12.1.4. Chemical reactions
12.1.4.1. ARRHENIUS_RRATES_DES
Flag to use Arrhenius reaction model for discrete particle reactions.
12.1.4.2. ARRHENIUS_RRATES_FLUID
Flag to use Arrhenius reaction model for fluid phase reactions.
12.1.4.3. CHEM_MIN_SPECIES_FLUID
Minimum species mass fraction in fluid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.4. CHEM_MIN_SPECIES_SOLID
Minimum species mass fraction in solid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.5. DES_MIN_PMASS_FRAC
Minimum particle mass fraction for reactions. When the ratio of particle mass to initial mass is below this threshold, reactions which consume particle species will be turned off for these particles. If a particle size distribution is in effect, the initial mass is the minimum mass for the distribution.
12.1.4.6. NMAX(PHASE)
\(0 \le Phase \le 10\)
12.1.4.7. SPECIES_NAME(PHASE)
12.1.4.8. STIFF_CHEM_ABS_TOL
12.1.4.9. STIFF_CHEM_MAX_STEPS
12.1.4.10. STIFF_CHEM_MIN_RATE
Stiff chemistry minimum fluid reaction rate. If all fluid reaction rates are below this threshold, a cell is said to be non-reactive and no ODE is set for this cell.
12.1.4.11. STIFF_CHEM_MIN_RATE_DPM
Stiff chemistry minimum DPM (Discrete Phase Model) reaction rate. If all DPM reaction rates are below this threshold, a particle/parcel is said to be non-reactive and no ODE is set for this particle/parcel.
12.1.4.12. STIFF_CHEM_REL_TOL
12.1.4.13. STIFF_CHEMISTRY
Flag to use stiff chemistry solver (Direct integration).
12.1.4.14. USE_RRATES
