_new_project
): On the main menu, selectNew project
(fig_model_param
): On the Model
drop-down menu.Check the
Disable Fluid Solver
checkbox.
3.7.3. Enter the geometry¶
fig_add_cylinder
): Create the cylindrical geometry by pressing->
primitives
->cylinder
0.1
for the cylinder resolution
primitives
->cylinder
1.2
0.08
fig_difference
): Subtract the smaller radius cylinder from the larger radius cylinder bySelect the larger radius cylinder (named
cylinder
)While holding the
ctrl
key, select the smaller radius cylinder (namedcylinder1
)Press the
Slice the tube in half by:
Add a box:
primitives
->box
Center X
value to0.5
mChange the
Y Length
to1.2
m
Select the tube (named
difference
)While holding the
ctrl
key, select the box (namedbox
)Press the
Rotate the chute by:
Select the chute (named
difference1
fig_add_transform
): Add a filter:->
transform
Enter a value of
0.8
m in theTranslate Y
field.Enter a value of
70
in theRotation Z
field.
transform
)Enter a value of
0.8
in theTranslate X
fieldEnter a value of
0.6
in theTranslate Y
120
in theRotation Z
transform1
)Enter a value of
0.0
in theTranslate X
0.3
in theTranslate Y
70
in theRotation Z
Press the
Autosize
button to fit the domain extents to the geometry
3.7.4. Enter the mesh¶
Background
sub-pane
20
20
for the y cell valueEnter
for the z cell value
Select the Regions
pane.
click the
button to create a new region
field (“walls”)Change the color by pressing the
Color
buttonCheck the
Select Facets (STL)
checkbox
field (“inlet”)Enter a value of
-0.4
m in theFrom X
-0.2
m in theTo X
3.7.6. Create a solid¶
button to create a new solid
field (“glass beads”)Enter the particle diameter of
1/80
2500
kg/m2 in theDensity
On the DEM
sub pane:
check the
checkbox and keep defaults values for all other settings.
pane leave the default initial condition.
Select Region
glass beads
sub-pane:Enter a value of
0.1
in thevolume fraction
field.Enter a velocity in the
Y-axial velocity
field of-0.1
m/s
Select Region
combo-boxSelect the “walls” region and click
3.7.9. Select output options¶
check boxSelect the
Particle Data
in theOutput type
combo box.Select the “Background IC” region from the list to save all the cell data
*.vtp
files in theFilename base
fieldChange the
to0.1
secondsSelect the
Diameter
andTranslational Velocity
check boxes.
3.7.10. Run the project¶
Save project by clicking
Run
dialog, select the default executable from the listClick the
Run
3.7.11. View results¶
