12.1.5. Discrete element model (DEM)
12.1.5.1. Discrete Element - Common
12.1.5.1.1. DES_DIFFUSE_WIDTH
12.1.5.1.2. DES_EPG_CLIP
12.1.5.1.3. DES_EXPLICITLY_COUPLED
Table 12.20 Valid Values
12.1.5.1.4. DES_INTERP_MEAN_FIELDS
Table 12.21 Valid Values
12.1.5.1.5. DES_INTERP_ON
Table 12.22 Valid Values
12.1.5.1.6. DES_INTERP_SCHEME
Table 12.23 Valid Values
Do not use interpolation.
GARG_2012
SQUARE_DPVM
Divided particle volume method: Information is interpolated to/from a particle’s position using a square filter of size DES_INTERP_WIDTH.
LINEAR_HAT
Linear interpolation: Hat functions are used to distribute particle information. PIC only.
DPVM_SATELLITE
Divided particle volume method using satellites.
12.1.5.1.7. DES_INTERP_WIDTH
12.1.5.1.8. DES_INTG_METHOD
Time stepping scheme. Note that DEM solids species mass fraction always use firt-order Euler scheme regardless of this setting.
Table 12.24 Valid Values
EULER
First-order Euler scheme.
ADAMS_BASHFORTH
Second-order ADAMS_BASHFORTH scheme. (DEM only)
12.1.5.1.9. DES_ONEWAY_COUPLED
Run one-way coupled simulations [default .FALSE.]. If set, the fluid does not see the particles in terms of drag force. The effect of particle volume is still felt by the fluid through non-unity voidage values.
Table 12.25 Valid Values
12.1.5.1.10. DESGRIDSEARCH_IMAX
12.1.5.1.11. DESGRIDSEARCH_JMAX
12.1.5.1.12. DESGRIDSEARCH_KMAX
12.1.5.1.13. GENER_PART_CONFIG
Table 12.26 Valid Values
Generate particle configuration based on the initial condition parameters. Data provided in the particle_input.dat file, if present, is ignored.
Particle position and velocity data are provided in the particle_input.dat file. A runtime error occurs if this file is not provided.
12.1.5.1.14. PARTICLES
Number of particles to be read in from the particle_input.dat file. This value is ignored when using automatic particle generation. A simulation with a mass inflow BC can start without solids by setting PARTICLES = 0.
12.1.5.2. Discrete Element Model
12.1.5.2.1. ASPERITIES
12.1.5.2.2. DES_BUFF_RESIZE_FACTOR
12.1.5.2.3. DES_COLL_MODEL
Table 12.27 Valid Values
LSD
HERTZIAN
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG V_POISSON, VW_POISSON.
12.1.5.2.4. DES_CONV_CORR
Table 12.28 Valid Values
RANZ_1952
GUNN
WAKAO
TAVASSOLI
12.1.5.2.5. DES_EM(PHASE)
Emissivity of solids phase.
12.1.5.2.6. DES_EN_INPUT(INDEX)
12.1.5.2.7. DES_EN_WALL_INPUT(INDEX)
  • \(1 \le Index \le MMAX\)
12.1.5.2.8. DES_ET_INPUT(INDEX)
12.1.5.2.9. DES_ET_WALL_INPUT(INDEX)
12.1.5.2.10. DES_ETAT_FAC
Table 12.29 Valid Values
UNDEFINED
12.1.5.2.11. DES_ETAT_W_FAC
Table 12.30 Valid Values
UNDEFINED
12.1.5.2.12. DES_MIN_COND_DIST
12.1.5.2.14. DLB_DT
Table 12.32 Valid Values
UNDEFINED
>0
12.1.5.2.15. DLB_EGW
Table 12.33 Valid Values
>=0
12.1.5.2.16. DTSOLID_FACTOR
12.1.5.2.17. DTSOLID_UPDATE_DT
12.1.5.2.18. E_YOUNG(PHASE)
12.1.5.2.19. E_YOUNG_ACTUAL(PHASE)
12.1.5.2.20. EW_YOUNG
12.1.5.2.21. EW_YOUNG_ACTUAL
12.1.5.2.22. FACTOR_RLM
12.1.5.2.23. FLPC
12.1.5.2.24. HAMAKER_CONSTANT
12.1.5.2.25. KN
12.1.5.2.26. KN_W
12.1.5.2.27. KT_FAC
12.1.5.2.28. KT_W_FAC
12.1.5.2.29. MEW
12.1.5.2.30. MEW_R
12.1.5.2.31. MEW_RW
12.1.5.2.32. MEW_W
12.1.5.2.33. MINIMIZE_DES_FACET_LIST
12.1.5.2.34. NEIGHBOR_SEARCH_N
12.1.5.2.35. NEIGHBOR_SEARCH_RAD_RATIO
12.1.5.2.36. NFACTOR
12.1.5.2.37. REMOVE_ROGUE_PARTICLES
12.1.5.2.38. USE_COHESION
12.1.5.2.39. USE_VDH_DEM_MODEL
12.1.5.2.40. V_POISSON(PHASE)
12.1.5.2.41. V_POISSON_ACTUAL(PHASE)
12.1.5.2.42. VAN_DER_WAALS
12.1.5.2.43. VDW_INNER_CUTOFF
12.1.5.2.44. VDW_OUTER_CUTOFF
12.1.5.2.45. VW_POISSON
12.1.5.2.46. VW_POISSON_ACTUAL
12.1.5.2.47. WALL_HAMAKER_CONSTANT
12.1.5.2.48. WALL_VDW_INNER_CUTOFF
12.1.5.2.49. WALL_VDW_OUTER_CUTOFF
12.1.5.3. Particles in Cell
12.1.5.3.1. FRIC_EXP_PIC
12.1.5.3.2. FRIC_NON_SING_FAC
12.1.5.3.3. MPPIC_COEFF_EN1
12.1.5.3.4. MPPIC_COEFF_EN_WALL
12.1.5.3.5. MPPIC_COEFF_ET_WALL
12.1.5.3.6. MPPIC_VELFAC_COEFF
12.1.5.3.7. PIC_CD_E
12.1.5.3.8. PIC_CFL
12.1.5.3.9. PIC_CFL_CONTROL
12.1.5.3.10. PIC_CFL_PARCEL_FRACTION
12.1.5.3.11. PIC_COLLISION_DAMPING
12.1.5.3.12. PSFAC_FRIC_PIC
