12.1.6. Gas phase¶
12.1.6.1. C_PG0¶
12.1.6.2. DIF_G0¶
12.1.6.3. HB_GAMA_C¶
Strain rate cutoff [1/s] in Herschel-Bulkley viscosity law.
12.1.6.4. HB_K0¶
Consistency factor [Pa.s^n] in Herschel-Bulkley viscosity law.
12.1.6.5. HB_N¶
Power law index (dimensionless) in Herschel-Bulkley viscosity law.
0 < HB_n < 1 : Shear thinning fluid
HB_n = 1 : Bingham fluid
HB_n > 1 : Shear thickening fluid
12.1.6.6. HB_TAU0¶
Bingham yield stress [Pa] in Herschel-Bulkley viscosity law.
12.1.6.7. K_G0¶
12.1.6.8. MU_G0¶
Specified constant gas viscosity [Pa.s in SI].
12.1.6.9. MU_G_MODEL¶
Gas viscosity model (default is Sutherland’s law).
Constant viscosity |
Sutherland’s law |
Herschel-Bulkley (non-Newtonian) model |
User-defined function |
12.1.6.10. MW_AVG¶
12.1.6.11. MW_G(SPECIES)¶
\(1 \le Species \le 100\)
12.1.6.12. NMAX_G¶
12.1.6.13. RO_G0¶
12.1.6.14. SL_MUREF¶
Reference gas viscosity [Pa.s in SI] in the Sutherland’s law.
12.1.6.15. SL_S¶
Sutherland constant [K] in the Sutherland’s law.
12.1.6.16. SL_TREF¶
Reference temperature [K] in the Sutherland’s law.
12.1.6.17. SPECIES_ALIAS_G(SPECIES)¶
12.1.6.18. SPECIES_G(SPECIES)¶
