12.1.10. Numerical parameters
This section contains keywords for defining numerical parameters. Keywords related to solving the governing equations (e.g., LEQ_IT, DISCRETIZE, UR_FAC, etc.) are dimensioned for the ten types of equations:
Index
Equation Type
Gas Pressure
Solids Volume Fraction
3
Gas and Solids U Momentum Equation
4
Gas and Solids V Momentum Equation
5
Gas and Solids W Momentum Equation
6
Gas and Solids Energy Equations (Temperature)
7
Gas and Solids Species Mass Fractions
8
Granular Temperature
User-Defined Scalar and K-Epsilon Equation
DES Diffusion Equation
For example, LEQ_IT(3) = 10, specifies to use 10 iterations within the linear equation solver for the U Momentum Equations (of type 3).
12.1.10.1. CHI_SCHEME
Table 12.47 Valid Values
Do not use the chi-scheme.
Use the chi-scheme correction.
12.1.10.2. CN_ON
Table 12.48 Valid Values
Implicit Euler based temporal discretization scheme employed (first-order accurate in time).
Two-step implicit Runge-Kutta method based temporal discretization scheme employed. This method should be second- order accurate in time excluding pressure terms and restart time step which are first-order accurate. However, as of 2015, testing shows that second-order accuracy is not observed.
12.1.10.3. DEF_COR
Table 12.49 Valid Values
Use down-wind factor method (default).
Use deferred correction method.
12.1.10.4. DETECT_STALL
Table 12.50 Valid Values
Continue iterating if residuals stall.
Reduce time step if residuals stall.
12.1.10.5. DIL_EP_S
12.1.10.6. DISCRETIZE(EQUATION ID NUMBER)
Table 12.51 Valid Values
First-order upwinding.
First-order upwinding (using down-wind factors).
3
Smart.
Superbee (recommended method).
5
QUICKEST (does not work).
4
ULTRA-QUICK.
7
van Leer.
6
MUSCL.
8
minmod.
Central (often unstable; useful for testing).
12.1.10.7. DO_TRANSPOSE
12.1.10.8. EPP_DEN
12.1.10.9. FPE_TRAP_INVALID
Terminate simulation and print stack trace on math domain errors (square root or log of negative value, etc).
12.1.10.10. FPE_TRAP_OVERFLOW
Terminate simulation and print stack trace on numerical overflow.
12.1.10.11. FPE_TRAP_ZERO
Terminate simulation and print stack trace on zero division errors.
12.1.10.12. ICHECK_BICGS
12.1.10.13. LEQ_IT(EQUATION ID NUMBER)
12.1.10.14. LEQ_METHOD(EQUATION ID NUMBER)
Table 12.52 Valid Values
SOR - Successive over-relaxation
BiCGSTAB - Biconjugate gradient stabilized.
3
GMRES - Generalized minimal residual method
5
CG - Conjugate gradient
12.1.10.15. LEQ_PC(EQUATION ID NUMBER)
Table 12.53 Valid Values
No preconditioner
LINE
Line relaxation
DIAG
Diagonal Scaling
12.1.10.16. LEQ_SWEEP(EQUATION ID NUMBER)
Table 12.54 Valid Values
RSRS
(Red/Black Sweep, Send Receive) repeated twice
ISIS
(Sweep in I, Send Receive) repeated twice
JSJS
(Sweep in J, Send Receive) repeated twice
KSKS
(Sweep in K, Send Receive) repeated twice
ASAS
(All Sweep, Send Receive) repeated twice
12.1.10.17. LEQ_TOL(EQUATION ID NUMBER)
12.1.10.18. MAX_INLET_VEL_FAC
12.1.10.19. MAX_NIT
12.1.10.20. NORM_G
12.1.10.21. NORM_S
12.1.10.22. OPT_PARALLEL
12.1.10.23. PPG_DEN
12.1.10.24. TMAX
Maximum temperature allowed in the system (K). It is strongly encouraged to keep the default value of 4000.0.
12.1.10.25. TMIN
Minimum temperature allowed in the system (K). It is strongly encouraged to keep the default value of 50.0.
12.1.10.26. TOL_DIVERGE
12.1.10.27. TOL_RESID
Maximum residual at convergence (continuity + momentum) [1.0d-3].
12.1.10.28. TOL_RESID_SCALAR
12.1.10.29. TOL_RESID_T
12.1.10.30. TOL_RESID_TH
12.1.10.31. TOL_RESID_X
12.1.10.32. TOL_SUM_RESID_ABS
12.1.10.33. UR_F_GS
  • 0 updates F_GS every time step
  • 1 updates F_GS every iteration
12.1.10.34. UR_FAC(EQUATION ID NUMBER)
12.1.10.35. UR_KTH_SML
12.1.10.36. USE_DOLOOP
12.1.10.37. ZERO_EP_S
12.1.10.38. ZERO_X_GS
