3.2. Two Dimensional Fluid Bed, Two Fluid Model (TFM)
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
Property
Value
geometry
10 cm x 30 cm
mesh
20 x 60
solid diameter
200 microns (\(200 \times 10^{-6}\) m)
solid density
2500 kg/m2
gas velocity
0.25 m/s
temperature
298 K
pressure
101325 Pa
3.2.1. Create a new project
  • (fig_new_project): On the main menu select New project
  • Create a new project by double-clicking on “Blank” template.
  • Enter a project name and browse to a location for the new project.
  • When prompted to enable SMS workflow, answer No, we will use the standard workflow for this tutorial.
create project
3.2.2. Select model parameters
  • Enter a descriptive text in the Description field
  • Select “Two-Fluid Model (MFiX-TFM)” in the Solver drop-down menu.
select model parameters
3.2.3. Enter the geometry
  • Select the 2 Dimensional checkbox
  • Enter 10/100 meters for the maximum x value
  • Enter 30/100 meters for the maximum y value
enter geometry
3.2.4. Enter the mesh
  • Enter 20 for the x cell value
  • Enter 60 for the y cell value
enter mesh
3.2.5. Create regions for initial and boundary condition specification
Select the Regions pane. By default, a region that covers the entire domain is already defined. This is typically used to initialize the flow field and visualize the results.
  • click the add button to create a new region to be used for the bed initial condition.
  • Enter a name for the region in the Name field (“bed”)
  • Change the color by pressing the Color button
  • Enter xmin or min in the From X field
  • Enter xmax or max in the To X field
  • Enter ymin or min in the From Y field
  • Enter ymax/2 or max/2 in the To Y field
  • Enter zmin or min in the From Z field
  • Enter zmax or max in the To Z field
create region 1
  • Click the bottom_region button to create a new region with the From and To fields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition. From Y and To Y should equal ymin, defining an XZ-plane.
  • Enter a name for the region in the Name field (“inlet”)
create region 2
  • Click the top_region button to create a new region with the From and To fields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition. From Y and To Y should equal ymax, defining an XZ-plane.
  • Enter a name for the region in the Name field (“outlet”)
create region 3
3.2.6. Create a solid
On the Solids pane:
  • Click the add button to create a new solid
  • Accept the radial distribution setting (Carnahan-Starling)
  • Enter a descriptive name in the Name field (“glass beads”)
  • Keep the model as “Two-Fluid Model (MFiX-TFM)”)
  • Enter the particle diameter of 200e-6 m in the Diameter field
  • Enter the particle density of 2500 kg/m2 in the Density field
create a solid
3.2.7. Create Initial Conditions
  • Select the already populated “Background IC” from the region list. This will initialize the entire flow field with air.
  • Enter 101325 Pa in the Pressure (optional) field
initial condition pane
  • Create a new Initial Condition by pressing the add button
  • Select the bed region created previously for the bed Initial Condition (“bed” region) and click the OK button.
create new initial condition
  • Select the solid (named previously as “glass beads”) sub-pane and enter a volume fraction of 0.4 in the Volume Fraction field. This will fill the bottom half of the domain with glass beads.
initial condition pane2
3.2.8. Create Boundary Conditions
  • Create a new Boundary condition by clicking the add button
  • On the Select Region dialog, select “Mass Inflow” from the Boundary type drop-down menu
  • Select the “inlet” region and click OK
new boundary condition
  • On the “Fluid” sub-pane, enter a velocity in the Y-axial velocity field of “0.25” m/s
  • Create another Boundary condition by clicking the add button
  • On the Select Region dialog, select “Pressure Outflow” from the Boundary type combo-box
  • Select the “outlet” region and click OK
3.2.9. Change numeric parameters
  • Enter 0 in the Fluid Normalization field.
3.2.10. Select output options
  • On the Basic sub-pane, check the Write VTK output files (VTU/VTP) checkbox
  • Select the VTK sub-pane
  • Create a new output by clicking the add button
  • Select the “Background IC” region from the list to save all the cell data
  • Click OK to create the output
  • Enter a base name for the *.vtu files in the Filename base field
  • Change the Write interval to 0.1 seconds
  • Select the Volume fraction, Pressure, and Velocity vector check-boxes on the Fluid sub-sub-pane
3.2.11. Change run parameters
  • Change the Time step to 1e-3 seconds
  • Change the Maximum time step to 1e-2 seconds
3.2.12. Run the project
  • Save project by clicking the save button
  • Run the project by clicking the play button
  • On the Run Solver dialog, select the executable from the combo-box
  • Click the Run button to actually start the simulation
3.2.13. View results
  • Create a new visualization tab by pressing the add next to the Model tab
  • Select an item to view, such as plotting the time step (dt) or click the 3D view button to view the vtk output files.
new output
  • On the VTK results tab, the visibility and representation of the *.vtk files can be controlled with the menu on the side.
  • Change frames with the first, back, next, and last buttons
  • Click the play button to play the available vtk files.
  • Change the playback speed under the speed section on the sidebar.
3.2.14. Increase grid resolution
  • Click the reset button and delete all simulation files.
  • On the Mesh pane, change the X Cells to 80 and the Y Cells to 180
  • On the Output pane, VTK sub-pane, change the write interval to 0.01
  • Save and run the project.
