8.3.4. Geometry and Discretization¶
8.3.4.1. COORDINATES¶
Cartesian coordinates. |
Cylindrical coordinates. |
8.3.4.3. DX(CELL)¶
Use uniform mesh size with higher-order discretization methods.
DX should be kept uniform in cylindrical coordinates for strict momentum conservation.
8.3.4.4. XMIN¶
8.3.4.9. DY(CELL)¶
8.3.4.13. NO_K¶
Z axis in Cartesian coordinate system
Theta in Cylindrical coordinate system
3D simulation. |
2D simulation. |
8.3.4.15. DZ(CELL)¶
8.3.4.19. CYCLIC_X¶
No cyclic condition at x-boundary. |
Cyclic condition at x-boundary. |
8.3.4.20. CYCLIC_X_PD¶
Cyclic condition with pressure drop at x-boundary. |
8.3.4.21. DELP_X¶
8.3.4.22. CYCLIC_Y¶
No cyclic condition at y-boundary. |
8.3.4.23. CYCLIC_Y_PD¶
Cyclic condition with pressure drop at y-boundary. |
8.3.4.24. DELP_Y¶
8.3.4.25. CYCLIC_Z¶
No cyclic condition at z-boundary. |
Cyclic condition at z-boundary. |
8.3.4.26. CYCLIC_Z_PD¶
Cyclic condition with pressure drop at z-boundary. |
8.3.4.27. DELP_Z¶
8.3.4.28. SHEAR¶
8.3.4.29. V_SH¶
8.3.4.30. FLUX_G¶
8.3.4.31. CYLINDRICAL_2D¶
8.3.4.32. I_CYL_NUM¶
8.3.4.33. I_CYL_TRANSITION¶
Two cell smoothing transition. |
One cell smoothing transition. |
No smoothing. |
8.3.4.36. ERX(CTRL)¶
8.3.4.37. FIRST_DX(CTRL)¶
- Value of first DX in a segment (x-direction). A negative
8.3.4.38. LAST_DX(CTRL)¶
- Value of last DX in a segment (x-direction). A
8.3.4.41. ERY(CTRL)¶
8.3.4.42. FIRST_DY(CTRL)¶
8.3.4.43. LAST_DY(CTRL)¶
8.3.4.46. ERZ(CTRL)¶
8.3.4.47. FIRST_DZ(CTRL)¶
8.3.4.48. LAST_DZ(CTRL)¶
