12.1.17. Solids phase
12.1.17.1. C_PS0(PHASE)
Applies to solids model(s): TFM, DEM
12.1.17.2. CGP_D_P0(PHASE)
12.1.17.3. CGP_STAT_WT(PHASE)
12.1.17.4. D_P0(PHASE)
12.1.17.5. DIL_FACTOR_VSD
12.1.17.6. DIL_INERT_X_VSD(PHASE)
12.1.17.7. GSP_Q1(PHASE)
Glued sphere particle quaternion q1.
12.1.17.8. GSP_Q2(PHASE)
Glued sphere particle quaternion q2.
12.1.17.9. GSP_Q3(PHASE)
Glued sphere particle quaternion q3.
12.1.17.10. GSP_Q4(PHASE)
Glued sphere particle quaternion q4.
12.1.17.11. INERT_SPECIES(PHASE)
12.1.17.12. K_S0(PHASE)
12.1.17.13. KS_MODEL(PHASE)
Table 12.83 Valid Values
CONST_EFF
USR
Bauer
Musser
12.1.17.14. MMAX
Number of solids phases.
12.1.17.15. MW_S(PHASE, SPECIES)
12.1.17.16. NGLUEDPARTICLES
Number of glued sphere particles
12.1.17.17. NMAX_S(PHASE)
12.1.17.18. RO_S0(PHASE)
12.1.17.19. RO_XS0(PHASE, SPECIES)
12.1.17.20. SOLIDS_MODEL(PHASE)
Table 12.84 Valid Values
TFM
Two-fluid model (continuum)
DEM
Discrete element model
CGP
Coarse-grained particle DEM
SQP
Superquadric particle DEM
GSP
Glued sphere particle DEM
PIC
Multiphase particle-in-cell
12.1.17.21. SPECIES_ALIAS_S(PHASE, SPECIES)
12.1.17.22. SPECIES_S(PHASE, SPECIES)
12.1.17.23. SQP_A(PHASE)
12.1.17.24. SQP_B(PHASE)
12.1.17.25. SQP_C(PHASE)
12.1.17.26. SQP_CONTACT_EVOLUTION
12.1.17.27. SQP_INIT_CONTACT_EVOLUTION
12.1.17.28. SQP_M(PHASE)
12.1.17.29. SQP_N(PHASE)
12.1.17.30. SQP_Q1(PHASE)
12.1.17.31. SQP_Q2(PHASE)
12.1.17.32. SQP_Q3(PHASE)
12.1.17.33. SQP_Q4(PHASE)
12.1.17.34. X_S0(PHASE, SPECIES)
