3.1. First tutorial
3.1.1. Starting the MFiX GUI
On Windows, open the Miniforge Prompt and activate the mfix environment
Windows
conda activate mfix-26.1.4
(mfix-26.1.4) C:\> mfix
Linux or Mac
(mfix-26.1.4) > mfix
3.1.2. Creating a project
Icon
Single
Single-phase Model
TFM
Two-fluid Model (TFM)
PIC
Particle in Cell Model (PIC)
DEM
Discrete Element Model (DEM)
Hybrid
Hybrid Model (TFM + DEM)
Geometry
Cartesian cut-cell (complex) geometry
Chemistry
Chemistry
  • Filter the templates by de-selecting the Single (single-phase), and Chemistry (chemistry) icons
  • Double-click on hopper_3d (3D DEM granular flow hopper) to create a new project
  • Enter a project name (or keep the existing name) and browse to a location for the new project.
  • Click Ok
3.1.3. Running the solver
  • Click the Play (Start) button to open the Run dialog.
  • Click Ok to use the default mfixsolver: [default]/mfixsolver
The solver will begin to run, with output displayed in the Console window. There is a progress bar along the bottom of the screen where it says MFiX running: elapsed time.
3.1.4. View results
  • Select the VTK results tab. The visibility and representation of the *.vtk files can be controlled with the menu on the side.
  • Change frames with the First, Back, Next, and Last buttons
  • Click the Play button to play the available vtk files.
  • Change the playback speed under the Speed section on the sidebar.
3.1.5. Pausing/unpausing
  • Click the Pause (pause) button to pause the solver.
    MFiX paused will be displayed in the Console window. The solver process still exists, but is waiting for you to unpause it.
    While the solver is paused, you can change the project. For instance, on the Run Pane you could change Stop time to another value to have the solver run for a different amount of time.
  • Click the Play (run) button to unpause the solver and continue running.
3.1.6. Stopping/resuming
  • Click the Stop (stop) button to stop the solver.
MFiX stopped will be displayed in the Console window. The solver process has ended, with the output files still in the project directory.
  • Clicking the Play (run) button to open the Run dialog.
  • Check Restart and select Resume from the drop down list.
  • Click Ok to use the default mfixsolver.
