12.1.8. Initial conditions (IC)
Each initial condition is specified over a rectangular region (or
pie-shaped for cylindrical coordinates) that corresponds to the scalar numerical
grid. These are 3D regions: X_w X_e, Y_s Y_n, and Z_t Z_b. The
region is defined by the constant coordinates of each of the six faces, which
may be specified as the physical coordinates or the cell indices. The physical
coordinates are easier to specify than the cell indices. If cell sizes are not
small enough to resolve a region specified using physical coordinates, MFIX will
indicate this problem with an error message.
12.1.8.1. IC_DES_ABORT_ON_FAILED_SEEDING(IC, PHASE)
\(1 \le IC \le 500\)
Flag to abort if unsuccessful seeding occurs.
12.1.8.2. IC_DES_LATTICE(IC, PHASE)
Type of initial lattice distribution (simple cubic or hexagonal) to the entire IC region.
Particles are distributed on a hexagonal close-packed lattice. |
Particles are distributed on a cubical lattice. |
12.1.8.3. IC_DES_NP(IC, PHASE)
12.1.8.4. IC_DES_RAND(IC, PHASE)
12.1.8.5. IC_DES_RAND_FACTOR_X(IC, PHASE)
12.1.8.6. IC_DES_RAND_FACTOR_Y(IC, PHASE)
12.1.8.7. IC_DES_RAND_FACTOR_Z(IC, PHASE)
12.1.8.8. IC_DES_SM(IC, PHASE)
12.1.8.9. IC_DES_SPACE_FACTOR_X(IC, PHASE)
12.1.8.10. IC_DES_SPACE_FACTOR_Y(IC, PHASE)
12.1.8.11. IC_DES_SPACE_FACTOR_Z(IC, PHASE)
12.1.8.12. IC_DES_SPACING(IC, PHASE)
Spacing between particle within initial lattice distribution (expressed as a fraction of particle diameter) to the entire IC region.
12.1.8.13. IC_DES_TIGHT_BOUNDARY_SPACING(IC, PHASE)
Tight spacing near the boundary of the IC region.
12.1.8.14. IC_E_TURB_G(IC)
12.1.8.15. IC_EP_G(IC)
12.1.8.16. IC_EP_S(IC, PHASE)
12.1.8.17. IC_GAMA_RG(IC)
Gas phase radiation coefficient in the IC region. Modify file energy_mod.f to change the source term.
12.1.8.18. IC_GAMA_RS(IC, PHASE)
12.1.8.19. IC_GSP_RANDOM_Q(IC, PHASE)
Initialize GSP with random orientation (quaternion) in the IC region.
12.1.8.20. IC_I_E(IC)
12.1.8.21. IC_I_W(IC)
12.1.8.22. IC_J_N(IC)
12.1.8.23. IC_J_S(IC)
12.1.8.24. IC_K_B(IC)
12.1.8.25. IC_K_T(IC)
K index of the top-most wall.
12.1.8.26. IC_K_TURB_G(IC)
12.1.8.27. IC_L_SCALE(IC)
12.1.8.28. IC_OVERRIDE_PART_INPUT(IC, PHASE)
Initial conditions take precedence over data in particle_inpupt.dat file for this region and solids phase.
12.1.8.29. IC_P_G(IC)
12.1.8.30. IC_P_STAR(IC)
12.1.8.31. IC_PIC_CONST_STATWT(IC, PHASE)
Flag to specify the initial constant statistical weight for computational particles/parcels. Actual number of parcels will be automatically computed.
12.1.8.32. IC_PSD_MAX_DP(IC, PHASE)
Initial maximum particle size of particle size distribution of solids phase in the IC region. Required for a UNIFORM distribution.
12.1.8.33. IC_PSD_MEAN_DP(IC, PHASE)
Initial mean value of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.8.34. IC_PSD_MIN_DP(IC, PHASE)
Initial minimum particle size of particle size distribution of solids phase in the IC region. Required for a UNIFORM distribution.
12.1.8.35. IC_PSD_STDEV(IC, PHASE)
Initial standard deviation of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.8.36. IC_PSD_TYPE(IC, PHASE)
Monodisperse: all particles have diameter D_P0. |
Diameter drawn from a uniform (flat) distribution between the minimum and maximum diameters, which are both required. Mean and standard deviation are not used. |
12.1.8.37. IC_ROP_S(IC, PHASE)
12.1.8.38. IC_SCALAR(IC, SCALAR EQ.)
\(1 \le Scalar Eq. \le 100\)
12.1.8.39. IC_SQP_RANDOM_Q(IC, PHASE)
12.1.8.40. IC_T_G(IC)
12.1.8.41. IC_T_RG(IC)
12.1.8.42. IC_T_RS(IC, PHASE)
12.1.8.43. IC_T_S(IC, PHASE)
12.1.8.44. IC_THETA_M(IC, PHASE)
12.1.8.45. IC_TYPE(IC)
12.1.8.46. IC_U_G(IC)
Initial x-axial component of gas velocity in the IC region.
12.1.8.47. IC_U_S(IC, PHASE)
Initial x-axial component of solids-phase velocity in the IC region.
12.1.8.48. IC_V_G(IC)
Initial y-axial component of gas velocity in the IC region.
12.1.8.49. IC_V_S(IC, PHASE)
Initial y-axial component of solids-phase velocity in the IC region.
12.1.8.50. IC_W_G(IC)
Initial z-axial component of gas velocity in the IC region.
12.1.8.51. IC_W_S(IC, PHASE)
Initial z-axial component of solids-phase velocity in the IC region.
12.1.8.52. IC_X_E(IC)
12.1.8.53. IC_X_G(IC, SPECIES)
\(1 \le Species \le 100\)
12.1.8.54. IC_X_S(IC, PHASE, SPECIES)
12.1.8.55. IC_X_W(IC)
12.1.8.56. IC_Y_N(IC)
12.1.8.57. IC_Y_S(IC)
12.1.8.58. IC_Z_B(IC)
12.1.8.59. IC_Z_T(IC)
Z coordinate of the top face.
