8.3.17. Parallelization Control¶
computational grid. The preconditioners are chosen with the keyword LEQ_PC
NODESI * NODESJ * NODESK
must be the same as the number of processors
specified using mpirun
(or equivalent command). Otherwise the code will
return with an error.
8.3.17.4. DLB_NODESI(LAYOUT)¶
\(1 \le Layout \le 100\)
8.3.17.5. DLB_NODESJ(LAYOUT)¶
8.3.17.6. DLB_NODESK(LAYOUT)¶
