8.3.13. Output Control
8.3.13.1. RES_DT
required
8.3.13.2. RES_BACKUP_DT
8.3.13.3. RES_BACKUPS
8.3.13.4. SPX_DT(SP VALUE)
  • \(1 \le SP Value \le 11\)
  • SP1: void fraction (EP_G)
8.3.13.5. NRR
8.3.13.6. OUT_DT
8.3.13.7. REPORT_SOLID_INVENTORY
required
8.3.13.8. REPORT_SOLID_INVENTORY_DT
required
8.3.13.9. BREAKDOWN_SOLID_INVENTORY_BY_PHASE
required
8.3.13.10. NLOG
8.3.13.11. FULL_LOG
8.3.13.12. RESID_STRING(RESIDUAL INDEX)
Table 8.65 Valid Values
P0
Gas pressure
PM
Solids phase M pressure
R0
Gas density
RM
Solids phase M density
U0
Gas phase U-velocity
V0
Gas phase V-velocity
W0
Gas phase W-velocity
UM
Solids phase M U-velocity
VM
Solids phase M V-velocity
WM
Solids phase M W-velocity
T0
Gas temperature
TM
Solids phase M temperature
GM
X0NN
XMNN
K0
K-Epsilon model residuals
8.3.13.13. GROUP_RESID
8.3.13.14. REPORT_NEG_DENSITY
Table 8.66 Valid Values
Log negative density errors.
8.3.13.15. REPORT_NEG_SPECIFICHEAT
Table 8.67 Valid Values
8.3.13.16. REPORT_MASS_BALANCE_DT
8.3.13.17. PHIP_OUT_JJ
8.3.13.18. BDIST_IO
8.3.13.19. BSTART_WITH_ONE_RES
8.3.13.20. MONITOR_X_W(MONITOR)
8.3.13.21. MONITOR_X_E(MONITOR)
8.3.13.22. MONITOR_Y_S(MONITOR)
8.3.13.23. MONITOR_Y_N(MONITOR)
8.3.13.24. MONITOR_Z_B(MONITOR)
8.3.13.25. MONITOR_Z_T(MONITOR)
8.3.13.26. MONITOR_NAME(MONITOR)
8.3.13.27. MONITOR_DT(MONITOR)
8.3.13.28. MONITOR_TYPE(MONITOR)
Data monitor type.
Table 8.68 Valid Values
Point value
Sum over region
Minimum over region
3
Maximum over region
4
5
6
7
Flow rate across surface
8
Mass flow rate across surface
11
Volume integral
12
Volume-weighted average
13
Mass-weighted volume integral
14
Mass-weighted volume average
101
Sum over region
102
Minimum over region
103
Maximum over region
104
105
106
107
108
109
110
8.3.13.29. MONITOR_EP_G(MONITOR)
8.3.13.30. MONITOR_RO_G(MONITOR)
8.3.13.31. MONITOR_P_G(MONITOR)
8.3.13.32. MONITOR_U_G(MONITOR)
8.3.13.33. MONITOR_V_G(MONITOR)
8.3.13.34. MONITOR_W_G(MONITOR)
8.3.13.35. MONITOR_T_G(MONITOR)
8.3.13.36. MONITOR_MW_MIX_G(MONITOR)
8.3.13.37. MONITOR_X_G(MONITOR, SPECIES)
  • \(1 \le Species \le 100\)
8.3.13.38. MONITOR_Y_G(MONITOR, SPECIES)
8.3.13.39. MONITOR_K_TURB_G(MONITOR)
8.3.13.40. MONITOR_E_TURB_G(MONITOR)
8.3.13.41. MONITOR_EP_S(MONITOR, PHASE)
8.3.13.42. MONITOR_U_S(MONITOR, PHASE)
8.3.13.43. MONITOR_V_S(MONITOR, PHASE)
8.3.13.44. MONITOR_W_S(MONITOR, PHASE)
8.3.13.45. MONITOR_ROP_S(MONITOR, PHASE)
8.3.13.46. MONITOR_RO_S(MONITOR, PHASE)
8.3.13.47. MONITOR_P_STAR(MONITOR)
8.3.13.48. MONITOR_P_S(MONITOR, PHASE)
8.3.13.49. MONITOR_T_S(MONITOR, PHASE)
8.3.13.50. MONITOR_X_S(MONITOR, PHASE, SPECIES)
8.3.13.51. MONITOR_THETA_M(MONITOR, PHASE)
8.3.13.52. MONITOR_SCALAR(MONITOR, SCALAR EQ.)
Write scalar in region.
8.3.13.53. MONITOR_RRATE(MONITOR, RATE)
  • \(1 \le RATE \le NRRMAX\)
8.3.13.54. MONITOR_FLUID_RRATE(MONITOR, RATE)
Write fluid reaction rates in region. This keyword replaces
8.3.13.55. MONITOR_DES_RRATE(MONITOR, RATE)
Write particle/parcel reaction rates in region. Particle/parcel data
is converted to cell data.
8.3.13.56. MONITOR_PART_PHASE(MONITOR, PHASE)
8.3.13.57. MONITOR_RADIUS(MONITOR)
8.3.13.58. MONITOR_PMASS(MONITOR)
8.3.13.59. MONITOR_PVOL(MONITOR)
8.3.13.60. MONITOR_RO_P(MONITOR)
8.3.13.61. MONITOR_VEL_X(MONITOR)
8.3.13.62. MONITOR_VEL_Y(MONITOR)
8.3.13.63. MONITOR_VEL_Z(MONITOR)
8.3.13.64. MONITOR_ROT_X(MONITOR)
8.3.13.65. MONITOR_ROT_Y(MONITOR)
8.3.13.66. MONITOR_ROT_Z(MONITOR)
8.3.13.67. MONITOR_T_P(MONITOR)
8.3.13.68. MONITOR_X_P(MONITOR, SPECIES)
8.3.13.69. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)
  • \(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
8.3.13.70. MONITOR_PART_RRATE(MONITOR, RATE)
  • \(1 \le rate \le 100\)
8.3.13.71. MONITOR_PART_RESIDENCE_TIME(MONITOR)
8.3.13.72. WRITE_VTK_FILES
Table 8.69 Valid Values
8.3.13.73. TIME_DEPENDENT_FILENAME
Table 8.70 Valid Values
8.3.13.74. VTK_DT(VTK)
  • \(1 \le VTK \le 100\)
8.3.13.75. VTK_DBG_FILE(VTK)
When VTK_DBG_FILE is .TRUE., the VTK region file is only written
8.3.13.76. VTK_VAR(IDX)
  • \(1 \le IDX \le 20\)
Table 8.71 Valid Values
Void fraction (EP_g)
3
Gas velocity (U_g, V_g, W_g)
4
5
Solids density (ROP_s)
6
7
8
Scalar
Reaction rates
11
K and Epsilon
12
100
Grid Partition
101
Boundary Condition ID
102
Distance to wall
103
DEM facet count
104
DEM Neighboring facets
999
Cell IJK index
1000
Cut face normal vector
8.3.13.77. VTK_X_W(VTK)
8.3.13.78. VTK_X_E(VTK)
8.3.13.79. VTK_Y_S(VTK)
8.3.13.80. VTK_Y_N(VTK)
8.3.13.81. VTK_Z_B(VTK)
8.3.13.82. VTK_Z_T(VTK)
8.3.13.83. VTK_FILEBASE(VTK)
8.3.13.84. VTK_DATA(VTK)
Table 8.72 Valid Values
C
Cell data (VTU file).
P
Particle data (VTP file).
G
Geometry data (STL file).
F
Force chain data (VTP file).
8.3.13.85. VTK_GEO(VTK, GEO)
8.3.13.86. VTK_SELECT_MODE(VTK)
Table 8.73 Valid Values
C
P
I
8.3.13.87. VTK_NXS(VTK)
8.3.13.88. VTK_NYS(VTK)
8.3.13.89. VTK_NZS(VTK)
8.3.13.90. VTK_SLICE_TOL(VTK)
8.3.13.91. VTK_EP_G(VTK)
8.3.13.92. VTK_P_G(VTK)
8.3.13.93. VTK_VEL_G(VTK)
8.3.13.94. VTK_U_G(VTK)
8.3.13.95. VTK_V_G(VTK)
8.3.13.96. VTK_W_G(VTK)
8.3.13.97. VTK_P_STAR(VTK)
8.3.13.98. VTK_P_S(VTK, PHASE)
8.3.13.99. VTK_VEL_S(VTK, PHASE)
8.3.13.100. VTK_U_S(VTK, PHASE)
8.3.13.101. VTK_V_S(VTK, PHASE)
8.3.13.102. VTK_W_S(VTK, PHASE)
8.3.13.103. VTK_ROP_S(VTK, PHASE)
8.3.13.104. VTK_RO_S(VTK, PHASE)
8.3.13.105. VTK_EP_S(VTK, PHASE)
8.3.13.106. VTK_T_G(VTK)
8.3.13.107. VTK_T_S(VTK, PHASE)
8.3.13.108. VTK_MW_MIX_G(VTK)
8.3.13.109. VTK_X_G(VTK, GAS SPECIES)
8.3.13.110. VTK_Y_G(VTK, GAS SPECIES)
8.3.13.111. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)
8.3.13.112. VTK_THETA_M(VTK, PHASE)
8.3.13.113. VTK_SCALAR(VTK, SCALAR)
8.3.13.114. VTK_RRATE(VTK, RATE)
  • \(1 \le rate \le nRRmax\)
8.3.13.115. VTK_RRATE_LABEL(VTK, RATE)
8.3.13.116. VTK_FLUID_RRATE(VTK, RATE)
8.3.13.117. VTK_DES_RRATE(VTK, RATE)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is
accumulated in fluid cells.
8.3.13.118. VTK_K_TURB_G(VTK)
8.3.13.119. VTK_E_TURB_G(VTK)
8.3.13.120. VTK_VORTICITY(VTK)
8.3.13.121. VTK_LAMBDA_2(VTK)
Write lambda_2 in region.
8.3.13.122. VTK_PARTITION(VTK)
8.3.13.123. VTK_BC_ID(VTK)
8.3.13.124. VTK_DWALL(VTK)
8.3.13.125. VTK_FACET_COUNT_DES(VTK)
8.3.13.126. VTK_NB_FACET_DES(VTK)
8.3.13.127. VTK_IJK(VTK)
8.3.13.128. VTK_NORMAL(VTK)
8.3.13.129. VTK_DEBUG(VTK, IDX)
  • \(1 \le IDX \le 15\)
8.3.13.130. VTK_PART_DIAMETER(VTK)
8.3.13.131. VTK_PART_PHYSICAL_DIAMETER(VTK)
8.3.13.132. VTK_PART_CGP_STAT_WT(VTK)
8.3.13.133. VTK_PART_VEL(VTK)
8.3.13.134. VTK_PART_ANGULAR_VEL(VTK)
8.3.13.135. VTK_PART_ORIENTATION(VTK)
8.3.13.136. VTK_PART_USR_VAR(VTK, USR_VAR)
8.3.13.137. VTK_PART_TEMP(VTK)
8.3.13.138. VTK_PART_X_S(VTK, DES_SPECIES)
8.3.13.139. VTK_PART_RRATE(VTK, RATE)
8.3.13.140. VTK_PART_DENSITY(VTK)
8.3.13.141. VTK_PART_COHESION(VTK)
8.3.13.142. VTK_PART_RANK(VTK)
8.3.13.143. VTK_PART_ID(VTK)
Write particle ID in region.
8.3.13.144. VTK_PART_RESIDENCE_TIME(VTK)
8.3.13.145. VTK_PART_PHASE_ID(VTK)
8.3.13.146. VTK_PART_PHASE(VTK, PHASE)
8.3.13.147. VTK_CUTCELL_ONLY(VTK)
8.3.13.148. FRAME(VTK)
8.3.13.149. VTU_DIR
Directory where VTK files are stored. By default,
8.3.13.150. DES_REPORT_MASS_INTERP
8.3.13.152. VTP_DIR
8.3.13.153. DES_OUTPUT_TYPE
Table 8.74 Valid Values
PARAVIEW
TECPLOT
8.3.13.154. DEBUG_DES
8.3.13.155. FOCUS_PARTICLE
8.3.13.156. WRITE_PART_OUT
8.3.13.157. PART_OUT_ZERO_VEL
8.3.13.158. PART_OUT_X_MIN
8.3.13.159. PART_OUT_X_MAX
8.3.13.160. PART_OUT_X_EXCLUDE
8.3.13.161. PART_OUT_Y_MIN
8.3.13.162. PART_OUT_Y_MAX
8.3.13.163. PART_OUT_Y_EXCLUDE
8.3.13.164. PART_OUT_Z_MIN
8.3.13.165. PART_OUT_Z_MAX
8.3.13.166. PART_OUT_Z_EXCLUDE
8.3.13.167. PART_OUT_PHASE(PHASE)
8.3.13.168. PART_OUT_DIAMETER_MIN
8.3.13.169. PART_OUT_DIAMETER_MAX
8.3.13.170. PART_OUT_DIAMETER_EXCLUDE
8.3.13.171. PART_OUT_DENSITY_MIN
8.3.13.172. PART_OUT_DENSITY_MAX
8.3.13.173. PART_OUT_DENSITY_EXCLUDE
8.3.13.174. PART_OUT_U_MIN
8.3.13.175. PART_OUT_U_MAX
8.3.13.176. PART_OUT_U_EXCLUDE
X-velocity filter selection mode applied to particles written in particle_output.dat. By default, particles with data between min and max value are selected and written out. Change to .TRYE. to select only particles with data outside the [min;max] range.
8.3.13.177. PART_OUT_V_MIN
8.3.13.178. PART_OUT_V_MAX
8.3.13.179. PART_OUT_V_EXCLUDE
8.3.13.180. PART_OUT_W_MIN
8.3.13.181. PART_OUT_W_MAX
8.3.13.182. PART_OUT_W_EXCLUDE
8.3.13.183. PART_OUT_TEMP_MIN
8.3.13.184. PART_OUT_TEMP_MAX
8.3.13.185. PART_OUT_TEMP_EXCLUDE
8.3.13.186. PART_OUT_X_S_MIN(INDEX)
  • \(1 \le Index \le 100\)
8.3.13.187. PART_OUT_X_S_MAX(INDEX)
8.3.13.188. PART_OUT_X_S_EXCLUDE(INDEX)
8.3.13.189. PART_OUT_USR_VAR_MIN(INDEX)
8.3.13.190. PART_OUT_USR_VAR_MAX(INDEX)
8.3.13.191. PART_OUT_USR_VAR_EXCLUDE(INDEX)
8.3.13.192. PART_IN_X_MIN
8.3.13.193. PART_IN_X_MAX
8.3.13.194. PART_IN_X_EXCLUDE
8.3.13.195. PART_IN_Y_MIN
8.3.13.196. PART_IN_Y_MAX
8.3.13.197. PART_IN_Y_EXCLUDE
8.3.13.198. PART_IN_Z_MIN
8.3.13.199. PART_IN_Z_MAX
8.3.13.200. PART_IN_Z_EXCLUDE
8.3.13.201. PART_IN_PHASE(PHASE)
8.3.13.202. PART_IN_DIAMETER_MIN
8.3.13.203. PART_IN_DIAMETER_MAX
8.3.13.204. PART_IN_DIAMETER_EXCLUDE
8.3.13.205. PART_IN_DENSITY_MIN
8.3.13.206. PART_IN_DENSITY_MAX
8.3.13.207. PART_IN_DENSITY_EXCLUDE
8.3.13.208. PART_IN_U_MIN
8.3.13.209. PART_IN_U_MAX
8.3.13.210. PART_IN_U_EXCLUDE
8.3.13.211. PART_IN_V_MIN
8.3.13.212. PART_IN_V_MAX
8.3.13.213. PART_IN_V_EXCLUDE
8.3.13.214. PART_IN_W_MIN
8.3.13.215. PART_IN_W_MAX
8.3.13.216. PART_IN_W_EXCLUDE
8.3.13.217. PART_IN_TEMP_MIN
8.3.13.218. PART_IN_TEMP_MAX
8.3.13.219. PART_IN_TEMP_EXCLUDE
8.3.13.220. PART_IN_X_S_MIN(INDEX)
8.3.13.221. PART_IN_X_S_MAX(INDEX)
8.3.13.222. PART_IN_X_S_EXCLUDE(INDEX)
8.3.13.223. PART_IN_USR_VAR_MIN(INDEX)
8.3.13.224. PART_IN_USR_VAR_MAX(INDEX)
8.3.13.225. PART_IN_USR_VAR_EXCLUDE(INDEX)
