12.1.3. Cartesian grid
12.1.3.1. ADJUST_PROC_DOMAIN_SIZE
12.1.3.2. ALPHA_MAX
12.1.3.3. BAR_CHAR
Character used to create the progress bar.
12.1.3.4. BAR_RESOLUTION
12.1.3.5. BAR_WIDTH
12.1.3.6. BC_ID_Q(QUADRIC ID)
\(1 \le Quadric ID \le 500\)
Boundary condition flag.
12.1.3.7. BEND_R1(QUADRIC ID)
12.1.3.8. BEND_R2(QUADRIC ID)
Bend Radius 2 (used when QUADRIC_FORM = BEND*), BEND_R1>BEND_R2.
12.1.3.9. BEND_THETA1(QUADRIC ID)
12.1.3.10. BEND_THETA2(QUADRIC ID)
12.1.3.11. C2C_R1(QUADRIC ID)
12.1.3.12. C2C_R2(QUADRIC ID)
12.1.3.13. C2C_Y1(QUADRIC ID)
12.1.3.14. C2C_Y2(QUADRIC ID)
12.1.3.15. CAD_PROPAGATE_ORDER
Propagation occurs in unique cell index order, from IJK=IJKSTART3 to IJKEND3, one neighbor at a time (West, East, South, North, Bottom, Top) |
Propagation occurs in the I, followed by J, and K directions |
Propagation occurs in the J, followed by K, and I directions |
Propagation occurs in the K, followed by I, and J directions |
12.1.3.16. CARTESIAN_GRID
Do not use Cartesian grid cut cell technique. |
Use Cartesian grid cut cell technique. |
12.1.3.17. CG_SAFE_MODE
Run code in safe mode.
Performs initial preprocessing but use all original MFiX subroutines during flow solution (using only cell volumes and areas of cut cells). |
Runs the code with modified subroutines for cut cell treatment. |
12.1.3.18. CG_UR_FAC
12.1.3.19. CLIP_XMAX(QUADRIC ID)
12.1.3.20. CLIP_XMIN(QUADRIC ID)
12.1.3.21. CLIP_YMAX(QUADRIC ID)
12.1.3.22. CLIP_YMIN(QUADRIC ID)
12.1.3.23. CLIP_ZMAX(QUADRIC ID)
12.1.3.24. CLIP_ZMIN(QUADRIC ID)
12.1.3.25. DIM_FACETS_PER_CELL
Maximum number of STL facets per cell.
12.1.3.26. DISTRIBUTE_SMALL_CUT_CELLS
Option to distribute small cut cells among their neighbors.
12.1.3.27. DQUADRIC(QUADRIC ID)
12.1.3.28. DWALL_BRUTE_FORCE
Brute force calculation of wall distance.
12.1.3.29. F_DASHBOARD
12.1.3.30. FAC_DIM_MAX_CUT_CELL
12.1.3.31. FLIP_STL_NORMALS(BC)
\(1 \le BC \le 500\)
Option to flip STL facet normals. The index corresponds to the BC ID the STL file is applied to.
Flip normals |
Do not flip normals |
12.1.3.32. FLUID_IN_CLIPPED_REGION(QUADRIC ID)
Remove cells from computational domain. |
Treat cells as fluid cells. |
12.1.3.33. GROUP_Q(GROUP ID, QUADRIC ID)
\(1 \le Group ID \le DIM{\_}GROUP\)
12.1.3.34. GROUP_RELATION(GROUP ID)
A point belongs to the computational domain if at least one of f(x,y,z) among all quadrics is negative. |
A point belongs to the computational domain if all of f(x,y,z) among all quadrics are negative. |
When quadrics intersect along planes that are perpendicular to either the x, y, or z-axis, quadrics can be smoothly combined in a piecewise manner. |
12.1.3.35. GROUP_SIZE(GROUP ID)
12.1.3.36. HALF_ANGLE(QUADRIC ID)
12.1.3.37. ITERMAX_INT
12.1.3.38. LAMBDA_X(QUADRIC ID)
12.1.3.39. LAMBDA_Y(QUADRIC ID)
12.1.3.40. LAMBDA_Z(QUADRIC ID)
12.1.3.41. MINIMIZE_SEND_RECV
12.1.3.42. N_GROUP
Number of group(s) of quadrics (<=50).
12.1.3.43. N_QUADRIC
12.1.3.44. N_USR_DEF
Number of user-defined functions (currently limited to 0 or 1). If set to 1, the geometry is defined in the user subroutine eval_usr_fct.f.
Do not use user-defined function |
Use one user-defined function |
12.1.3.45. N_X(QUADRIC ID)
12.1.3.46. N_Y(QUADRIC ID)
12.1.3.47. N_Z(QUADRIC ID)
12.1.3.48. NOC_PHI_DIF
Flag to turn off non-orthogonality terms in phi diffusion derivatives.
12.1.3.49. NODESI_REPORT
12.1.3.50. NODESJ_REPORT
12.1.3.51. NODESK_REPORT
12.1.3.52. OUT_MSH_VALUE
Defines value of f outside of the .msh geometry. a value of 1.0 means the domain outside of the .msh geometry is excluded from computation, i.e., an internal flow is computed.
model an external flow |
model an internal flow |
12.1.3.53. OUT_STL_VALUE
Defines value of F_STL outside of the STL geometry. A value of 1.0 means the domain outside of the STL geometry is excluded from computation, i.e., an internal flow is computed. Note: This depends on the direction of the facet normal vectors.
12.1.3.54. PG_OPTION
Use maximum of (east/west), (north/south), and (top/bottom) pairs of velocity cells. |
Use both (east/west), (north/south), and (top/bottom) areas of velocity cells. |
Use east, north and top areas of pressure cell (same as standard cells). |
12.1.3.55. PIECE_XMAX(QUADRIC ID)
12.1.3.56. PIECE_XMIN(QUADRIC ID)
12.1.3.57. PIECE_YMAX(QUADRIC ID)
12.1.3.58. PIECE_YMIN(QUADRIC ID)
12.1.3.59. PIECE_ZMAX(QUADRIC ID)
12.1.3.60. PIECE_ZMIN(QUADRIC ID)
12.1.3.61. PRINT_PROGRESS_BAR
Print a progress bar during each major step of preprocessing stage.
12.1.3.62. PRINT_WARNINGS
Prints any warning message encountered during preprocessing on the screen.
12.1.3.63. QUADRIC_FORM(QUADRIC ID)
Use normal form, as defined in equation (1). The LAMDBAs and D must be defined |
Plane. Needs to define N_X,N_Y,N_Z (unit normal vector pointing away from fluid cells). |
Cylinder aligned with x-axis, internal flow. Needs to define RADIUS(QID). |
Cylinder aligned with x-axis, external flow. Needs to define RADIUS(QID). |
Cylinder aligned with y-axis, internal flow. Needs to define RADIUS(QID). |
Cylinder aligned with y-axis, external flow. Needs to define RADIUS(QID). |
Cylinder aligned with z-axis, internal flow. Needs to define RADIUS(QID). |
Cylinder aligned with z-axis, external flow. Needs to define RADIUS(QID). |
Cone aligned with x-axis, internal flow. Needs to define HALF_ANGLE(QID). |
Cone aligned with y-axis, internal flow. Needs to define HALF_ANGLE(QID). |
Cone aligned with z-axis, internal flow. Needs to define HALF_ANGLE(QID). |
Sphere, internal flow. Needs to define RADIUS(QID). |
Sphere, external flow. Needs to define RADIUS(QID). |
Cylinder-to-cylinder conical junction, internal flow. Needs to be defined between two cylinders. |
Torus, internal flow. Needs to define TORUS_R1(QID) and TORUS_R2(QID).A torus is not a quadric surface but is defined as a basic shape. |
Torus, external flow. Needs to define TORUS_R1(QID) and TORUS_R2(QID). |
Pair of parallel cylinders (y-direction), capped at both ends by a cylinder at 90 degree angle to create a U-shaped coil. Needs UCOIL_R1, UCOIL_R2, UCOIL_Y1, UCOIL_Y2. |
Bend between two cylinders in the XY plane, Needs BEND_R1,BEND_R2,BEND_THETA1,BEND_THETA2. |
connects two vertical cylinders by a conical section. Needs C2C_R1,C2C_R2,C2C_Y1,C2C_Y2. |
Reactor, made of two vertical cylinders, connected by a conical section. Each cylinder is rounded and closed by a conical cap. Needs REACTOR1_R1,REACTOR1_R2,REACTOR1_Y1,REACTOR1_Y2, REACTOR1_YR1,REACTOR1_YR2,REACTOR1_RR1,REACTOR1_RR2, REACTOR1_THETA1,REACTOR1_THETA2. |
12.1.3.64. QUADRIC_SCALE
12.1.3.65. RADIUS(QUADRIC ID)
12.1.3.66. RAY_DIR
Ray direction when propagating CAD value
12.1.3.67. RE_INDEXING
12.1.3.68. REACTOR1_R1(QUADRIC ID)
12.1.3.69. REACTOR1_R2(QUADRIC ID)
12.1.3.70. REACTOR1_RR1(QUADRIC ID)
12.1.3.71. REACTOR1_RR2(QUADRIC ID)
12.1.3.72. REACTOR1_THETA1(QUADRIC ID)
12.1.3.73. REACTOR1_THETA2(QUADRIC ID)
12.1.3.74. REACTOR1_Y1(QUADRIC ID)
12.1.3.75. REACTOR1_Y2(QUADRIC ID)
12.1.3.76. REACTOR1_YR1(QUADRIC ID)
12.1.3.77. REACTOR1_YR2(QUADRIC ID)
12.1.3.78. RELATION_WITH_PREVIOUS(GROUP ID)
A point belongs to the computational domain if f-value for the current group or f-value for the combination of previous groups is negative. |
A point belongs to the computational domain if f-value for the current group and f-value for the combination of previous groups is negative. |
12.1.3.79. REPORT_BEST_DOMAIN_SIZE
12.1.3.80. SCALE_MSH
12.1.3.81. SCALE_STL
12.1.3.82. SET_CORNER_CELLS
Some cut cells may be treated as corner cells. |
Do not treat cut cells as corner cells. |
12.1.3.83. STL_BC_ID
Boundary condition flag for the STL geometry
12.1.3.84. STL_NB_ANGLE
Angle (degrees) to detect if two STL facets are nearly aligned. This is used to ignore edge collision in DEM simulations. Particle-edge collision will be ignored if the angle between two facets is smaller than STL_NB_ANGLE.
12.1.3.85. STL_SMALL_ANGLE
Smallest angle accepted for valid STL triangles (in degrees). Triangles having an angle smaller that this value will be ignored.
12.1.3.86. T_X(QUADRIC ID)
Translation in x-direction.
12.1.3.87. T_Y(QUADRIC ID)
Translation in y-direction.
12.1.3.88. T_Z(QUADRIC ID)
Translation in z-direction.
12.1.3.89. THETA_X(QUADRIC ID)
12.1.3.90. THETA_Y(QUADRIC ID)
12.1.3.91. THETA_Z(QUADRIC ID)
12.1.3.92. TOL_DELH
Tolerance used to limit acceptable values of normal distance to the wall (expressed as a fraction of cell diagonal, between 0.0 and 1.0).
12.1.3.93. TOL_F
12.1.3.94. TOL_MERGE
Tolerance used to remove duplicate nodes (expressed as a fraction of cell diagonal, between 0.0 and 1.0).
12.1.3.95. TOL_MSH
12.1.3.96. TOL_POLY
12.1.3.97. TOL_SMALL_AREA
Tolerance used to detect small faces (expressed as a fraction of original face area, between 0.0 and 1.0).
12.1.3.98. TOL_SMALL_CELL
Tolerance used to detect small cells (expressed as a fraction of cell volume, between 0.0 and 1.0).
12.1.3.99. TOL_SNAP(DIRECTION)
\(1 \le Direction \le 3\)
Tolerance used to snap an intersection point onto an existing cell corner (expressed as a fraction of edge length, between 0.0 and 0.5). For stretched grids, three values can be entered in the x, y and z directions.
12.1.3.100. TOL_STL
12.1.3.101. TOL_STL_DP
12.1.3.102. TORUS_R1(QUADRIC ID)
12.1.3.103. TORUS_R2(QUADRIC ID)
12.1.3.104. TX_MSH
12.1.3.105. TX_STL
12.1.3.106. TY_MSH
12.1.3.107. TY_STL
12.1.3.108. TZ_MSH
12.1.3.109. TZ_STL
12.1.3.110. UCOIL_R1(QUADRIC ID)
12.1.3.111. UCOIL_R2(QUADRIC ID)
12.1.3.112. UCOIL_Y1(QUADRIC ID)
12.1.3.113. UCOIL_Y2(QUADRIC ID)
12.1.3.114. USE_MSH
Do not use .msh file. |
Read geometry (for 3d geometry only) from geometry.msh. |
12.1.3.115. USE_POLYGON
Do not use polygons. |
Read polygon data (for 2d geometry only) from poly.dat. |
12.1.3.116. USE_STL
Do not use STL file. |
Read triangulated geometry (for 3d geometry only) from geometry_####.stl. |
12.1.3.117. WRITE_DASHBOARD
