12.1.2. Boundary conditions (BC)¶
Boundary conditions are specified over flow planes or 2D surfaces that are normal to one of the coordinate directions and coincide with a face of the scalar control-volume. The values for one of the three pairs of coordinates are equal. The surface is defined by the constant coordinates of each of the four edges, which can be specified with physical coordinates or cell indices, and the two equal values for the direction normal to the face, which can only be specified with physical coordinates. If cell sizes are not small enough to resolve a surface specified using physical coordinates, MFIX will indicate this problem with an error message.
A flow plane must have a wall cell (or an outside boundary) on one side and a
flow cell on the other side. The BC section is also used to specify obstacles in
the flow domain. Obstacles are 3D regions, just as for the IC regions: X_w
X_e, Y_s Y_n, and Z_t Z_b. By default the outside boundary is initialized as
no-slip walls. For cylindrical coordinates the axis is initialized as a
free-slip wall.
12.1.2.1. BC_C_SCALAR(BC, SCALAR EQ.)¶
\(1 \le BC \le 500\)
\(1 \le Scalar Eq. \le 100\)
Specified constant scalar flux, \(C\), in diffusion boundary condition: \({\mathrm{d}S}/{\mathrm{d}n} + Hw (S - Sw) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.2. BC_C_T_G(BC)¶
Specified constant gas phase heat flux, \(C\), in diffusion boundary condition: \({\mathrm{d}T_g}/{\mathrm{d}n} + Hw (T_g - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.3. BC_C_T_S(BC, PHASE)¶
Specified constant solids phase heat flux, \(C\), in diffusion boundary condition: \({\mathrm{d}T_s}/{\mathrm{d}n} + Hw (T_s - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.4. BC_C_THETA_M(BC, PHASE)¶
Specified constant flux, \(C\), in diffusion boundary condition: \({\mathrm{d}{\Theta}_m}/{\mathrm{d}n} + Hw ({\Theta}_m - {\Theta}w_m) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.5. BC_C_X_G(BC, SPECIES)¶
\(1 \le Species \le 100\)
Specified constant gas species mass flux, \(C\), in diffusion boundary condition: \({\mathrm{d}X_g}/{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.6. BC_C_X_S(BC, PHASE, SPECIES)¶
Specified constant solids species mass flux, \(C\), in diffusion boundary condition: \({\mathrm{d}X_s}/{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.7. BC_DEFAULT_WALLS¶
Apply default wall Boundary conditions along the MFIX box (no-slip, adiabatic walls).
12.1.2.8. BC_DT_0(BC)¶
The interval at the beginning when the normal velocity at the boundary is equal to BC_Jet_g0. When restarting a run, this value and BC_Jet_g0 should be specified such that the transient jet continues correctly. MFIX does not store the jet conditions. For MASS_OUTFLOW boundary conditions, BC_DT_0 is the time period to average and print the outflow rates. The adjustment of velocities to get a specified mass or volumetric flow rate is based on the average outflow rate.
12.1.2.9. BC_DT_H(BC)¶
12.1.2.10. BC_DT_L(BC)¶
12.1.2.11. BC_E_TURB_G(BC)¶
12.1.2.12. BC_EP_G(BC)¶
12.1.2.13. BC_EP_S(BC, PHASE)¶
12.1.2.14. BC_GSP_RANDOM_Q(BC, PHASE)¶
Flag to randomize GSP orientation (quaternion) along mass inlet BC.
12.1.2.15. BC_HW_G(BC)¶
Gas phase \(Hw\) for partial slip boundary.
12.1.2.16. BC_HW_S(BC, PHASE)¶
Solids phase \(Hw\) for partial slip boundary.
12.1.2.17. BC_HW_SCALAR(BC, SCALAR EQ.)¶
Scalar transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}S}/{\mathrm{d}n} + Hw (S - Sw) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.18. BC_HW_T_G(BC)¶
Gas phase heat transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}T_g}/{\mathrm{d}n} + Hw (T_g - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.19. BC_HW_T_S(BC, PHASE)¶
Solids phase heat transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}T_s}/{\mathrm{d}n} + Hw (T_s - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.20. BC_HW_THETA_M(BC, PHASE)¶
Transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}{\Theta}_m}/{\mathrm{d}n} + Hw ({\Theta}_m - {\Theta}w_m) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.21. BC_HW_X_G(BC, SPECIES)¶
Gas phase species mass transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}X_g}/{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.22. BC_HW_X_S(BC, PHASE, SPECIES)¶
Solid phase species mass transfer coefficient, \(Hw\), in diffusion boundary condition: \({\mathrm{d}X_s}/{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.23. BC_I_E(BC)¶
12.1.2.24. BC_I_W(BC)¶
12.1.2.25. BC_J_N(BC)¶
12.1.2.26. BC_J_S(BC)¶
12.1.2.27. BC_JET_G0(BC)¶
12.1.2.28. BC_JET_GH(BC)¶
12.1.2.29. BC_JET_GL(BC)¶
12.1.2.30. BC_JJ_M¶
Use a modified version of Johnson and Jackson partial slip BC (BC_JJ_PS BC) with a variable specularity coefficient.
12.1.2.31. BC_JJ_PS(BC)¶
Do not use Johnson and Jackson partial slip bc. Default if granular energy transport equation is not solved. |
Use Johnson and Jackson partial slip bc. Default if granular energy transport equation is solved. |
12.1.2.32. BC_K_B(BC)¶
12.1.2.33. BC_K_T(BC)¶
K index of the top-most cell.
12.1.2.34. BC_K_TURB_G(BC)¶
12.1.2.35. BC_MASSFLOW_G(BC)¶
12.1.2.36. BC_MASSFLOW_G_RAMP_T0(BC)¶
Starting time for ramped gas mass flow rate through the boundary.
12.1.2.37. BC_MASSFLOW_G_RAMP_T1(BC)¶
Ending time for ramped gas mass flow rate through the boundary.
12.1.2.38. BC_MASSFLOW_G_RAMP_V0(BC)¶
Starting value for ramped gas mass flow rate through the boundary.
12.1.2.39. BC_MASSFLOW_G_RAMP_V1(BC)¶
12.1.2.40. BC_MASSFLOW_S(BC, PHASE)¶
12.1.2.41. BC_MASSFLOW_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped solids mass flow rate through the boundary.
12.1.2.42. BC_MASSFLOW_S_RAMP_T1(BC, PHASE)¶
Ending time for ramped solids mass flow rate through the boundary.
12.1.2.43. BC_MASSFLOW_S_RAMP_V0(BC, PHASE)¶
Starting value for ramped solids mass flow rate through the boundary.
12.1.2.44. BC_MASSFLOW_S_RAMP_V1(BC, PHASE)¶
Ending value for ramped solids mass flow rate through the boundary.
12.1.2.45. BC_MI_APPLY_TO_DES(BC)¶
Flag to make the PO BC invisible to discrete solids. Set this flag to .FALSE. to remove this BC for discrete solids.
12.1.2.46. BC_MI_END_TIME(BC)¶
12.1.2.47. BC_MI_START_TIME(BC)¶
Mass inlet starting time. This controls DEM solids only (fluid flow starts at t=0).
12.1.2.48. BC_P_G(BC)¶
Gas pressure at the BC plane.
12.1.2.49. BC_P_G_RAMP_T0(BC)¶
Starting time for ramped gas pressure at the BC plane.
12.1.2.50. BC_P_G_RAMP_T1(BC)¶
Ending time for ramped gas pressure at the BC plane.
12.1.2.51. BC_P_G_RAMP_V0(BC)¶
Starting value for ramped gas pressure at the BC plane.
12.1.2.52. BC_P_G_RAMP_V1(BC)¶
Ending value for ramped gas pressure at the BC plane.
12.1.2.53. BC_PIC_MI_CONST_STATWT(BC, PHASE)¶
Flag to specify the constant statistical weight for inflowing computational particles/parcels. Actual number of parcels will be automatically computed.
12.1.2.54. BC_PO_APPLY_TO_DES(BC)¶
12.1.2.55. BC_PSD_MAX_DP(BC, PHASE)¶
12.1.2.56. BC_PSD_MEAN_DP(BC, PHASE)¶
Mean value of particle size distribution of solids phase in the BC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.2.57. BC_PSD_MIN_DP(BC, PHASE)¶
12.1.2.58. BC_PSD_STDEV(BC, PHASE)¶
Standard deviation of particle size distribution of solids phase in the BC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.2.59. BC_PSD_TYPE(BC, PHASE)¶
Uniform particle size. |
12.1.2.60. BC_ROP_S(BC, PHASE)¶
12.1.2.61. BC_SCALAR(BC, SCALAR EQ.)¶
12.1.2.62. BC_SCALARW(BC, SCALAR EQ.)¶
Specified scalar value at the wall, \(Sw\), in diffusion boundary condition: \({\mathrm{d}S}/{\mathrm{d}n} + Hw (S - Sw) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.63. BC_SQP_RANDOM_Q(BC, PHASE)¶
12.1.2.64. BC_T_G(BC)¶
12.1.2.65. BC_T_G_RAMP_T0(BC)¶
Starting time for ramped gas temperature at the BC plane.
12.1.2.66. BC_T_G_RAMP_T1(BC)¶
Ending time for ramped gas temperature at the BC plane.
12.1.2.67. BC_T_G_RAMP_V0(BC)¶
Starting value for ramped gas temperature at the BC plane.
12.1.2.68. BC_T_G_RAMP_V1(BC)¶
Ending value for ramped gas temperature at the BC plane.
12.1.2.69. BC_T_S(BC, PHASE)¶
12.1.2.70. BC_T_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped solids phase temperature at the BC plane.
12.1.2.71. BC_T_S_RAMP_T1(BC, PHASE)¶
Ending time for ramped solids phase temperature at the BC plane.
12.1.2.72. BC_T_S_RAMP_V0(BC, PHASE)¶
Starting value for ramped solids phase temperature at the BC plane.
12.1.2.73. BC_T_S_RAMP_V1(BC, PHASE)¶
Ending value for ramped solids phase temperature at the BC plane.
12.1.2.74. BC_THETA_M(BC, PHASE)¶
12.1.2.75. BC_THETA_M_RAMP_T0(BC, PHASE)¶
Starting time for ramped solids phase granular temperature at the BC plane.
12.1.2.76. BC_THETA_M_RAMP_T1(BC, PHASE)¶
Ending time for ramped solids phase granular temperature at the BC plane.
12.1.2.77. BC_THETA_M_RAMP_V0(BC, PHASE)¶
Starting value for ramped solids phase granular temperature at the BC plane.
12.1.2.78. BC_THETA_M_RAMP_V1(BC, PHASE)¶
Ending value for ramped solids phase granular temperature at the BC plane.
12.1.2.79. BC_THETAW_M(BC, PHASE)¶
Specified wall value, \({\Theta}w_m\), in diffusion boundary condition: \({\mathrm{d}{\Theta}_m}/{\mathrm{d}n} + Hw ({\Theta}_m - {\Theta}w_m) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.80. BC_TW_G(BC)¶
Specified gas phase wall temperature, when using constant temperature wall, or free stream gas reference temperature \(T_{ref}\), in diffusion boundary condition: \({\mathrm{d}T_g}/{\mathrm{d}n} + Hw (T_g - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.81. BC_TW_S(BC, PHASE)¶
Specified constant solids phase wall temperature, when using constant temperature wall, or free stream solids reference temperature \(T_{ref}\), in diffusion boundary condition: \({\mathrm{d}T_s}/{\mathrm{d}n} + Hw (T_s - T_{ref}) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.82. BC_TYPE(BC)¶
Type of boundary.
The specified boundary condition is ignored. This is useful for turning off some boundary conditions without having to delete them from the file. |
Mass inflow rates for gas and solids phases are specified at the boundary. |
The specified values of gas and solids mass outflow rates at the boundary are maintained, approximately. This condition should be used sparingly for minor outflows, when the bulk of the outflow is occurring through other constant pressure outflow boundaries. |
Inflow from a boundary at a specified constant pressure. To specify as the west, south, or bottom end of the computational region, add a layer of wall cells to the west, south, or bottom of the PI cells. Users need to specify all scalar quantities and velocity components. The specified values of fluid and solids velocities are only used initially as MFIX computes these values at this inlet boundary. |
Outflow to a boundary at a specified constant pressure. To specify as the west, south, or bottom end of the computational region, add a layer of wall cells to the west, south, or bottom of the PO cells. |
Velocity gradients at the wall vanish. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids. A FSW is equivalent to using a PSW with \(Hw=0\). |
All components of the velocity vanish at the wall. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids. A NSW is equivalent to using a PSW with \(Vw=0\) and \(Hw\) undefined. |
Partial slip at the wall implemented as the boundary condition: \({\mathrm{d}V}/{\mathrm{d}n} + Hw (V - Vw) = 0\), where \(n\) is the normal pointing from the fluid into the wall. The coefficients \(Hw\) and \(Vw\) should be specified. For free-slip set \(Hw=0\). For no-slip leave \(Hw\) undefined (\(Hw=\infty\)) and set \(Vw=0\). To set \(Hw=\infty\), leave it unspecified. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids. |
12.1.2.83. BC_U_G(BC)¶
X-axial component of gas velocity at the BC plane.
12.1.2.84. BC_U_G_RAMP_T0(BC)¶
Starting time for ramped x-axial component of gas velocity at the BC plane.
12.1.2.85. BC_U_G_RAMP_T1(BC)¶
Ending time for ramped x-axial component of gas velocity at the BC plane.
12.1.2.86. BC_U_G_RAMP_V0(BC)¶
Starting value for ramped x-axial component of gas velocity at the BC plane.
12.1.2.87. BC_U_G_RAMP_V1(BC)¶
Ending value for ramped x-axial component of gas velocity at the BC plane.
12.1.2.88. BC_U_S(BC, PHASE)¶
X-axial component of solids-phase velocity at the BC plane.
12.1.2.89. BC_U_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped x-axial component of solids-phase velocity at the BC plane.
12.1.2.90. BC_U_S_RAMP_T1(BC, PHASE)¶
Ending time for ramped x-axial component of solids-phase velocity at the BC plane.
12.1.2.91. BC_U_S_RAMP_V0(BC, PHASE)¶
Starting value for ramped x-axial component of solids-phase velocity at the BC plane.
12.1.2.92. BC_U_S_RAMP_V1(BC, PHASE)¶
Ending value for ramped x-axial component of solids-phase velocity at the BC plane.
12.1.2.93. BC_UW_G(BC)¶
Gas phase \(Uw\) for partial slip boundary.
12.1.2.94. BC_UW_S(BC, PHASE)¶
Solids phase \(Uw\) for partial slip boundary.
12.1.2.95. BC_V_G(BC)¶
Y-axial component of gas velocity at the BC plane.
12.1.2.96. BC_V_G_RAMP_T0(BC)¶
Starting time for ramped y-axial component of gas velocity at the BC plane.
12.1.2.97. BC_V_G_RAMP_T1(BC)¶
Ending time for ramped y-axial component of gas velocity at the BC plane.
12.1.2.98. BC_V_G_RAMP_V0(BC)¶
Starting value for ramped y-axial component of gas velocity at the BC plane.
12.1.2.99. BC_V_G_RAMP_V1(BC)¶
Ending value for ramped y-axial component of gas velocity at the BC plane.
12.1.2.100. BC_V_S(BC, PHASE)¶
Y-axial component of solids-phase velocity at the BC plane.
12.1.2.101. BC_V_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped y-axial component of solids-phase velocity at the BC plane.
12.1.2.102. BC_V_S_RAMP_T1(BC, PHASE)¶
Ending time for ramped y-axial component of solids-phase velocity at the BC plane.
12.1.2.103. BC_V_S_RAMP_V0(BC, PHASE)¶
Starting value for ramped y-axial component of solids-phase velocity at the BC plane.
12.1.2.104. BC_V_S_RAMP_V1(BC, PHASE)¶
Ending value for ramped y-axial component of solids-phase velocity at the BC plane.
12.1.2.105. BC_VOLFLOW_G(BC)¶
12.1.2.106. BC_VOLFLOW_G_RAMP_T0(BC)¶
Starting time for ramped volumetric flow rate through the boundary.
12.1.2.107. BC_VOLFLOW_G_RAMP_T1(BC)¶
Ending time for ramped volumetric flow rate through the boundary.
12.1.2.108. BC_VOLFLOW_G_RAMP_V0(BC)¶
Starting value for ramped volumetric flow rate through the boundary.
12.1.2.109. BC_VOLFLOW_G_RAMP_V1(BC)¶
Ending value for ramped volumetric flow rate through the boundary.
12.1.2.110. BC_VOLFLOW_S(BC, PHASE)¶
12.1.2.111. BC_VOLFLOW_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped solids volumetric flow rate through the boundary.
12.1.2.112. BC_VW_G(BC)¶
Gas phase \(Vw\) for partial slip boundary.
12.1.2.113. BC_VW_S(BC, PHASE)¶
Solids phase \(Vw\) for partial slip boundary.
12.1.2.114. BC_W_G(BC)¶
Z-axial component of gas velocity at the BC plane.
12.1.2.115. BC_W_G_RAMP_T0(BC)¶
Starting time for ramped z-axial component of gas velocity at the BC plane.
12.1.2.116. BC_W_G_RAMP_T1(BC)¶
Ending time for ramped z-axial component of gas velocity at the BC plane.
12.1.2.117. BC_W_G_RAMP_V0(BC)¶
Starting value for ramped z-axial component of gas velocity at the BC plane.
12.1.2.118. BC_W_G_RAMP_V1(BC)¶
Ending value for ramped z-axial component of gas velocity at the BC plane.
12.1.2.119. BC_W_S(BC, PHASE)¶
Z-axial component of solids-phase velocity at the BC plane.
12.1.2.120. BC_W_S_RAMP_T0(BC, PHASE)¶
Starting time for ramped z-axial component of solids-phase velocity at the BC plane.
12.1.2.121. BC_W_S_RAMP_T1(BC, PHASE)¶
Ending time for ramped z-axial component of solids-phase velocity at the BC plane.
12.1.2.122. BC_W_S_RAMP_V0(BC, PHASE)¶
Starting value for ramped z-axial component of solids-phase velocity at the BC plane.
12.1.2.123. BC_W_S_RAMP_V1(BC, PHASE)¶
Ending value for ramped z-axial component of solids-phase velocity at the BC plane.
12.1.2.124. BC_WALL_OMEGA(BC, COMPONENT)¶
\(1 \le Component \le 3\)
Moving wall angular velocity. This is only meant to be used for granular DEM, CGP, SQP or GSP models rotate walls. The rotation occurs around the center point defined with BC_WALL_ROT_CENTER. Example: a smooth rotating drum. The first index is the BC ID, the second index is the component (1=x, 2=y, 3=z)
12.1.2.125. BC_WALL_ROT_CENTER(BC, COMPONENT)¶
Moving wall center of rotation. This is only meant to be used for granular DEM, CGP, SQP or GSP models to rotate walls. This keywords is used in conjunction with BC_WALL_OMEGA. Example: a smooth rotating drum. The first index is the BC ID, the second index is the component (1=x, 2=y, 3=z)
12.1.2.126. BC_WALL_VEL(BC, COMPONENT)¶
Moving wall translational velocity. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move walls in the tangential direction. Example: a conveyor belt. The first index is the BC ID, the second index is the component (1=x, 2=y, 3=z)
12.1.2.127. BC_WW_G(BC)¶
Gas phase \(Ww\) for partial slip boundary.
12.1.2.128. BC_WW_S(BC, PHASE)¶
Solids phase \(Ww\) for partial slip boundary.
12.1.2.129. BC_X_E(BC)¶
12.1.2.130. BC_X_G(BC, SPECIES)¶
12.1.2.131. BC_X_S(BC, PHASE, SPECIES)¶
12.1.2.132. BC_X_W(BC)¶
12.1.2.133. BC_XW_G(BC, SPECIES)¶
Specified wall gas species mass fraction, \(Xw\), in diffusion boundary condition: \({\mathrm{d}X_g}/{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.134. BC_XW_S(BC, PHASE, SPECIES)¶
Specified solids species mass fraction at the wall, \(Xw_s\), in diffusion boundary condition: \({\mathrm{d}X_s}/{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
12.1.2.135. BC_Y_N(BC)¶
12.1.2.136. BC_Y_S(BC)¶
12.1.2.137. BC_Z_B(BC)¶
12.1.2.138. BC_Z_T(BC)¶
