12.1.15. Point sources (PS)
Point sources are used in place of mass inlets where either the geometry and/or grid resolution prohibit proper boundary condition specification. For example, a point source may be used to model an injector with dimensions smaller than the grid. Point sources may be defined within a single computational cell, along a plane, or as a volume of computational cells.
Directional preference is specified with a velocity vector (i.e., PS_U_g,
PS_V_g, etc.), however, directional preference is not required.
12.1.15.1. PS_I_E(PS)
\(1 \le PS \le 5000\)
12.1.15.2. PS_I_W(PS)
12.1.15.3. PS_J_N(PS)
12.1.15.4. PS_J_S(PS)
12.1.15.5. PS_K_B(PS)
12.1.15.6. PS_K_T(PS)
K index of the top-most cell.
12.1.15.7. PS_MASSFLOW_G(PS)
12.1.15.8. PS_MASSFLOW_S(PS, PHASE)
12.1.15.9. PS_T_G(PS)
Temperature of incoming gas.
12.1.15.10. PS_T_S(PS, PHASE)
12.1.15.11. PS_U_G(PS)
X-axial component of incoming gas velocity.
12.1.15.12. PS_U_S(PS, PHASE)
X-axial component of incoming solids velocity.
12.1.15.13. PS_V_G(PS)
Y-axial component of incoming gas velocity.
12.1.15.14. PS_V_S(PS, PHASE)
Y-axial component of incoming solids velocity.
12.1.15.15. PS_W_G(PS)
Z-axial component of incoming gas velocity.
12.1.15.16. PS_W_S(PS, PHASE)
Z-axial component of incoming solids velocity.
12.1.15.17. PS_X_E(PS)
12.1.15.18. PS_X_G(PS, SPECIES)
\(1 \le Species \le 100\)
12.1.15.19. PS_X_S(PS, PHASE, SPECIES)
12.1.15.20. PS_X_W(PS)
12.1.15.21. PS_Y_N(PS)
12.1.15.22. PS_Y_S(PS)
12.1.15.23. PS_Z_B(PS)
12.1.15.24. PS_Z_T(PS)
