3.3. Two Dimensional Fluid Bed, Discrete Element Model (DEM)¶
15 cm x 90 cm x 0.4 cm |
15 x 45 x 1 |
2700 kg/m2 |
42.0 m/s |
3.3.1. Create a new project¶
Model
drop-down menu.
3.3.3. Enter the geometry¶
0.15
0.90
meters for the maximum y valueEnter
0.004
3.3.4. Enter the mesh¶
pane, Background
15
45
for the y cell valueEnter
for the z cell value
On the Regions
click the
button to create a new region that covers the entire domain to be used for the bed initial condition.
field (“bed”)Change the
To Y
field to be “ymax/2”Click the
button to create a new region to be used by the gas inlet boundary condition.
field (“inlet”)Enter
0.07
in theFrom X
field and0.08
in theTo X
field.Click the
button to create a new region to be used by pressure outlet boundary condition.
field (“outlet”)
3.3.6. Create a solid¶
pane, Materials
button to create a new solid
field (“solids”)Enter the particle diameter of
0.004
2700
kg/m2 in theDensity
Solids
pane,DEM
sub-paneCheck the
checkbox, so that the bed Initial Condition, defined later, will be filled with solids
101325
Pa in thePressure (optional)
button.
0.4
in theVolume Fraction
field. This will fill the bottom half of the domain with solids.Note the estimated number of particles and inventory (around 3,200 particles or 0.3 kg). When running DEM simulations on a single core machine, it is recommended to stay below 100,000 particles to get reasonable run times.
Select Region
Y-axial velocity
field of “42” m/s
Select Region
dialog, select “Pressure Outflow” from theBoundary type
3.3.9. Select output options¶
checkbox
to create the output
*.vtu
files in theFilename base
field (“particles”)Change the
to0.01
secondsSelect the
Diameter
andTranslational Velocity
check-boxes
Stop Time step
to1.0
secondsChange the
to1e-2
secondsChange the
to1e-2
seconds
3.3.11. Run the project¶
Save project by clicking the
Run
Run
3.3.12. View results¶
3D view
Change frames with the
, and
buttons
section on the sidebar.
