12.1.13. Particle-in-cell model (PIC)
This section contains keywords relating to the Particle-in-cell model (PIC).
12.1.13.1. FRIC_EXP_PIC
12.1.13.2. FRIC_NON_SING_FAC
12.1.13.3. MPPIC_COEFF_EN1
12.1.13.4. MPPIC_COEFF_EN_WALL
12.1.13.5. MPPIC_COEFF_ET_WALL
12.1.13.6. MPPIC_VELFAC_COEFF
12.1.13.7. PIC_CD_E
12.1.13.8. PIC_CFL
12.1.13.9. PIC_CFL_CONTROL
12.1.13.10. PIC_CFL_PARCEL_FRACTION
12.1.13.11. PIC_COLLISION_DAMPING
12.1.13.12. PSFAC_FRIC_PIC
