3.4. Three Dimensional Single phase flow over a sphere¶
This tutorial shows how to create a three dimensional single phase flow over a sphere.
60 cm 20 cm x 20 cm |
30 x 10 x 10 |
1 m/s |
3.4.1. Create a new project¶
3.4.2. Select model parameters¶
On the Model
fieldSelect “Single Phase” in the
drop-down menu.
3.4.3. Enter the geometry¶
pane enter the domain extents:
60/100
meters for the maximum x value20/100
meters for the maximum y value20/100
Next, add a sphere by clicking the button -> primitives -> sphere. This adds a sphere constructed of triangles (STL) to the project.
10/100
for the center X position10/100
for the center Y position10/100
for the center Z position
5/100
for the radius.
3.4.4. Enter the mesh¶
pane, Background
for the y cell valueEnter
for the z cell value
3.4.5. Create regions for initial and boundary condition specification¶
Select the Regions
click the button to create a region that encompasses the entire domain
name
such as “sphere”Check the
Select Facets (STL)
check-box to turn the region into a STL region. The facets of the sphere should now be selected.
field (“inlet”)
field (“outlet”)
field (“slice”)Enter
zmax/2
in both theFrom Z
andTo Z
fields to move the region to the center of the domain
3.4.6. Create Initial Conditions¶
Initial conditions
paneSelect the already populated “Background IC” from the region list. This will initialize the entire flow field with air.
101325
Pa in thePressure (optional)
3.4.7. Create Boundary Conditions¶
the sphere by:
clicking the button
Select Region
combo-boxSelect the “sphere” region and click
Add a mass inlet boundary condition by:
clicking the button
Select Region
combo-boxSelect the “inlet” region and click
X-axial velocity
field of1.0
m/s
clicking the button
Select Region
dialog, select “Pressure Outflow” from theBoundary type
3.4.8. Select output options¶
checkbox
sub-paneCreate a new output by clicking the button
Select the “slice” region from the list to save cell data at a slice through the domain
to “0.01” secondsSelect the
Pressure
,Velocity vector
,Velocity x-component
,Velocity y-component
, andVelocity z-component
check-boxes on theFluid
sub-sub-pane
3.4.9. Change run parameters¶
Stop Time step
to2.0
secondsChange the
to1e-2
secondsChange the
to1e-2
seconds
3.4.10. Run the project¶
Save project by clicking the button
Run the project by clicking the button
Run Solver
dialog, select the executableClick the
Run
3.4.11. View results¶
Create a new visualization tab by pressing the next to the Model tab
3D view
