12.1.7. Geometry and discretization¶
12.1.7.1. COORDINATES¶
Cartesian coordinates. |
Cylindrical coordinates. |
12.1.7.2. CPX(CTRL)¶
\(0 \le CTRL \le MAX{\_}CP\)
12.1.7.3. CPY(CTRL)¶
12.1.7.4. CPZ(CTRL)¶
12.1.7.5. CYCLIC_X¶
No cyclic condition at x-boundary. |
Cyclic condition at x-boundary. |
12.1.7.6. CYCLIC_X_PD¶
Cyclic condition with pressure drop at x-boundary. |
12.1.7.7. CYCLIC_Y¶
No cyclic condition at y-boundary. |
12.1.7.8. CYCLIC_Y_PD¶
Cyclic condition with pressure drop at y-boundary. |
12.1.7.9. CYCLIC_Z¶
No cyclic condition at z-boundary. |
Cyclic condition at z-boundary. |
12.1.7.10. CYCLIC_Z_PD¶
Cyclic condition with pressure drop at z-boundary. |
12.1.7.11. CYLINDRICAL_2D¶
12.1.7.12. DELP_X¶
12.1.7.13. DELP_Y¶
12.1.7.14. DELP_Z¶
12.1.7.15. DX(CELL)¶
\(0 \le Cell \le 5000\)
Use uniform mesh size with higher-order discretization methods.
DX should be kept uniform in cylindrical coordinates for strict momentum conservation.
12.1.7.16. DY(CELL)¶
12.1.7.17. DZ(CELL)¶
12.1.7.18. ERX(CTRL)¶
\(1 \le CTRL \le MAX{\_}CP\)
12.1.7.19. ERY(CTRL)¶
12.1.7.20. ERZ(CTRL)¶
12.1.7.21. FIRST_DX(CTRL)¶
Value of first DX in a segment (x-direction). A negative value will copy DX from previous segment (if available).
12.1.7.22. FIRST_DY(CTRL)¶
12.1.7.23. FIRST_DZ(CTRL)¶
12.1.7.24. FLUX_G¶
12.1.7.25. I_CYL_NUM¶
12.1.7.26. I_CYL_TRANSITION¶
Two cell smoothing transition. |
One cell smoothing transition. |
No smoothing. |
12.1.7.27. IMAX¶
Number of cells in the x (r) direction.
12.1.7.28. JMAX¶
Number of cells in the y-direction.
12.1.7.29. KMAX¶
Number of cells in the z-direction.
12.1.7.30. LAST_DX(CTRL)¶
Value of last DX in a segment (x-direction). A negative value will copy DX from next segment (if available).
12.1.7.31. LAST_DY(CTRL)¶
12.1.7.32. LAST_DZ(CTRL)¶
12.1.7.33. NCX(CTRL)¶
12.1.7.34. NCY(CTRL)¶
12.1.7.35. NCZ(CTRL)¶
12.1.7.36. NO_K¶
Z axis in Cartesian coordinate system
Theta in cylindrical coordinate system
3D simulation. |
2D simulation. |
12.1.7.37. SHEAR¶
12.1.7.38. V_SH¶
12.1.7.39. X_MAX¶
Simulation domain upper bound in the x-direction.
12.1.7.40. X_MIN¶
Simulation domain lower bound in the x-direction.
12.1.7.41. XLENGTH¶
Simulation domain length in the x (r) direction.
12.1.7.42. XMIN¶
12.1.7.43. Y_MAX¶
Simulation domain upper bound in the y-direction.
12.1.7.44. Y_MIN¶
Simulation domain lower bound in the y-direction.
12.1.7.45. YLENGTH¶
Simulation domain length in the y-direction.
12.1.7.46. Z_MAX¶
Simulation domain upper bound in the z-direction.
12.1.7.47. Z_MIN¶
Simulation domain lower bound in the z-direction.
12.1.7.48. ZLENGTH¶
