12.1.11. Output control
12.1.11.1. BDIST_IO
12.1.11.2. BREAKDOWN_SOLID_INVENTORY_BY_PHASE
Required
12.1.11.3. BSTART_WITH_ONE_RES
12.1.11.4. DEBUG_DES
12.1.11.5. DES_OUTPUT_TYPE
Table 12.61 Valid values
PARAVIEW
TECPLOT
12.1.11.6. DES_REPORT_MASS_INTERP
12.1.11.7. FOCUS_PARTICLE
12.1.11.8. FRAME(VTK)
  • \(1 \le VTK \le 100\)
12.1.11.9. FULL_LOG
12.1.11.10. GROUP_RESID
12.1.11.11. MONITOR_COLL_COUNT(MONITOR)
Write the particle-wall collision count over the STL geometries defined by monitor_geo.
12.1.11.12. MONITOR_DES_RRATE(MONITOR, RATE)
  • \(1 \le RATE \le NRRMAX\)
Write particle/parcel reaction rates in region. Particle/parcel data is converted to cell data.
12.1.11.13. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)
  • \(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
12.1.11.14. MONITOR_DT(MONITOR)
12.1.11.15. MONITOR_E_TURB_G(MONITOR)
12.1.11.16. MONITOR_EP_G(MONITOR)
12.1.11.17. MONITOR_EP_S(MONITOR, PHASE)
12.1.11.18. MONITOR_FLUID_RRATE(MONITOR, RATE)
Write fluid reaction rates in region. This keyword replaces MONITOR_RRate and does not require users to write code to save data in ReactionRates(:,:) array.
12.1.11.19. MONITOR_FORCE(MONITOR)
Write the particle-wall total force (normal + tangential) over the STL geometries defined by monitor_geo.
12.1.11.20. MONITOR_GEO(MONITOR, GEO)
  • \(1 \le GEO \le MONITOR{\_}GEO{\_}MAX\)
STL file to use in a monitor.
12.1.11.21. MONITOR_K_TURB_G(MONITOR)
12.1.11.22. MONITOR_MW_MIX_G(MONITOR)
12.1.11.23. MONITOR_NAME(MONITOR)
12.1.11.24. MONITOR_NORMAL_FORCE(MONITOR)
Write the particle-wall normal force over the STL geometries defined by monitor_geo.
12.1.11.25. MONITOR_P_G(MONITOR)
12.1.11.26. MONITOR_P_S(MONITOR, PHASE)
12.1.11.27. MONITOR_P_STAR(MONITOR)
12.1.11.28. MONITOR_PART_PHASE(MONITOR, PHASE)
12.1.11.29. MONITOR_PART_RESIDENCE_TIME(MONITOR)
12.1.11.30. MONITOR_PART_RRATE(MONITOR, RATE)
  • \(1 \le rate \le 100\)
12.1.11.31. MONITOR_PCOUNT(MONITOR)
12.1.11.32. MONITOR_PMASS(MONITOR)
12.1.11.33. MONITOR_POS_X(MONITOR)
Write particle x-axis position in region.
12.1.11.34. MONITOR_POS_Y(MONITOR)
Write particle y-axis position in region.
12.1.11.35. MONITOR_POS_Z(MONITOR)
Write particle z-axis position in region.
12.1.11.36. MONITOR_PVOL(MONITOR)
12.1.11.37. MONITOR_Q(MONITOR)
Write the particle-wall heat transfer over the STL geometries defined by monitor_geo.
12.1.11.38. MONITOR_RADIUS(MONITOR)
12.1.11.39. MONITOR_RO_G(MONITOR)
12.1.11.40. MONITOR_RO_P(MONITOR)
12.1.11.41. MONITOR_RO_S(MONITOR, PHASE)
12.1.11.42. MONITOR_ROP_S(MONITOR, PHASE)
12.1.11.43. MONITOR_ROT_X(MONITOR)
12.1.11.44. MONITOR_ROT_Y(MONITOR)
12.1.11.45. MONITOR_ROT_Z(MONITOR)
12.1.11.46. MONITOR_RRATE(MONITOR, RATE)
12.1.11.47. MONITOR_SCALAR(MONITOR, SCALAR EQ.)
Write scalar in region.
12.1.11.48. MONITOR_T_G(MONITOR)
12.1.11.49. MONITOR_T_P(MONITOR)
12.1.11.50. MONITOR_T_S(MONITOR, PHASE)
12.1.11.51. MONITOR_TANG_FORCE(MONITOR)
Write the particle-wall tangential force over the STL geometries defined by monitor_geo.
12.1.11.52. MONITOR_TAVG_DT(MONITOR)
12.1.11.53. MONITOR_TAVG_RESET_DT(MONITOR)
12.1.11.54. MONITOR_TAVG_SS_SPAN(MONITOR)
12.1.11.55. MONITOR_TAVG_SS_TOL(MONITOR)
12.1.11.56. MONITOR_TAVG_START(MONITOR)
12.1.11.57. MONITOR_THETA_M(MONITOR, PHASE)
12.1.11.58. MONITOR_TORQUE(MONITOR)
Write the particle-wall total torque over the STL geometries defined by monitor_geo. All geometries in the monitor must have the same origin from which torque arm is applied.
12.1.11.59. MONITOR_TYPE(MONITOR)
Data monitor type.
Table 12.62 Valid values
Point value(cell).
Sum over region (cell).
Minimum over region (cell).
3
Maximum over region (cell).
4
Arithmetic average over region (cell).
5
Standard deviation over region (cell).
6
Area-weighted average over surface (cell).
7
Flow rate across surface (cell).
8
Mass flow rate across surface (cell).
Mass-weighted average over surface (cell).
Volumetric flow rate over surface (cell).
11
Volume integral (cell).
12
Volume-weighted average (cell).
13
Mass-weighted volume integral (cell).
14
Mass-weighted volume average (cell).
101
102
Minimum over region (particle).
103
Maximum over region (particle).
104
Arithmetic average over region (particle).
105
Standard deviation over region (particle).
106
Mass-weighted average over region (particle).
107
Volume-weighted average over region (particle).
108
Flow rate across surface (particle).
109
Mass-weighted flow rate across surface (particle).
110
Volume-weighted flow rate across surface (particle).
201
Sum over region (geometry).
202
Minimum over region (geometry).
203
Maximum over region (geometry).
204
Arithmetic average over region (geometry).
205
Standard deviation over region (geometry).
206
Area-weighted average over region (geometry).
12.1.11.60. MONITOR_U_G(MONITOR)
12.1.11.61. MONITOR_U_S(MONITOR, PHASE)
12.1.11.62. MONITOR_V_G(MONITOR)
12.1.11.63. MONITOR_V_S(MONITOR, PHASE)
12.1.11.64. MONITOR_VEL_X(MONITOR)
12.1.11.65. MONITOR_VEL_Y(MONITOR)
12.1.11.66. MONITOR_VEL_Z(MONITOR)
12.1.11.67. MONITOR_W_G(MONITOR)
12.1.11.68. MONITOR_W_S(MONITOR, PHASE)
12.1.11.69. MONITOR_WEAR(MONITOR)
Write the particle-wall wear indicator over the STL geometries defined by monitor_geo.
12.1.11.70. MONITOR_X_E(MONITOR)
12.1.11.71. MONITOR_X_G(MONITOR, SPECIES)
  • \(1 \le Species \le 100\)
12.1.11.72. MONITOR_X_P(MONITOR, SPECIES)
12.1.11.73. MONITOR_X_S(MONITOR, PHASE, SPECIES)
12.1.11.74. MONITOR_X_W(MONITOR)
12.1.11.75. MONITOR_Y_G(MONITOR, SPECIES)
12.1.11.76. MONITOR_Y_N(MONITOR)
12.1.11.77. MONITOR_Y_S(MONITOR)
12.1.11.78. MONITOR_Z_B(MONITOR)
12.1.11.79. MONITOR_Z_T(MONITOR)
12.1.11.80. NLOG
12.1.11.81. NRR
12.1.11.82. OUT_DT
12.1.11.83. PART_OUT_DENSITY_EXCLUDE
Density filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.84. PART_OUT_DENSITY_MAX
Density maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_DENSITY_EXCLUDE is set to .TRUE.
12.1.11.85. PART_OUT_DENSITY_MIN
Density minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_DENSITY_EXCLUDE is set to .TRUE.
12.1.11.86. PART_OUT_DIAMETER_EXCLUDE
Diameter filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.87. PART_OUT_DIAMETER_MAX
Diameter maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_DIAMETER_EXCLUDE is set to .TRUE.
12.1.11.88. PART_OUT_DIAMETER_MIN
Diameter minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_DIAMETER_EXCLUDE is set to .TRUE.
12.1.11.89. PART_OUT_PHASE(PHASE)
Solids phase filter selection mode applied to particles written in particle output file. Change to .FALSE. to exclude particles belonging to this phase.
12.1.11.90. PART_OUT_TEMP_EXCLUDE
Temperature filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.91. PART_OUT_TEMP_MAX
Temperature maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_TEMP_EXCLUDE is set to .TRUE.
12.1.11.92. PART_OUT_TEMP_MIN
Temperature minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_TEMP_EXCLUDE is set to .TRUE.
12.1.11.93. PART_OUT_U_EXCLUDE
X-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.94. PART_OUT_U_MAX
X-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_U_EXCLUDE is set to .TRUE.
12.1.11.95. PART_OUT_U_MIN
X-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_U_EXCLUDE is set to .TRUE.
12.1.11.96. PART_OUT_USR_VAR_EXCLUDE(INDEX)
  • \(1 \le Index \le 100\)
User-defined variable filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.97. PART_OUT_USR_VAR_MAX(INDEX)
User-defined variable maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_USR_VAR_EXCLUDE is set to .TRUE.
12.1.11.98. PART_OUT_USR_VAR_MIN(INDEX)
User-defined variable minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_USR_VAR_EXCLUDE is set to .TRUE.
12.1.11.99. PART_OUT_V_EXCLUDE
Y-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.100. PART_OUT_V_MAX
Y-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_V_EXCLUDE is set to .TRUE.
12.1.11.101. PART_OUT_V_MIN
Y-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_V_EXCLUDE is set to .TRUE.
12.1.11.102. PART_OUT_W_EXCLUDE
Z-velocity filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.103. PART_OUT_W_MAX
Z-velocity maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_W_EXCLUDE is set to .TRUE.
12.1.11.104. PART_OUT_W_MIN
Z-velocity minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_W_EXCLUDE is set to .TRUE.
12.1.11.105. PART_OUT_X_EXCLUDE
X-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data is outside the [min;max] range.
12.1.11.106. PART_OUT_X_MAX
X-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_X_EXCLUDE is set to .TRUE.
12.1.11.107. PART_OUT_X_MIN
X-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_X_EXCLUDE is set to .TRUE.
12.1.11.108. PART_OUT_X_S_EXCLUDE(INDEX)
Species filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.11.109. PART_OUT_X_S_MAX(INDEX)
Species maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_X_S_EXCLUDE is set to .TRUE.
12.1.11.110. PART_OUT_X_S_MIN(INDEX)
Species minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless corresponding PART_OUT_X_S_EXCLUDE is set to .TRUE.
12.1.11.111. PART_OUT_Y_EXCLUDE
Y-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.112. PART_OUT_Y_MAX
Y-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_Y_EXCLUDE is set to .TRUE.
12.1.11.113. PART_OUT_Y_MIN
Y-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_Y_EXCLUDE is set to .TRUE.
12.1.11.114. PART_OUT_Z_EXCLUDE
Z-coordinate filter selection mode applied to particles written in particle output file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select only particles with data outside the [min;max] range.
12.1.11.115. PART_OUT_Z_MAX
Z-coordinate maximum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_Z_EXCLUDE is set to .TRUE.
12.1.11.116. PART_OUT_Z_MIN
Z-coordinate minimum value of the filter applied to particles written in particle output file. By default, particles with data between min and max value are written out, unless PART_OUT_Z_EXCLUDE is set to .TRUE.
12.1.11.117. PART_OUT_ZERO_VEL
Option to reset the velocity to zero in the particle output file. Default value is .False. (do not reset the velocity to zero).
12.1.11.118. PHIP_OUT_JJ
12.1.11.120. REPORT_MASS_BALANCE_DT
12.1.11.121. REPORT_NEG_DENSITY
Table 12.63 Valid values
Log negative density errors.
12.1.11.122. REPORT_NEG_SPECIFICHEAT
Table 12.64 Valid values
12.1.11.123. REPORT_SOLID_INVENTORY
Required
12.1.11.124. REPORT_SOLID_INVENTORY_DT
Required
12.1.11.125. RES_BACKUP_DT
12.1.11.126. RES_BACKUPS
12.1.11.127. RES_DT
Required
12.1.11.128. RESID_STRING(RESIDUAL INDEX)
Table 12.65 Valid values
P0
Gas pressure
PM
Solids phase M pressure
R0
Gas density
RM
Solids phase M density
U0
Gas phase U-velocity
V0
Gas phase V-velocity
W0
Gas phase W-velocity
UM
Solids phase M U-velocity
VM
Solids phase M V-velocity
WM
Solids phase M W-velocity
T0
Gas temperature
TM
Solids phase M temperature
GM
X0NN
XMNN
K0
K-Epsilon model residuals
12.1.11.129. SPX_DT(SP VALUE)
  • \(1 \le SP Value \le 11\)
  • SP1: void fraction (EP_G)
12.1.11.130. TIME_DEPENDENT_FILENAME
Table 12.66 Valid values
12.1.11.131. TSS_HDR
12.1.11.132. VTK_BC_ID(VTK)
12.1.11.133. VTK_C_PG(VTK)
12.1.11.134. VTK_C_PS(VTK, PHASE)
12.1.11.135. VTK_CUTCELL_ONLY(VTK)
12.1.11.136. VTK_DATA(VTK)
Table 12.67 Valid values
C
Cell data (VTU file).
P
Particle data (VTP file).
G
Geometry data (STL file).
F
Force chain data (VTP file).
N
Glued (non-spherical) particle data (VTP file).
12.1.11.137. VTK_DBG_FILE(VTK)
When VTK_DBG_FILE is .TRUE., the VTK region file is only written when the subroutine WRITE_DBG_VTU_AND_VTP_FILES is called, typically in a UDF.
12.1.11.138. VTK_DEBUG(VTK, IDX)
  • \(1 \le IDX \le 15\)
12.1.11.139. VTK_DES_RRATE(VTK, RATE)
  • \(1 \le rate \le nRRmax\)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is accumulated in fluid cells.
12.1.11.140. VTK_DT(VTK)
12.1.11.141. VTK_DWALL(VTK)
12.1.11.142. VTK_E_TURB_G(VTK)
12.1.11.143. VTK_EP_G(VTK)
12.1.11.144. VTK_EP_S(VTK, PHASE)
12.1.11.145. VTK_FACET_COUNT_DES(VTK)
12.1.11.146. VTK_FCMAX_ONLY(VTK)
12.1.11.147. VTK_FILEBASE(VTK)
12.1.11.148. VTK_FLUID_RRATE(VTK, RATE)
12.1.11.149. VTK_GEO(VTK, GEO)
Geometry source for VTK geometry output.
12.1.11.150. VTK_GSP_OUTPUT_TYPE(VTK)
Type of GSP output shape in VTK files.
Table 12.68 Valid values
Use actual glued particle shape (show all component spheres).
Use bounding sphere to represent entire GSP.
12.1.11.151. VTK_IJK(VTK)
12.1.11.152. VTK_K_G(VTK)
Write gas phase thermal conductivity in region.
12.1.11.153. VTK_K_TURB_G(VTK)
12.1.11.154. VTK_LAMBDA_2(VTK)
Write lambda_2 in region.
12.1.11.155. VTK_MU_G(VTK)
12.1.11.156. VTK_MW_MIX_G(VTK)
12.1.11.157. VTK_NB_FACET_DES(VTK)
12.1.11.158. VTK_NORMAL(VTK)
12.1.11.159. VTK_NXS(VTK)
12.1.11.160. VTK_NYS(VTK)
12.1.11.161. VTK_NZS(VTK)
12.1.11.162. VTK_P_G(VTK)
12.1.11.163. VTK_P_S(VTK, PHASE)
12.1.11.164. VTK_P_STAR(VTK)
12.1.11.165. VTK_PART_ANGULAR_VEL(VTK)
12.1.11.166. VTK_PART_C_PS(VTK)
12.1.11.167. VTK_PART_CGP_STAT_WT(VTK)
12.1.11.168. VTK_PART_COHESION(VTK)
12.1.11.169. VTK_PART_COLL_FORCE(VTK)
12.1.11.170. VTK_PART_COORDINATION(VTK)
Write particle coordination number in region.
12.1.11.171. VTK_PART_DENSITY(VTK)
12.1.11.172. VTK_PART_DIAMETER(VTK)
12.1.11.173. VTK_PART_DRAG_COEFF(VTK)
12.1.11.174. VTK_PART_GLUEBOUNDING(VTK)
12.1.11.175. VTK_PART_GLUEDIAMETER(VTK)
12.1.11.176. VTK_PART_GLUEID(VTK)
12.1.11.177. VTK_PART_GLUEMASS(VTK)
12.1.11.178. VTK_PART_GLUEQUAT(VTK)
12.1.11.179. VTK_PART_GLUEVOLUME(VTK)
12.1.11.180. VTK_PART_ID(VTK)
Write particle ID in region.
12.1.11.181. VTK_PART_MASS(VTK)
12.1.11.182. VTK_PART_ORIENTATION(VTK)
12.1.11.183. VTK_PART_OVERLAP_STATS(VTK)
Write particle overlap statistics (min, max, mean) in region.
12.1.11.184. VTK_PART_PHASE(VTK, PHASE)
12.1.11.185. VTK_PART_PHASE_ID(VTK)
12.1.11.186. VTK_PART_PHYSICAL_DIAMETER(VTK)
12.1.11.187. VTK_PART_RANK(VTK)
12.1.11.188. VTK_PART_RESIDENCE_TIME(VTK)
12.1.11.189. VTK_PART_RRATE(VTK, RATE)
12.1.11.190. VTK_PART_TEMP(VTK)
12.1.11.191. VTK_PART_USR_VAR(VTK, USR_VAR)
12.1.11.192. VTK_PART_VEL(VTK)
12.1.11.193. VTK_PART_VOLUME(VTK)
12.1.11.194. VTK_PART_X_S(VTK, DES_SPECIES)
12.1.11.195. VTK_PARTITION(VTK)
12.1.11.196. VTK_RO_G(VTK)
12.1.11.197. VTK_RO_S(VTK, PHASE)
12.1.11.198. VTK_ROP_S(VTK, PHASE)
12.1.11.199. VTK_RRATE(VTK, RATE)
12.1.11.200. VTK_RRATE_LABEL(VTK, RATE)
12.1.11.201. VTK_SCALAR(VTK, SCALAR)
12.1.11.202. VTK_SCALAR_CC(VTK)
12.1.11.203. VTK_SELECT_MODE(VTK)
Table 12.69 Valid values
C
P
I
12.1.11.204. VTK_SLICE_TOL(VTK)
12.1.11.205. VTK_STL_AREA(VTK)
Write STL facet surface area in region (geometry data).
12.1.11.206. VTK_STL_COLL_COUNT(VTK)
Write collision count between particles and STL facet in region (geometry data).
12.1.11.207. VTK_STL_FORCE(VTK)
Write total force exerted by particles onto the STL facet in region (geometry data).
12.1.11.208. VTK_STL_GROUP_ID(VTK)
Write STL facet group ID in region (geometry data).
12.1.11.209. VTK_STL_NORMAL_FORCE(VTK)
Write normal force exerted by particles onto the STL facet in region (geometry data).
12.1.11.210. VTK_STL_NORMAL_VEL(VTK)
Write normal velocity of a moving STL facet in region (geometry data).
12.1.11.211. VTK_STL_Q(VTK)
Write heat transfer between particles and STL facet in region (geometry data).
12.1.11.212. VTK_STL_TANG_FORCE(VTK)
Write tangential force exerted by particles onto the STL facet in region (geometry data).
12.1.11.213. VTK_STL_TANG_VEL(VTK)
Write tangential velocity of a moving STL facet in region (geometry data).
12.1.11.214. VTK_STL_TORQUE(VTK)
Write torque exerted by particles onto the STL facet in region (geometry data). The torque pivot point must be defined for each geometry (STL BC, regular BC or default BC).
12.1.11.215. VTK_STL_VEL(VTK)
Write velocity of a moving STL facet in region (geometry data).
12.1.11.216. VTK_STL_WEAR(VTK)
Write a measure of the wear on the STL facet in region (geometry data).
12.1.11.217. VTK_T_END(VTK)
12.1.11.218. VTK_T_G(VTK)
12.1.11.219. VTK_T_S(VTK, PHASE)
12.1.11.220. VTK_T_START(VTK)
12.1.11.221. VTK_THETA_M(VTK, PHASE)
12.1.11.222. VTK_U_G(VTK)
12.1.11.223. VTK_U_S(VTK, PHASE)
12.1.11.224. VTK_V_G(VTK)
12.1.11.225. VTK_V_S(VTK, PHASE)
12.1.11.226. VTK_VAR(IDX)
  • \(1 \le IDX \le 20\)
Table 12.70 Valid values
Void fraction (EP_g)
3
Gas velocity (U_g, V_g, W_g)
4
5
Solids density (ROP_s)
6
7
8
Scalar
Reaction rates
11
K and Epsilon
12
100
Grid Partition
101
Boundary Condition ID
102
Distance to wall
103
DEM facet count
104
DEM Neighboring facets
999
Cell IJK index
1000
Cut face normal vector
12.1.11.227. VTK_VEL_G(VTK)
12.1.11.228. VTK_VEL_S(VTK, PHASE)
12.1.11.229. VTK_VORTICITY(VTK)
12.1.11.230. VTK_W_G(VTK)
12.1.11.231. VTK_W_S(VTK, PHASE)
12.1.11.232. VTK_X_E(VTK)
12.1.11.233. VTK_X_G(VTK, GAS SPECIES)
12.1.11.234. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)
12.1.11.235. VTK_X_W(VTK)
12.1.11.236. VTK_Y_G(VTK, GAS SPECIES)
12.1.11.237. VTK_Y_N(VTK)
12.1.11.238. VTK_Y_S(VTK)
12.1.11.239. VTK_Z_B(VTK)
12.1.11.240. VTK_Z_T(VTK)
12.1.11.241. VTP_DIR
12.1.11.242. VTU_DIR
Directory where VTK files are stored. By default, VTK files are written in the run directory.
12.1.11.243. WRITE_PART_OUT
Option to write a particle output file at the end of a simulation. After the simulation, the file can be renamed as particle_input.csv and used as initial condition for another simulation. For example, a first granular DEM simulation can be run fairly quickly to settle a bed of particles and the data saved in this file can be used to start a new coupled simulation. Default value is .False. (do not write the file).
12.1.11.244. WRITE_VTK_FILES
Table 12.71 Valid values
