8.3.14. UDF Control
8.3.14.1. CALL_USR
Table 8.75 Valid Values
Call user-defined subroutines.
Do NOT call user-defined subroutines.
8.3.14.2. CALL_USR_SOURCE(EQUATION ID NUMBER)
  • 1EquationIDNumber10
Table 8.76 Valid Values
Call user-defined source.
MFIX default: No additional source.
8.3.14.3. USR_ROG
Flag to use the User Defined Function, USR_PROP_ROg, in model/usr_prop.f for calculating the gas phase density, RO_g.
Table 8.77 Valid Values
Call user-defined function.
Use MFIX default calculation.
8.3.14.4. USR_CPG
Flag to use the User Defined Function, USR_PROP_CPg, in model/usr_prop.f for calculating the gas phase constant pressure specific heat, C_pg.
Table 8.78 Valid Values
8.3.14.5. USR_KG
Flag to use the User Defined Function, USR_PROP_Kg, in model/usr_prop.f for calculating the gas phase conductivity, K_g.
Table 8.79 Valid Values
8.3.14.6. USR_DIFG
Flag to use the User Defined Function, USR_PROP_Difg, in model/usr_prop.f for calculating the gas phase diffusivity.
Table 8.80 Valid Values
8.3.14.7. USR_MUG
Flag to use the User Defined Function, USR_PROP_Mug, in model/usr_prop.f for calculating the gas phase viscosity, Mu_g.
Table 8.81 Valid Values
8.3.14.8. USR_ROS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_ROs, in model/usr_prop.f for calculating the solids phase density, RO_s.
Table 8.82 Valid Values
8.3.14.9. USR_CPS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_CPs, in model/usr_prop.f for calculating the solids phase constant pressure specific heat, C_ps.
Table 8.83 Valid Values
8.3.14.10. USR_KS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_Ks, in model/usr_prop.f for calculating the solids phase conductivity, K_s.
Table 8.84 Valid Values
8.3.14.11. USR_DIFS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_Difs, in model/usr_prop.f for calculating the solids phase diffusivity, Dif_s.
Table 8.85 Valid Values
8.3.14.12. USR_MUS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_Mus, in model/usr_prop.f for calculating the solids phase viscosity, Mu_s; second viscosity, lambda_s; and pressure, P_s.
Table 8.86 Valid Values
8.3.14.13. USR_GAMA(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_Gama, in model/usr_prop.f for calculating the gas-solids phase heat transfer coefficient, Gama_gs.
Table 8.87 Valid Values
8.3.14.14. USR_FGS(PHASE)
  • 1Phase10
Flag to use the User Defined Function, USR_PROP_Fgs, in model/usr_prop.f for calculating the gas-solids phase drag coefficient due to relative velocity differences, F_gs. Currently unavailable.
Table 8.88 Valid Values
8.3.14.15. USR_FSS(PHASE)
  • 1PhaseDIM_LM
Flag to use the User Defined Function, USR_PROP_Fss, in model/usr_prop.f for calculating the solids-solids phase drag coefficient due to relative velocity differences, F_ss. Currently unavailable.
Table 8.89 Valid Values
8.3.14.16. C(USER-DEFINED ID)
  • 1UserdefinedIDDIMENSION_C
User defined constants.
8.3.14.17. C_NAME(USER-DEFINED ID)
8.3.14.18. USR_DT(USR)
  • 1USR5
8.3.14.19. USR_X_W(USR)
  • 1USR5
8.3.14.20. USR_X_E(USR)
  • 1USR5
8.3.14.21. USR_Y_S(USR)
  • 1USR5
8.3.14.22. USR_Y_N(USR)
  • 1USR5
8.3.14.23. USR_Z_B(USR)
  • 1USR5
8.3.14.24. USR_Z_T(USR)
  • 1USR5
8.3.14.25. USR_I_W(USR)
  • 1USR5
8.3.14.26. USR_I_E(USR)
  • 1USR5
8.3.14.27. USR_J_S(USR)
  • 1USR5
8.3.14.28. USR_J_N(USR)
  • 1USR5
8.3.14.29. USR_K_B(USR)
  • 1USR5
8.3.14.30. USR_K_T(USR)
  • 1USR5
8.3.14.31. USR_TYPE(USR)
  • 1USR5
8.3.14.32. USR_VAR(USR)
  • 1USR5
UDF hook:
Variable to be written in the user-defined output files.
8.3.14.33. USR_FORMAT(USR)
  • 1USR5
UDF hook:
Format for writing user-defined (ASCII) output file.
8.3.14.34. USR_EXT(USR)
  • 1USR5
8.3.14.35. DES_USR_VAR_SIZE
