3.10. Procedural Geometry¶
3.10.1. Create a new project¶
On the main menu click on the New button.
3.10.2. Create the geometry¶
First, create a cylinder:
Go to the Geometry
Choose ->
Procedural > Cylinder
as the geometry input (namedcylinder
Radius =
0.05
m, Height =0.225
m, Resolution =20
Start angle=
deg, end angle =360
deg, resolution =32
Check the
Bottom cap
andTop cap
check boxes and set the resolution to5
for both caps.
Next, create a bend:
Go to the Geometry
Choose ->
Procedural > Bend
as the geometry input (named “bend”).Enter the bend’s parameters:
Front section: Radius =
0.02
m, Length =0.05
m, Resolution =10
Back section: Radius =
0.05
m, Length =0.25
m, Resolution =20
Bend section: Major radius =
0.075
m, Minor radius =0.02
m, Start angle=0
deg, end angle =90
deg, resolution =16
Circumference: Start angle=
deg, end angle =360
deg, resolution =16
Check the
Bottom cap
andTop cap
check boxes and set the resolution to3
for both caps. Leave Offset =0
Select the bend (named
bend
)Add a filter: ->
transform
Set a Translation of
0.025
m in the X-direction,0.15
m in the Y-direction, and0.05
m in the Z-direction.Rotate
-90
deg in the Z-direction.
Select the cylinder (named
cylinder
)While holding the
ctrl
key, select the transformed bend (namedtranform
)Press the button
Next, create another bend:
Go to the Geometry
Choose ->
Procedural > Bend
as the geometry input (namedbend1
0.02
m, Length =0.1
m, Resolution =10
0.02
m, Length =0.1
m, Resolution =10
0.05
m, Start angle=0
deg, end angle =90
deg, resolution =10
deg, end angle =360
deg, resolution =16
Check the
Bottom cap
andTop cap
bend1
)Add a filter: ->
transform
-0.005
m in the X-direction,0.25
m in the Y-direction, and-0.05
90
Combine the bend and the previous geometry (union):
Select the transformed bend (named
transform1
)While holding the
ctrl
key, select the previous geometry (namedunion
)Press the button. This will create a new
union1
geometry.
In the model window, show the Geometry, hide the Background Mesh, Hide the Regions (visibility is toggled by clicking on each icon). Set the Geometry style to
edges
, opacity to 1.0, check theShow normals
box, set theScale
to 0.01, setcount
to 10,000 (to show all normals).
union1
geometry,Add a filter: ->
flip normals
. Now the vecors point towards the fluid region. The tips of the arrows are not visible, but we can see the origin (shown as a dot at the center of each face).
In
Domain extent
, enter the following:X-direction: Min =
-0.055
m, Max =0.055
m.Y-direction: Min =
0.01
m, Max =0.35
m.Z-direction: Min =
-0.1
m, Max =0.18
m.
Go to the Regions
There is already a
Background IC
that is predefined in the Blank template. We can ignore it for now.Click the button to create a new region to be used by a mass inlet boundary condition.
Mass inlet
in the Boundary type drop down menu.Enter a name for the region in the Name field (“top inlet”).
Change the region Color to Red.
Click the button to create a new region to be used by another mass inlet boundary condition.
Mass inlet
in the Boundary type drop down menu.Enter a name for the region in the Name field (“bottom inlet”).
Change the region Color to Pink.
Click the button to create a new region to be used by pressure outlet boundary condition.
Pressure Outflow
in the Boundary type drop down menu.Enter a name for the region in the Name field (“outlet”).
Change the region Color to Yellow.
click the button to create a new region that covers the entire domain to be used for the wall boundary condition.
No-slip wall
in the Boundary type drop down menu.Enter a name for the region in the Name field (“wall”).
Change the region Color to Green.
Select facets (STL)
andflip_normals
, useall
for the selection method. You should see that there are 4003 facets selected.
click the button to create a new region that will be used as initial condition region. This is not needed to generate the mesh, but will be used later when setting up the simulation.
Leave the Boundary type to
None
.Enter a name for the region in the Name field (“init bed”).
Change the region Color to Black.
Set the Y-extent form
ymin
to0.15
m.Save the project by clicking the button.
3.10.5. Setup the mesh¶
Go to the Mesh
pane, Background
15
for the x cell value.Enter
35
for the y cell value.Enter
for the z cell value.
Go to the Mesh
pane, Mesher
0.0
deg. (The geometry unions have created elongated triangles we need to keep).Click
Generate
.Look at the console output to verify the mesh generation completed successfully.
In the Model view, hide the Geometry, Background Mesh and Regions, show the Boundary_Mesh, set Color by to
bc_id
, Style toedges
and opacity to1.0
.The Boundary_Mesh should look like a closed surface with colors matching the Boundary Conditions regions.
After inspection, the mesh is deemed acceptable and we can move to setting up the simulation (Solver mode). Click Accept
. This will unlock the Modeler tab.
3.10.6. Model settings¶
Model
field.Select “Discrete Element Model (MFiX-DEM)” in the
drop-down menu.Keep all other settings at their default values.
3.10.7. Regions settings¶
3.10.8. Fluid settings¶
Change Density to
Ideal gas law
3.10.9. Solids settings¶
pane, Materials
Click the button to create a new solid.
0.005
field.Enter the particle density of
2700
kg/m3 in theDensity
field.Select the
Solids
pane,DEM
sub-pane.Check the
checkbox.Keep all other settings at their default values.
3.10.10. Initial Conditions settings¶
There is already a
Background IC
region that initializes the entire domain as stagnant air. We only need to add solids at the bottom.Create a new initial condition region by clicking the button.
init bed
region, go to theSolid 1
tab and enter0.5
for the volume fraction.
3.10.11. Boundary Conditions settings¶
top inlet
region. In theSolids 1
tab, enter0.2
for the volume fraction and-0.2
for the Y-axial velocity.Select the
bottom inlet
region. Stay on theFluid
tab, enter4.0
for the Y-axial velocity.The outlet Boundary Conditions is already set to atmospheric pressure. No changes are needed.
3.10.12. Numerics settings¶
On the Numerics
0.0
and the flui pressure correction scale factor to1.0
On the Preconditioner tab, set the preconditioner to
None
for all equations.
3.10.13. Output settings¶
checkbox.Select the
sub-pane.Create a new output by clicking the button.
to create the output.Enter a base name for the
*.vtu
files in theFilename base
field (“Particles”).Change the
to0.01
seconds.Select the
Diameter
andTranslational Velocity
check-boxes.
3.10.14. Run settings¶
Set the Stop time to
1.0
.Set the Time step to
0.001
.Set the Maximum time step to
0.01
3.10.15. Run the simulation¶
Run the project by clicking the button.
Run
dialog, select the executable from the combo-box.Click the
Run
button to actually start the simulation.
3.10.16. View results¶
Create a new visualization tab by pressing the next to the Model tab.
3D view
files can be controlled with the menu on the side.Change frames with the , , , and buttons.
Click the button to play the available vtk files.
Change the playback speed under the section on the sidebar.
