3.8. SMS meshing workflow, cyclone, Discrete Element Model (DEM)
The SMS workflow is an optional feature, and can
be turned on from the settings menu (select SMS: Segregated Mesher/Solver from the Mesher workflow drop down list). The blank template will automatically
3.8.1. Create a new project
3.8.2. Import the geometry
Go to the Geometry pane:
Choose
STL fileas the geometry input.
cyclone.stl, select it and answerYeswhen prompted to copy the file to the project directory.Verify the STL normals are pointing in the right direction. In the model window, show the Geometry, hide the Background mesh, hide the Regions (visibility is toggled by clicking on each icon). Set the Geometry style to
edges, opacity to 1.0, check theShow normalsbox, set theScaleto 0.05, setcountto 10,000 (to show all normals).
Check the Flip normals box and notice the difference in the Model view. Uncheck the box since the original STL
file was correctly oriented.
In
Domain extent, click on Autosize, and adjust the following:Enter
0.0for the Min Y value.Enter
0.9for the Max Y value.Enter
0.25for the Max Z value.
3.8.3. Create boundary conditions regions
Go to the Regions pane:
There is already a
Backgroundthat is predefined in the Blank template. We can ignore it for now.Click the
(top) button to create a new region to be used by pressure outflow boundary condition.
Pressure outflowin theBoundary typedrop down menu.Enter a name for the region in the
Namefield (“Top outlet”).Change the region color to blue.
(bottom) button to create a new region to be used by another pressure outflow boundary condition.
Namefield (“Bottom outlet”).Change the region color to yellow.
(front) button to create a new region to be used by mass inflow boundary condition.
Mass inflowin theBoundary typedrop down menu.Enter a name for the region in the
Namefield (“Front inlet”).Change the region color to red.
Namefield (“Wall”).Change the region color to green.
Select facets (STL)andcyclone.stl, useallfor the selection method. You should see that there are 7554 facets selected.
3.8.4. Setup the mesh
25for the x cell value.Enter
70for the y cell value.Enter
33for the z cell value.
Generate. Select the default solver, and clickRunLook at the console output to verify the mesh generation completed successfully.
In the Model view - hide the
Geometry,Background meshandRegions, - show theBoundary mesh- setColor bytobc_id, - setStyletoedgesand opacity to1.0.The boundary mesh should look like a closed surface with colors matching the boundary conditions regions.
Color the boundary mesh by
small_cell. This will show small cells, as defined by the small cell tolerance. The default value of 0.01 means a cut cell is considered small if its volume is below 0.01 times the volume of the corresponding standard, uncut cell. These small cells will be removed from the computation. Having a Small cell tolerance set to 0.0 will keep all small cells and this may lead to numerical stiffness and loss of convergence.
Mesh statistics (histogram) can be viewed in the Mesh stats viewport. Various quantities are available. For example the aspect ratio of cut cells is between 1 and 8, with most aspect ratios between 1 and 2. This is acceptable.
Go back to the
Geometrypane, and flip the normals. This will incorrectly orient the STL file. This is a common error when importing STL files. Generate the mesh and visualize the boundary mesh. Having an open surface and boundaries inside-out is an indication that the normals are not properly oriented. The mesh should not be accepted.
Uncheck the
Flip normalsbox in the Geometry pane to get correct orientation. Go to the Region pane, and select the Front inlet region in the region table and set theBoundary typetoNone. Save the project and generate the mesh. The boundary mesh will look like an open surface, this is an indication a boundary condition is missing. The mesh should not be accepted.
Remember to set the Front inlet region boundary type to Mass inflow again before continuing.
3.8.5. Model settings
3.8.6. Regions settings
We already have the Background region that is predefined. We will use it to initialize the flow field. We have defined all Boundary Condition regions during the meshing step. There are no other regions that need to be defined in this tutorial. We will reuse Background region for the VTK output file.
3.8.7. Fluid settings
Change Density to
3.8.8. Solids settings
Namefield (“Glass beads”).Verify the solids model is already set to “Discrete Element Model (MFiX-DEM)”.
2500kg/m3 in theDensityfield.
Enable automatic particle generationcheckbox. Although we will start with an empty cyclone, this setting is necessary so we don’t attempt to read initial particle location fromparticle_input.dat.Keep all other settings at their default values.
3.8.9. Initial conditions settings
There is already a pre-defined “Background” region. This will initialize the entire flow field with air at rest.
3.8.10. Boundary conditions settings
The Top outlet and Bottom outlet Boundary conditions are already set to atmospheric pressure. No changes are needed.
The Wall Boundary conditions is already set to No-slip wall. No changes are needed.
3.8.11. Numerics settings
On the Numerics pane:
3.8.12. Output settings
Basicsub-pane, check theWrite VTK output files (VTU/VTP)checkbox.
VTKsub-pane.Select “Particle Data” from the ‘Output type’ drop-down menu.
Select the “Background” region from the list to save all the particle data.
OKto create the output.
3.8.13. Run settings
Set
Stop timeto1.0.Set
Time stepto0.01.Set
3.8.14. Run the simulation
3.8.15. View results
next to the Model tab.
